Question about Dryers
The dryer is plugged in and blows really hot but the drum does not turn- any idea where to start
  • 2,418 Answers
The dryer has a belt that goes around the drum and is driven by a motor in the bottom of the mach. Open the back or lay it down on a bucket on the front and look for the belt to be off or broken.
Posted on Feb 04, 2010
  • 10,319 Answers
You have a broken or a belt that came off the drum of your dryer. The very front panel of your dryer will need to come off. Then you will see the drum as well. A belt tensioner keeps the belt tight also. If you had a sqeek the past few days the bearing for the tensioner makes that noise upon wearing out causing the belt to come off. If the belt is broken it may need a new tensioner as well. I would replace both items if 5 years old or more
Dryer runs for three or four minutes then shuts of and willnot start for 10 minutes or longer'
Could be motor overheating and shutting off. Need to check if drum turns freely. If it does check vent hose making sure it isn't plugged causing dryer to overheat. If motor is bad it will get worse and just not start
Sep 24, 2014 | Avanti D110 Electric Portable Dryer
Dryer not drying clothes
Hello, does the dryer drum turn? If the dryer drum is moving. Is the dryer blowing hot air, cold air, no air at all? Now, if it's doing everything mention above escept blowing hot air then you'll need a new heating element. If not blow air, then the drum belt is broken, belt off, or the drum motor has gone south. It was put for a quitt. Which mean in New Mexico, they fired me, I don't work, no job, finished, I'am out of here, don't bury me with my wires exposed. I hope I was some help to you. have a nice day and be safe, GB. stewbison
Aug 20, 2011 | Dryers
The dryer drum does not rotate. I have a Kenmore electric model number 110.62622101. It blows hot air but drum does not rotate
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 15, 2011 | Kenmore 62622 Electric Dryer
Can 3431 be converted to a regular vented dryer?
You cannot convert this model. This unit blows hot air into drum and the water is turned to steam and exhausted out through the pump to the drain. Unlike regular dryers that blow hot air into drum, creating link and just heat that blow out vent.
Jun 22, 2010 | LG WM3431 Front Load Washer / Dryer
Dyer really hot, not drying clothes
Is the dryer tumbling? If not, you may have a broken belt or some other drive assembly issue.
Also, turn the dryer on and go outside to the vent discharge - you should feel air coming out at a pretty good clip. If not, the vent line is obstructed and will need to be cleaned out.
Jan 07, 2010 | Dryers
Dryer will not produce hot air. What could be the problem? I opened the back panel and there is a square shaped box that was hot. Is that the heat element?
The heating element should be nearly the diameter of the drum and is generally round. If the box of which you speak is about 4 to 6 inches square, it is probably an electrical connection box and shouldn't be getting hot. If this box has a removable cover, unplug the power cord and remove the cover--look for loose connections. If all ok, replace cover. Does the drum turn? Start the dryer and check for air blowing from the outside vent. If not, check for plugged lint filter (wash with hot water and detergent) and lint plugging the flex-hose between the dryer outlet and the outside vent. After running for a little while, feel the back of the drum to see if is generally hot--if so, then the heating element appears to be working. Hope this helps.
Jul 26, 2009 | Dryers
Tricity Bendix WDR1240W Condenser dryer problem
Check the fan that is supposed to blow the hot air into the drum. It may be seized or jammed. It should be situated on the top of the outer drum. You will need to remove the top cover from the machine and identify the blower fan.
Nov 01, 2007 | Tricity Bendix WDR1240W Front Load Washer...
Dryers Logo
65 people viewed this question
Top Dryers Experts
