Question about Hotpoint Washing Machines
How do i lift the top of the washing machine up to get at stuff that got caught during a spin cycle?
  • 129 Answers
Ther are 2 push clip under top panel 1 on each corner push clip in pull front panel outward 1 side at a time pull forward and lift up and off
Posted on Feb 04, 2010
Washing machine makes clunking noises during spin cycle. Like metal is caught somewhere.
Good one!! Next time you will be careful not to fill up the drain pump.
Jun 23, 2012 | Maytag Washing Machines
Why has my front loading washing machine started to rattle, knock and squeak during the spin cycle
If the drum is loose and you can feel loose play when you lift the lip of the inner drum, you probably have bearing problems and/or a broken arm on the rear of the inner drum. However a coin caught between the inner and outer drums isn't good news either. Find a tech to diagnose and explain...Good luck.....Nomess
Apr 20, 2010 | Whirlpool Washing Machines
Washing machine spin cycle not working properly
Its the belt. Easy fix. Lift the top by sticking a screwdriver into the gap between the front panel and top panel. There are two "tabs" you need to push in while lifting the top front up. Then raise the front up a bit off the ground with blocks to take out the two phillips screws near the bottom (front). Then slide the front panel down. The belt is on the bottom. simple to remove from below the pully. not sure the belt type to replace with.
Feb 21, 2010 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Nov 11, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Agitator Not Working
check your motor coupler, lid switch
Nov 08, 2006 | Hotpoint VBXR1090D Top Load Washer
Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Oct 19, 2006 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
