Question about Dishwashers
My kenmore dishwasher# 1675590 is not working, water is not draining and i dot hear the cicle kick in.
  • 129 Answers
Could need cleaning or control clean unit first and drain and hose
Posted on Feb 04, 2010
My dishwasher is not draining
ists not draining.. meaning you dont hear the drain pump kick in? or if you do hear pump kick in, have you checked the hose to the drain..? it could be blocked with a build up of food over the use of dishwasher.
that happened to mine last month. it would fill, but seemd not to drain.. until i disassembled the dishwasher drain from the sink connection and saw at sink connection it wss blocked.. its an easy fix.. unscrew the clamp on drain hose and pull apart and push food back into the drain to wash it away.. good luck !!
Sep 27, 2014 | Kenmore Dishwasher With Ultra Wash And...
Kenmore Elite dishwasher will not drain
If the drain pump won't run, the most common cause is something hard (like a piece of glass or hard plastic) got into the pump and is blocking the impeller. If you want to fix it yourself, first unpug the dishwasher. Then you will need to either siphon the water out of the sump area or use a wet vac to suck out the water from the sump area. Then remove the toe-kick panel so you can get to the underside of the dishwasher. Depending on the model, you may be able to access the drain pump from there, or you may have to pull the dishwasher out. Then you can remove the end of the drain hose and check the area there. If that's okay, you can remove the drain pump by finding and pressing on the release button or lever, and turning it 1/8 turn counter-clockwise, If there's an obstruction, you will find it now. If no obstruction, then you probably have a bad drain pump and will need to replace it.
Jan 07, 2013 | Kenmore 24 in. 17482 / 17484 / 17489...
Maytag mah8700aww clothes wet after cicle
You might need to replace the drain pump. Make sure to listen if you hear the pump kicking in
Jul 25, 2012 | Maytag Washing Machines
My Kenmore Ultrawash II model # 1675590 is not running water or spinning anymore... I can hear the buzzing of the motor but there is no water flow or the normal cycle spinning. I checked the bottom for...
It is possible that the solenoid to the inlet valve is bad, the valve is plugged or the control is not sending voltage to the valve, you need a voltmeter to check the valve.
Aug 19, 2017 | Kenmore Dishwashers
KENMORE ELITE SMART WASH QUIET PAK 4 FRONT LOADER,
Now this is a drain issue from the pump, clean out or check drain hose position to make sure hose isnt in water. Front loader right? kick panel under door has two screws, 1/4 or Torx T20 will remove them. You will see a clean out screw handle that holds junk. Use a trash bag wrapped around the clean out to catch water and debris..
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
Trouble shooting kenmore dishwasher
I have a kenmore ultra wash II Model #1675590 Serial # FC1024731
Will not run and water is standing in the bottom. I have checked the electrical breaker and tried different cycles. Can you help.
Oct 03, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
My dishwasher want run any cicles
check the out flow tube and see if its blocked..... if its not see if the food grinder in the bottom is blocked
May 28, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
Dishwashers Logo
132 people viewed this question
Top Dishwashers Experts
