Question about KitchenAid Dishwashers
Dishwasher makes a horrible sound for the 1st 30 minutes; can't find any kinks or clogs...help
  • 129 Answers
Your have something in the chopper needs cleaning
Posted on Feb 04, 2010
Dishwasher won't drain when cycle is complete. Not even when press on the Cancel/Drain button. Engine starts working (at least sounds like something is going on) but not water goes out to the sink...
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Dishwashers
The second led is flashing. Water did nit drain at first. Then drained. Cannot press the start/reset button, nothing happens. Sounds like the pump was working, now doesn't seem to be. Help!!!
Hi
Daniel
Aug 27, 2011 | Dishwashers
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwasher will not drain. Can hear it making a sound but water will not empty. Tried some liquid plumer but that does not seem to be working. When we try to drain there is a funny sound.
Hi
This draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 13, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My LG dishwasher is stopping after a few minutes into the wash cycle with an error message OE and making a sound. The dishwasher tablet is still inside the dispenser and while there is water in the unit it...
Hi rebeccasolom,
OE means "Outlet Error"
The drain pump is either clogged or the outlet hose is kinked.
- Inspect the Drainage hose at the back for kinks.
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it.
Kind Regards :-)
If you found this solution helpful, please rate it.
May 25, 2011 | LG 24 in. LD-12BW5 Free-standing...
Our Dishwasher puts out the error code f12 when you run it how do I fix this
water intake fault at start of step, check tap turned on & inlet hose not kinked, does the box at the tap buzz within the 1st couple of minutes after starting?
Apr 16, 2010 | Miele Premier-Plus Built-in Dishwasher
I have a Miele Inspira line dishwasher and it is making a horrible sounds when I turn it on - like the water is not getting through easily
Hi If noise starts within one minute of start of program then you most likely have debris in drain pump. Under filter you will find non return valve remove valve this will expose drain pump impeller. with non return valve removed run program for 30 seconds refit valve and test. More in depth instructions available in user handbook.
Apr 11, 2010 | Miele Inspira Series Dishwasher w/ 6...
DIshwasher drain clogged Haier dishwasher model DW12-PFE2-E
Remove the drain hose from the sink drain assembly and force air into the hose--The clog should spit out into the washer cabinet. Make sure the drain hose doesn't have any kinks or sharp bends. Hope this helps.
Nov 21, 2009 | Dishwashers
Ie error code
The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound
Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
Sep 20, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
46 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
