Question about Lexmark X4650 InkJet Printer
SAys replace ink cartridges.. did that but still
I have a Lexmark X5650 Says replace ink cartridges.. did that but still will not print.. say alignement needed press ok.. do that.. then says needs cartridges. but have brand new ones in.. HELP!
  • Official Brand Answer
  • 3,344 Answers
The problem sometimes is that when you unpack the cartridges a little bit of residue of the packaging stays in the printhead of the cartridges. Here is a link that shows you how to clean the nozzles. http://www.bit.ly/aBjxGa
Posted on Feb 13, 2010
I dont know how to change the ink cartridge on my lexmark?
For more detailed instructions on how to change/replace the ink cartridges in your Lexmark printer, please refer to the Lexmark X5650 User's Guide. Turn to page 111 - Maintaining Print Cartridges.
I hope this information has been helpful.
Nov 30, 2011 | Lexmark X5650 All-in-One InkJet Printer
How can I install black cartridge only without printer stopping me from printing
The Lexmark X5650 printer requires both the black and color cartridges to be inserted in the printer to continue printing. Both cartridges must have ink in them and not empty.
Sep 03, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
How do you close front to get ink cartridge out
Please follow the steps below on how to change the cartridges on your Lexmark X5650 printer:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
Jul 26, 2011 | Lexmark X5650 All-in-One InkJet Printer
We have a X5650 Lexmark printer. The ink cartridges were both replaced with certified cartridges (parts 36 and 37xl) . When installed the printer does not recognize that the cartridges have ink and...
It could be that the cartridges are not inserted properly in the carrier or just needs cleaning. Try to remove both cartridges from the printer and manually clean the nozzles. You may refer to this article on How to Clean the Print Cartridge Nozzles and Contacts Manually. Then reinsert one cartridge first and close the cover. If no error appears, reinsert the other cartridge. Replace whichever cartridge is causing the error. You can also try the Clean Cartridge function on the printer by pressing the Setup button -> Maintenance -> Clean Cartridges. It will then print the clean nozzles test page. If error continues, replace the faulty cartridge.
Jan 20, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
My lexmark x5650 ran out of ink and i replaced the cartridges and it keeps saying to replace them. they are new please help.
I have had same problem with same model. As ink is used there are tiny internal electronic fuses which 'blow' as ink is used and cannot be reset. Sorry you need to buy original cartridge.
ianparronline.wordpress.com
Jan 03, 2011 | Lexmark X5650 All-in-One InkJet Printer
I just set up a new X5650 printer, and after a couple of print jobs, the printer says black and color ink low. I changed to brand new cartridges, and it still says the same thing. What should I do?
Some printer-vendors sell "half-full" ink-cartridges, to get you to _sooner_ buy replacement ink-cartridges.
Also, some printers need to be "told" (via software) that the ink-cartridge has either been replaced or refilled. Your printer could be one of those printers.
Aug 24, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
I have a new Lexmark X5650. for the first time I changed the black ink cartridge with an original 36 as indicated, and yet it tells me I am out of ink! Help! Thank you
Remove the cartridges from the printer. Close the cover. Unplug the printer from the power source and leave it unplug for now. Then, wipe the nozzles of the cartridge using a damp paper towel. Plug the printer back to its power source. When the printer's ready, re-insert the cartridges. Close the cover. The printer will print an alignment page. Just let it print the page without cancelling it. If that doesn't resolve the problem, try pressing the Settings button on the printer control panel. Go to Maintenance, then hit ok. Select Clean cartridges, then hit ok. That will force inks out of the cartridges and also cleans the nozzles. You can check ink levels by pressing Settings on the printer control panel. Then go to Maintenance, select Check Ink Levels. If ink level is still not recognized, have the ink cartridge replaced. You probably got a defective one.
Apr 08, 2010 | Lexmark X5650 All-in-One InkJet Printer
Hi i have a lexmark x5650 printer, i have just refilled the cartriges and it wont recognise them keeps telling me to replace them, any ideas any one ? neil.
I had same problem. I unplugged the unit, took a pink pencil lead and lightly cleaned the contacts, put the ink back in the plugged unit back in and it worked.
May 01, 2009 | Lexmark Office Equipment & Supplies
Refilled the black cartridge and now it doesnt recongize it
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 13, 2009 | Lexmark X5650 All-in-One InkJet Printer
Ink Cartrdige Won't Print
it is because the cartridges are non refillable..... they have a memory chip in them and can not be refilled except by lexmark thru their recycle center
Mar 22, 2009 | Lexmark X5650 All-in-One InkJet Printer
Lexmark X4650 InkJet Printer Logo
419 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
