Question about Maxtor Hard Drive
Pc and Laptop not recognizing hard drive when attached says no maxtor detected
    Scholar:
  • 167 Answers
If it's not detected how does it know to say "no Maxtor detected"?
Posted on Feb 04, 2010
How to fix a 500GB Maxtor hard when Bios doese not recognize it or recognize it as a 500GB drive?
Is this an unused drive? What is the cable interface - IDE or SATA?
What operating system are you using? Is this a PC or a laptop?
2.5" or 3.5" version?
What have you actually done with the computer/drive and software in your attempts to install the drive?
Jan 07, 2015 | Maxtor Computers & Internet
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
Jun 10, 2011 | Maxtor OneTouch III Mini Edition R01E100...
How should I bootup a maxtorHard Disk which cannot be recognized by BIOS?
Hello Samaya,
If the Maxtor Hard Driveis not detecting in BIOS then you have to replace it with new hard drive from the MAXTOR service centre or from the market.
Jun 01, 2011 | Maxtor Hard Drive
My maxtor D740X-6l 40GB drive will not boot up. I can hook the drive up to another computer and read the files but it will not even show as a drive on the original computer. The first computer recognizes...
all you have to do is to simply set the jumper at the back of he hard disk, beside where the IDE cable and power enter into the hard disk.
Just keep setting till you put at the right position where the system recognizes it.
There is nothing wrong with your PC and hard drive, just set the jumper of the Hard disk and that should be all.
Take care.
Jan 04, 2010 | Maxtor Hard Drive
Hay i am having Maxtor OneTouch 4 Mini (160GB).it does not detected by any computer except where its software is installed.plz ans immed
I've had this problem before (something similar) you'll need additional software from Maxtor.com so you're PC will recognize the new drive.
Jul 18, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Laptop does not detect recognize maxtor hard drive
Remove and re-attach the data (flat ribbon) cable to the hard drive. Heating and cooling cause poor conections to ecome no connections. By removing and re-attaching the data cable, you remake the connections. You may want to do the same with the power cable connections. If this does not work, my experience leads me to think the hard drive main board is dead. If this is the case, the drive will not be recognised. If the drive itself is dead but the mainboard is good, the drive is recognised but will not read/write. Heat is a real nasty hard drive killer.
May 22, 2009 | Maxtor Hard Drive
Laptop does not detect maxtor hard drive pc. please help me......
did you get a master disc for the maxtor hard drive if not you can download the drivers for vista of the net. sounds like it is set on dos or the jump pin is set to master instead on slave or the other way round.
Can't detect an external Hard drive (Maxtor 1TB)
im going to assume your on XP for these instructions. other wise you still need to do the same thing.
right click the my computer desktop or the start menu. go down to properties. open the hardware tab. open the device manager. Scroll down to it, remove the driver, just delete the whole entry. unplug the hard drive, then plug it in again. See if that works.
hope this will fixya....
Jan 05, 2009 | Maxtor Hard Drive
Brand new Seagate Maxtor OneTouch 4 plus 750 Gb isn't recognized
jumpered wrong or its a fake drive (knockoff) but doubtful so the real diagnostics is
start run diskmgmt.msc in it you will find if drive is unalocated or not even detected. if its not detected goto run type eventvwr and check in system for errors ..
im starting to think upper and lower cdrom filters are causing usb issue. i had issues with old zip drive software causing this.
Aug 01, 2008 | Maxtor Hard Drive
Maxtor Basics external portable hard drive not getting detected
I have a Western digital model wd2500b007-rnn
and I cannot get either my PC or my laptop to recognize the drive. I isolated the drive to another computer with the same error. It says USB device not reognized. I also tried a different port. I have not tried different cables. Can I retrieve the old data on the drive?
Did you find a resolution for this? I am having the same problem. None of my PCs can recognize the drive. Formatting seems to be the only choice but I need to recover my old data first.
Jun 06, 2008 | Computers & Internet
Maxtor Hard Drive Logo
91 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
