Question about Drills
Charger died. i have a icon cordless drill IC18V2K who's charger just died. there were only 2 resistors,led and diode on the circuit panel.all but the larger resistor survived the ordeal of smoking up.i need to replace the larger resistor but the heat has distorted the colour code.any ideas of getting a schematic for this? input voltage is 24 volts dc and the output going to the battery is unknown to charge 18 volt nicad's.
  • 12,061 Answers
It is usually a current limiting resistor anyway... so I would think that about 100 Ohms should be all good, you generally need about 250 - 300mA to charge ya batteries. It is simple Ohms law calculation.
Posted on Feb 04, 2010
Why does ryobi 18V cordless not charge
Please check the LED status of your charger. If both of the charger'sLED flashing, but it can charge a good battery. Than the battery is defective, you may replace a new Ryobi P206 Battery http://www.batteryshops.co.uk/tags_products/ryobi-p206-12-18v-2-speed-drill-driver-battery_6854.html
May 11, 2014 | Ryobi 18v Cordless Drill - P206 18 Volt V
Has anyone else had problems with the BOSCH "BC004" Battery Charger???
The problem is resistor R3 on the circuit board.
Since there is 310 Volts (!) across this resistor, I would highly recommend taking it to a TV repair shop for repair unless you know exactly what you are doing and have the skills for repairing a PC board. Take this email with you when you go there.
Be sure !!! to discharge the two large capacitors with a 10K resistor before attempting this repair - for days they will retain 165 Volts each across them after the power plug is pulled.
The repair is easy - simply replace the resistor R3 with two 130K metal film 1/2Watt resistors in series. The existing resistor is marginally power rated and there is too much potential difference across it for safety. Make sure the two replacement resistors are enclosed in a heat-shrink tube before soldering onto the board.
May 18, 2012 | Bosch 13618 - 2G 18V Brute Tough Cordless...
I have a B&D Firestorm 18v 1-hour battery charger, model 5100235-09 (240v). When I insert a battery to charge, only the green "battery full" LED lights immediately. But the battery never...
Hi I have same problem with the charger. Solution is to replace the charge with new part number issued from B&D Australia
Number of 90515050-01 until stock runs out , then it is replaced by part number of 90578873 early to mid june 2013.
Hope this helps
Lance from Perth , Western Australia.
Jun 19, 2011 | Black & Decker Drills
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
May 14, 2010 | Black & Decker 18V Cordless Drill/Driver
Where can I obtain a circuit board for a bosch cordless drill charger, Charger is AL 2404, part number 2 607 255 185, also has D-70745 Leinfelden printed on charger
most tool manufacturers don't offer the circuit boards as a separate saleable part. I can't find anything at the Bosch website.
Jan 13, 2010 | Bosch Drills
Charger not powering up, fuse is good?? what the f---?
Internal board fuse checked? This may/may not help?
Makita 1850 battery charger FIX. A friend asked me to check his charger unit which had failed after it had been connected to a portable petrol generator that incorrectly generated 317 Volts AC and not the usual 240 Volt AC. On the charger circuit board next to the transformer wire connection is a component marked F2; this is a 2.5Amp fuse covered with heat-shrink sleeving. This fuse had ruptured/blown. Also blown was Transistor Q1, a ''P'' Mosfet labelled IRF9Z24N and Schottky Diode D9 labelled SR560. Replacing these 3 items got the charger working again. NB Resistor R31 is only 0.1ohm - don't assume it's gone short circuit! NB. I'd presume that most other Makita chargers will have this heat-shrink sleeving ''camoflaged'' fuse on the input of the circuit board and it would definitely be worth checking if the charger has stopped working. Regards Roy
Oct 24, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Battery charger shuts off when you put in a battery to be charged,reset wont work,unit is getting warm-a Short ?
I have this problem with my black and decker when I tested the leads in the charger they have power, I tried 3 different batteries. I took the charger apart and plugged in the battery, this is when I noticed the 10v + power that I was getting when testing just the charger turned off when the battery was installed, so instead of reading 10v from the charger I was only reading 4v of the dying battery. I removed some covering only to find the resistor burnt black, and the led light with black in it. I am guessing that I could replace the resistor and light if I could tell what kind they were.
Jul 21, 2009 | Makita Drills
Charger no light and wont charge
Sorry to give you my opinion, but these chargers are very delicate, I have 4 and can barely keep 2 going. My recommendation? Open it up and look for obvious shorts/loose wires, if no luck then buy another one and return the busted one as if it were the new one. You will end up with two working chargers. PS this is probably fraud...ha!
Matt Giantglobes.com
Mar 10, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Fixing a cordless drill battery charger
usually transistors have three legs, diodes have two arms all very confusing isn't it? resistors have two arms as well but not three legs or only two legs and no arms its all about arms and legs isn't it do not attempt this repair if you live at home
Oct 18, 2008 | Drills
Drills Logo
183 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
