Question about Goodman GMS80903BNA Heater
Gooman heater connected to electronic lux 500 thermostat. no response from heater at all. tried changing batteries in thermostat.could thermostat possibly be bad. had both for approx.11 years
  • 118 Answers
Remove t-stat and remove red and white wires and connect them, if unit starts then it was the t-stat.
If not go to furnace and remove same two wires at furnace and jump out at circuit board or connect wires FROM furnace, if it starts the problem is in wires.
If you have power to furnace?? and nothing happens it is either a bad board or inducer motor (little one) is not starting. Remember that their is a fuse on corcuit boards that need to be checked.
Posted on Feb 04, 2010
I have two wires coming from my old thermostat (1 black and 1 white), where do I connect these to on my new digital thermostat?
There are way too many types/brands/models of equipment for anyone to answer that question. Pictures and information on your old thermostat, new thermostat and the heater or ac unit it is controlling are going to be a ton of help.
Jan 24, 2016 | Lux Tx500 Series Smart Temp Electronic...
Tip
Lux Thermostat 500
The Lux 500 Thermostat is an affordable programmable thermostat that gives you a very easy way to customize your heating and cooling temperatures to your schedule. The programming of this thermostat is easily the simplest that I have found in a programmable t-stat.
The Lux 500 series thermostats are a great economical way to reduce energy and utility expenses by raising or lowering your temperature settings a the times you set. The installation is so easy that most any DIY’er can install this thermostat. It has an easy to read display and the rotary dial makes the programming very user friendly.
A few of the other great features of this unit are, a keyboard lockout, and an air filter reminder.
This thermostat can be used on any 24v AC or 750mV single stage conventional heating/cooling system. Single stage heat pumps without auxiliary heat will also work with this thermostat.
Here is a summary of the features of this thermostat
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  • 5 - 2 Day programming
  • 4 Periods per day
  • Large easy-to-read display
  • LUX patented user-friendly Speed Dial®
  • Filter usage monitor and alert
  • Default Energy Star approved program
  • Temporary Temperature Override
  • Temperature Hold
  • Keyboard Lockout
  • Temperature Calibration
  • Swing Settings #1 - #9
  • Fahrenheit or Celsius temperature Scale
  • 12/24 Time Format
  • Low Battery Warning Indicator
  • Mercury Free
As you can see this thermostat will give you a lot of great features at an affordable price.
on Jan 16, 2010 | Heating & Cooling
Display all 888s
All you can do is remove batteries for 5 minutes or so , then try again.
Feb 18, 2014 | Lux Tx9100e 7 Day Universal Programmable...
Lux TX500e thermostat
go to honeywell it,s a house hole name
Nov 07, 2013 | Lux Tx500 Series Smart Temp Electronic...
Power surge and thermostat has nothing on screen
Check battery's , & try inturepting power for 5 to 10 min,if no response
change ,24 volt transformer or control .
Feb 25, 2013 | Lux Thermostats DMH110 Digital Heating and...
Snowflake symbol on thermostat
Copy following link for Lux product manuals
http://www.luxproducts.com/instructionmanuals.php
It might mean that AA batteries needs to be changed.
Or it might mean 2nd stage heating cycle.
Air filter needs to be changed.
Tech assistance 856-234-8803
Oct 26, 2012 | LuxPro PSP711TS Touch Screen Programmable...
Changed to lux9100e thermostat and get reversed polarity message on bryant furnace
I think it means that you need to reverse the wires to their respective connections on the thermostat..
Sep 24, 2012 | Lux Tx9100e 7 Day Universal Programmable...
I recently installed a Honeywell RTH6350D to replace a 2 year old LUX and can get everything to work but the heat(reason for replacing the LUX). Works sometimes but not consistantly. Have the common red(R)...
R represents power supply for the heat system.
RC represents power supply for cooling system.
G represents fan (neutral).
W represents heat system.
Y represents cooling system.
Y2 represents 2nd stage cooling.
W2 represents 2nd stage heating.
AUX represents heat pump.
Try calling 1-800-468-1502.
Their english is "REALLY BAD"!!!
Jan 02, 2011 | Honeywell Electronic Programmable...
Can't change temp setting. no response from soft touch buttons for warmer/cooler temp. changed batteries but no difference.
if the stat is in auto changeover from heat to cool you might need to lower the heat temperature setting before you can lower the cooling setting, these need to be 2 to 3 degrees apart and the stat will not let you over lap them.
Aug 15, 2009 | Honeywell CT3200 5-2 Day Electronic...
My furnace wont start from the thermomstat.i have to push in start button on the panel to kick on.. i have my temp set at 70.. i changed the batteries on thermostat.. but every other day i have to go down...
I would say that the thermostat needs replaced! (this is the most common problem with the honeywell brand!
Please rate my response to your question!
THANK YOU!
Jan 13, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
152 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
