Question about KitchenAid KUDR25 Dishwasher
Child lock blinking on a Kitchenaid ultima diswasher.
Can't turn it off. It's a Whisper quiet ultima Super ba. I see no lock symbol, I have tried holding down the energy saver button for 5 seconds. Nothing.
    Problem Solver:
  • 15 Answers
Try holding the E.S. button down for 30 seconds. Does not work, you need an Electronic control assembly which can be ordered online from Repair clinic .com for $146 for your model plus shipping. This is apparently a common problem with Kitchenaid dishwashers. Just repaired one the other day. Tried everything, but as soon as the new Electronic control assembly was installed, everything was Okay. This is an easy repair for anyone who is handy at all. Please shut off power to the dishwasher by switching the breaker off or removing the fuse.
Posted on Feb 20, 2010
  • fldab Oct 03, 2013
    I have the same problem. I have tried holding down the Energy Saver /Dry butoon for 30 sec and more, multiple times with no results. Before i spend $147 to hopefully repair a dishwasher I bought used, I'll go buy a new dishwasher.
The child lock light flash
Hello. Your Kitchenaid unit has the child-lock enabled. Look for a button(or set of buttons) that has a small lock symbol beneath or the word "lock". On most models, you have to push and hold the button(s) until the lock light goes out(usually about 3-5 seconds). That should disable the lock and the unit should operate normally. I hope this helps you!
Dec 18, 2015 | KitchenAid Dishwashers
Display Panel locked
To turn off Lock, press and hold ProDry for at least
4 seconds.
Feb 10, 2013 | KitchenAid KUDD03DTSS - Double-Drawer...
The access door will not open, it is showing the locked symbol in the window
Your problem is either one of the 2 cases below.
1. Door Locked Indicator...'Keyhole' symbol
The 'Keyhole' symbol will illuminate 2 seconds after you have
pressed the 'START/CANCEL' button and will remain lit
throughout the wash programme.
The 'Keyhole' symbol will be flashing at the end of the
programme to indicate that the door is still locked. When the
symbol goes off you will hear a bleep and the door can then
be opened.
2. If the machine has been child locked, deactivate this feature by pressing and holding in the 'child lock' button for 2 seconds.You will hear a beep and the child lock symbol will go out,allowing you to use the machine normally.
Jun 05, 2011 | Hotpoint Ultima WF860 Front Load Washer
I have a Kitchenaide Whisper Quiet Ultima dishwasher. It will come on, but no water comes in. Is there a reset button or something that may be clogged?
Are you able to provide the model no. of your dishwasher please.
NO water coming in could be either due to water inlet solenoid not working, the controller not working or the flood switch being triggered.
Need the actual model no. to confirm likely situation.
Sep 20, 2010 | KitchenAid Dishwashers
Child lock to turn off
Well you can please follow the below steps -
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
2. Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
3. Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Good Luck!!
Thanks
Mar 02, 2010 | KitchenAid Dishwashers
How to unlock the child lock
Most of the dishwasher in this series have an energy saver dry button. Hold this button in for four seconds and it should unlock the child safety lock. Does not work, try again for 30 seconds. Does not work. We have problem. If your model does not have an energy safer button, then type in the model number and you should be able to find the manual online and open the same to find out how to unlock the child safety lock. If all fails then you need an Electronic control board assembly, about $86 for your model, plus shipping from repair clinic.com. If you are at all handy, this is easy repair. Make sure you turn off the breaker or remove the fuse before you attempt any repairs.
Feb 08, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Door lock symbol showing on screen and door will
Assuming child lock is not on...Water not fully going away/ blockage @ filter.
Nov 02, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Child lock shut off
Hold the button with the lock until the light turns off. Consult the manual.
Can you provide a model number?
Feb 18, 2009 | Dishwashers
KitchenAid KUDR25 Dishwasher Logo
2,787 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
