Question about Welding Tools
A diagram for grabbing service from 60 amps fuse box. It has two black, one red on fused leg and one white on unfused bolt block. Where do I tie in wiring for power outlet recep. to service 220 volt single phase welder.
  • fblackmon Feb 04, 2010
    I will have to see, but it appear to be. Thank you.
  • 43,501 Answers
Sounds like you have a thre phase service...being that you have two black and one red you have a 240/120 delta service. this means that you can get 240 across either of the black wires and the red wire. So you just have to pick which black you want to hook to and then hook the other wire to the receptacle to the red wire, The third wire just needs to get grounded either on the white or the green/bare wire in your servoce.
Heatman101
Posted on Feb 04, 2010
Hi, I opened a junction box that operates 3 lights,from 3 diferant swicthes, there are red, white &blk plus ground i need to tap off of that & instal a gfi & vanity light w/s witch can you tell...
You need to find the hot leg and the nuetral leg . Hot is black and neutral is white . You need to make sure you have 120 volts between these wires cause some of the blacks could be switch leggs for the lights you talked about . Tie your recep. To those wht to wht and blk to blk .
Jan 24, 2012 | Hampton Bay 44 In. Bistro, Copper Kitchen...
How do I know if my stove is three fase. I am in Brazil and the here power is 220v. Would you help please?
Your oven is 2 phase 220 volt not sure about foreign electrical service.The stove requires 2 phase electric service,each leg impute can be no more than 135 volts.It requires 2 pole 60 amp service with no less than a 8 gauge 3 wire service line with ground.The pigtail on the stove is as follows,black wire 120 volt leg red wire the other 120 volt leg the white wire is the neutral leg,(which is sometimes run to the ground block which incorrect but will work) the green wire is ground.
Jun 13, 2011 | Whirlpool Stove Oven Sensor 8053344
JTP56 Electric Double Oven Dead after self-clean. Power Pigtail comes into back of top control enclosure in flex conduit. The three red,black,white conductors are spliced to 2 molex connectors. I am...
I doubt there is a fuse on the pigtail, it sounds like your black wire is grounded somewhere. Check black to red, if you get 120 or close to it, your black is shorted to ground.
Jun 07, 2011 | GE Profile JTP56 Electric Double Oven
What are the color codes for a factory stereo system in a 2006 Nissan alttima
use at your own risk. I can not confirm these.
+12V DC Battery(Constant) Yellow/green 31 15 Amp Fuse box on left front of engine compartment, near battery. Switched Accessory Purple 6 10 Amp Fuse block behind left side of dash Power Antenna NCA Green for antenna signal Illumination Red/yellow & red/blue Steering Wheel Control Wire Red/white, green, and blue If equipped, as for Mid-Line. Left Front + Blue/white Left Front - Blue/red Right Front + White/black Right Front - Blue/black Left Rear + Green/yellow Left Rear - Black/yellow Right Rear + Blue Right Rear - Red
titleicon.gif AT SPEAKERS
Wire Function Color Note Left Front Tweeter + Blue/white Left Front Tweeter - Blue/red Right Front Tweeter + White/black Right Front Tweeter - Blue/black
Feb 20, 2011 | 2006 Nissan Altima
02 altima wiring for all three harnesses
12V'green '+ 'ignition harness '
' STARTER'black/red '+ 'ignition harness '
' SECOND STARTER'black/yellow '+ 'ignition harness '
' IGNITION'black/red '+ 'ignition harness '
' ACCESSORY'red '+ 'ignition harness '
' SECOND ACCESSORY'white/blue '+ 'ignition harness '
' POWER LOCK'pink *7 '- 'pin 37 @ BCM by fuse box '
' POWER UNLOCK'brown *7 '- 'pin 44 @ BCM by fuse box '
' LOCK MOTOR'yellow/red ' 'pin 30 @ BCM by fuse box '
' UNLOCK MOTOR'green/white ' 'pin 23 @ BCM by fuse box '
' DISARM DEFEAT'green/red ' 'pin 31 @ BCM by fuse box '
' PARKING LIGHTS +'red/blue ' 'driver kick panel '
' HEADLIGHTS'blu (L), red/yel (R)'+ 'IPDM E/R *1 '
' DOOR TRIGGER'*2 '- 'BCM to right of fuse box '
' DOME SUPERVISION'comes on with unlock' ' '
' TRUNK/HATCH PIN'purple/white '- 'pin 18 @ BCM by fuse box '
' HOOD PIN'yellow/black '- 'hood pin switch '
'TRNK/HTCH RELEASE'red/blk or blu/red '- 'pin 76 @ BCM by fuse box '
' FCTRY ALARM ARM'pink/blue *3 '- 'driver switch in door '
'FCTRY ALRM DISARM'white/blue *3 '- 'driver switch in door '
' TACHOMETER'white/green ' 'ECM behind glove box *4 '
' SPEED SENSE'blue/yellow *5 '8 'pin 9 @ instrument cluster '
' BRAKE WIRE'red/green '+ 'brake pedal switch '
' HORN TRIGGER'green/white '- 'steering column '
' WIPERS'blu (L), blu/blk (H)'- 'wiper motor '
' LF WINDOW UP/DN'blu/red - blu/wht 'A 'driver window switch '
' RF WINDOW UP/DN'green - yellow *6 'A 'driver kick panel '
' LR WINDOW UP/DN'purple - blue 'A 'driver kick panel '
' RR WINDOW UP/DN'red/yel - yel/blk 'A 'driver kick panel '
' SUN RF OPN/CLOSE'not recommended ' ' '
' RADIO 12V'yellow/green '+ 'radio '
' RADIO GROUND' ' ' '
' RADIO SWITCH'purple '+ 'radio '
' RADIO ILLUMINATE'red/blue '+ 'radio '
' POWER ANTENNA'green '+ 'radio '
' LF SPEAKER'blu/wht - blu/red ' 'radio or amp under rear deck'
' RF SPEAKER'wht/blk - blu/blk ' 'radio or amp under rear deck'
' LR SPEAKER'grn/yel - blk/yel ' 'radio or amp under rear deck'
' RR SPEAKER'blue - red ' 'radio or amp under rear deck'
here is a wire diagram for the altima .you should be able to just buy a radio harness to attach to the factory harness with diagram of wires on back and find out what color are what on your factory wires
623.10482.150x100.nn03b.jpg 02 harness for your car from scosche
http://www.tintingbyfredjohnson.com
Dec 31, 2010 | Car Audio & Video
Hi, I have the Cutler Hammer fusible ac disconnect 30 amp, my question is with the 10-3 wire from the fuse panel to the pullout do you only use the Black White and Ground and lay back the Red? Also, can...
If you use a white wire to carry a 120 Volt line it would have to be taped with either black or red tape both at the breaker box and your fuseable disconnect so the solution is to use the black and the red wire into your curcut breaker, the white and the bare ground both tie into the grounding post at the circut box and at the fuseable cut off, Yes the fuses are neccisary per code.. to eliminate a short or fault from traveling all the way back to the breaker box.. often times found inside the building the fusible pullout is attached to. check your local codes and regulations for more specific details.
Aug 09, 2010 | Cutler Hammer Fusible AC Disconnect Switch...
Wire color scheme for alternator plug.
ok ric , now the tensioner , notice a 15mm bolt head on the tensioner pulley , put a wrench on that 15mm head and turn clockwise , that will unload the tensioner , install your belt according to the belt wrap picture under the hood , release tensioner , and you should be good to go . however ,,,,,
last thing , there are like 5 fuses involved in this circuit , 1.) a 120 amp fuse in the fuse block , left side of engine compartment , 2.) a 60 amp fuse in the same place as #1 , 3.) a 7.5 amp fuse in the relay box - left side of engine compartment , 4.) a 7.5 amp in the left side of dash fuse panel , and 5.) another 7.5 amp fuse in the same panel as #4 . sure is a very well protected circuit ..
good job
J5
Jan 18, 2009 | 1992 Lexus Sc 300
Altenator is not charging the battery
sir , the altenator has 3 wires at the connector correct ? a white/red , a green/white and a black , the white/red wire is involved with a 10 amp fuse to do with the charging meter / gauge , the fuse located behind left side of dash .. the green/white wire is is involved with 2 fuses , a 10 amp ECU fuse and a 25 amp Main fuse located at left rear of engine compartment main box , and the black wire is involved with a main 80 amp fuse at the main box also . both of these 2 wires end up at the positive side of the battery , please verify all these fuses are good . if they are indeed good , then open wiring would be next step verify continuity on black and the white/green wires . i would post a link to diagram but autozone repair info site is down at this time . if ya need more help , please ask .
Jan 05, 2009 | 2002 Kia Rio
Fuse blew replaced it and dryer won't work.
did you replace both fuses? there are 2 thirty amp fuses both are needed . if you can check voltage to the outlet that will eliminate an electrical problem and narrow it down to the dryer. If you have voltage to the dryer outlet, then I would look at the connections at the terminal block(where the cord connects to the dryer) then a meter would be needed to do much more testing.
Nov 03, 2008 | Whirlpool LER4634J Electric Dryer
Welding Tools Logo
42 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
