Question about Speed Queen Washing Machines
Washer is smoking....
My daughter overloaded the washer with clothes. when i got home the washer had run the cycle but was smoking excessively and squeaks when spinning. sgould i contine to use it?
  • 129 Answers
SOUNDS LIKE SHE SPUN THE BELT UNPLUG ELECTRIC , EMPTY WASHER, TIP BACKWARD CHECK UNDERNEATH BELT, IDLER, PULLY AND BRAKE PADS . SEE IF DAMAGED MAY NEW NEW BELT
Posted on Feb 04, 2010
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Stopped on the rinse cycle an give the 5 ud message.
The Sud (5ud) error code indicates a suds lock. This is normally caused by excessive detergent causing too much suds. It can also be caused by not using HE (High Efficiency) detergent. Overloading the washer can also cause this problem. Try running a cycle with no clothes and no detergent added. See if suds emerge in the washer even though no detergent was added.
Nov 21, 2010 | Washing Machines
My daughter in put a load of wet clothes (not completely finished spin cycle). Now dryer doesn't heat the clothes but seems to have all other functions.
Try running the dryer empty to see if the elements are heating. With the weight of wet clothes it is possible to trip the overloads.
Jan 03, 2010 | Dryers
My kenmore elite front load washer displays sud and does not drain
This display may be set because excessive detergent was used, the drain pump filter may need cleaning, or there may be a defective drain pump. You may also have overloaded the machine with excess clothes. If the machine is full of suds, run a Rinse/Spin cycle, then a Normal cycle without any detergent. Hope this helps!
Dec 15, 2009 | Cars & Trucks
I have a maytag washier and it is working but it makes a lot of noise -it sounds like jam Model number is MAV2755AWW Serial number is 27422854JT
Your Maytag washer may vibrate or make some noise during normal operation. If vibration and noise are excessive, however, you'll need to troubleshoot the problem. The two main reasons for such an issue are overloading and nonlevel installation. Overloading can be corrected by putting less clothing into the washer before you run a cycle. It can be corrected mid-cycle by removing clothing articles from the washer mid-cycle. It's also very important that you make sure that your washer is located on a firm, completely level surface. Otherwise it may create severe vibration and noise, possibly even enough to damage the machine or nearby items.
Sep 01, 2009 | Maytag Washing Machines
Spin cycle doesn't work
the motor coupling is bad it is between the motor and transmission
Jul 09, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore Elite H3E Washer Drain/Spin Problem
hi
it is the belt problem
check it///thank u
please rate it
Jul 04, 2009 | Washing Machines
The spin cycle for my
Dear shelldon39, Fri 2-20-2009 9:24pm EST (USA)
Some machines will shut down during the spin cycle as a precaution to prevent damage!
They will do this if you overload the washer with clothes and/or use too much detergent!
If this doesn't help please get back to me with more details!
jack
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer isn't properly draining in normal wash cycle and start/pause button has to be pushed to restart washer 2-3 times to finish cycle. When cycle finally finishes, a 'drain cycle' has to be run to remove...
remove bottom cover ckd pump for possible restriction..most have acess port on front if not remove hoses also pump impeller may be slipping on shaft or have broken fins
Jul 29, 2008 | GE Washing Machines
Smoking washer Amana NAV8800AWW
Ok, that's a different scenario. Generally, when a washer is agitating and develops an overload that stalls or overheats the motor, the problem could be caused by:
1. Too many clothes for the amount of water level selected. If clothes don't have enough water to circulate in properly, it can put excess pressure on the agitator which transfers to the gearcase, drive belt, and finally the motor. The motor is thermally protected and stops running until it cools down, then it will try to restart. In the process the drive belt could burn slightly to completely,so you may want to inspect the drive belt for burned areas.
2. Transmission malfunction, where something inside the transmission breaks due to an overload and jams a gear. End results can be the same as above.
I suspect a clothes overload may have caused the problem and once the overload is alleviated, the washer should operate normlly if the belt didn't burn,
May 27, 2008 | Amana NAV8800E Top Load Washer
Washing Machines Logo
241 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
