Question about Watches
How do you change the band size? - Watches
    President:
  • 2,501 Answers
Band sizes can be reduced by taking out sections. This is done by using a narrow tool to drive the jointing pins out.
You need specially small probes to do this and unless you have one, it is best to take it to a watch shop to do it for you.
Posted on Feb 05, 2010
How do you remove JARAGAR watch links?
Most likely it is going to be with a needle press... available on both eBay & AMAZON... but unless you are planning on having a lot of wrist size changes... or a large collection of HIGH END watches...
You would be better off to take it to a serious jeweler
Carnac the Magnificent
Invicta Watch Sizing Tool
Professional model (best chance of scratch/marring ur band)
Zacro Watch Band Strap Link Pin Remover Repair Tool Kit for Watchmakers...
Feb 28, 2013 | Watches
I need new band
If you need a new band for RADO watch, you can pop in any watch shop and choose whichever band you like. The only thing you have to remember is; get the right size. Right size for you watch is the size between lugs in millimetres. Lugs are the things where the band gets attached to the watch. Measure that distance - this is the size of band you are looking for.If you are after original Rado band, then you will have to pop into your nearest Rado dealer shop and order it. The real thing will be far more costly.
Mar 01, 2011 | Rado Diastar Classic 300M R12639023 Watch...
Need to change size of timex expansion band
Take the watch to your local Jeweler that you trust. They have the proper equipment to do the job effeciently and quickly. The jeweler may not even charge you to just downsize the band. Make sure you keep the extra links. If you have to have extra links added, that will cost a little more. Done properly, without damaging/scratching the band, or watch...will be worth the expense.
Thanks, Bill
Sep 03, 2010 | Timex Indiglo Expansion Watch
Pins keep popping out when watch band gets snagged. What size are the pins for watch band?
mcdevito75 here, These pins may be a bit worn in the band of your watch, if so, you"d have to order a kit with various size pins for replacement. BEST BET, look for a small watch repair shop to fit new pins in the band.
Jul 12, 2010 | Timex Ironman 30 Lap 53952 Wrist Watch
What size band do i need for a kirium watch (rubber)
Distance between lugs (the place where the band gets attached to the watch) is the size of band. Get ruler and measure it. Rate me plz.
Mar 03, 2010 | Tag Heuer Kirium (CL1212.BA0705)...
How do i change watchband for casio bg169wh
Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • Jun 20, 2009 | Casio BabyG BG169WH3V (Size: ) Watch for...
    Changing a Rolex metal watchband to a leather watchband
    Put the watch face down and examine the point where the band is connected to the watch case. you will find two holes and through them you will see sprinbar ends insertyed into watch case lugs. Take the tiny screwdriver and push the springbar end inwards,then do the same at the other lug reaching them through those holes.
    Then repeat the same at the other end of the band.
    Measure the distance between watch case lugs- this will be exact size for your new leather band.
    Rate me, plesae.
    Mar 23, 2009 | Rolex Daytona 116528 Wrist Watch
    Need a watch band for model 746 timex digital watch
    I would suggest going to walmart or a jewelry store. Walmart has lots of different styles, materials, and sizes of watch bands. They will usually put the band on and fit it to your wrist size.
    Aug 30, 2008 | Timex Watches
    Watches Logo
    115 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
