Question about Bell Lands Phones
I have an old dial phone and am looking for a wiring diagram
  • Bell Master
  • 2,460 Answers
Type 500 sets are pretty universal. Try this one http://www.public.carl.airpost.net/Phones/sc500.pdf
Carl
Posted on Feb 04, 2010
My phone says "Line in use" but nobody is using it.
Some of my telephones will read "Line In Use" when the phone doesn't detect a dial tone. I like to use an old wired telephone to check whether the problem is with the cordless phone base or the phone line wiring.
First plug in the test phone and check for a dial tone. If there is no dial tone, try a different RJ-11 cable between the phone and the jack. If there is still no dial tone, use the test phone at another jack and check for a dial tone. If you have two jacks with no dial tone, find your incoming telephone service box. If you have a relatively new phone service installation, the service box will have RJ-11 jacks. Plug your test phone into the jack and check for a dial tone. If there is still no dial tone, contact your telephone company. They will repair an outside wiring problem for free. If the service box doesn't have an RJ-11 jack, you'll need to ask your telephone company to test the phone line for you.
If there is a dial tone at another jack or at the service box, you have an inside wiring problem. You can check for loose or broken wires inside of the jack. Most use either screw terminals or a punch-down design. For the screw terminals, strip another section of the unbroken part of the wire, if needed. Secure the wire under the screw. For the punch-down terminal, take off the cover. Then you'll need a tool that is available in most hardware stores in the electrical wiring section. Do not strip the wire; just place it over the correct place in the terminal and push it into the contacts with the tool. Trim off any excess wire with a small pair of small wire cutting pliers, if the excess wire is blocking the cover from fitting back onto the terminal. http://www.lanshack.com/wire_phone_jack.aspx has a good diagram of the wire color and pin assignments. If the wiring is okay at the jack, you'll need to check the rest of the wiring for problems. Since the broken wire might be inside the wall, you may want to have a professional check it out. Your telephone provider's technicians can do this for a fee. If you have a DSL computer line, you should check the DSL filter. If the filter is inside at the jack, you'll need to replace the filter. If it is out at the service box, your telephone company will do the replacement.
If there is a dial tone at the jack with the test phone, check the purchase date on the L401 system. If it is under warranty (1 year usually), contact Motorola. Otherwise, replace your Motorola phone system. It's generally not worth the minimum repair and shipping costs.
I hope this helps.
(I've had dial tone issues after lightning strikes (the DSL filter was damaged), mice eating wires (buried phone line) and due to county road crew/contractors who dug too close to the wire. The first two problems required phone calls to get a technician to fix the outside line. The last one gets fixed by the contractors/phone company as soon as they can.)
Nov 09, 2015 | Motorola L401 DECT 6.0 Digital Cordless...
Why does my panasonic cordless home phone have the error message "check tell line?"
I like to use an old corded phone to diagnose telephone line problems. First though, try a new telephone cord between the base and the phone jack. (This can be obvious to some but I once saw a person swap a handset cord (the coiled cord) and an RJ-11 cable.)
Next plug a different phone into the jack. If it gets a dial tone, the KXTGA470B needs service. (If it is out of warranty, it may be better to replace it.) If the second phone does not get a dial tone, try the spare phone at a different jack if there is one. If the phone gets a dial tone at this jack, your wiring to the jack or inside it is faulty. I'd check the jack first, unscrew the faceplate and look at the back of the unit. There are two types of jacks. One has all of the conductor wires connect to screw terminals. If any wire is broken, strip the shielding from a bit more of the wire. Then wrap the wire under the appropriate screw. The other type of jack is a keystone. If a wire is loose, you'll need a punch-down tool (available at many hardware stores in the wiring section). Do not strip the wire, just press a new section into the correct point on the keystone. See http://www.lanshack.com/wire_phone_jack.aspx for the pin assignments.
If there isn't another phone line jack or there is no dial tone at another jack, find where your telephone service comes in. Open the box and look inside. If you are lucky, the service will have an RJ-11 connection. Plug in your test phone and check for dial tone. If there is still no dial tone, call your phone company and tell them to fix it. (I've had mice chew wires in underground service.) It will be a free repair. If there is a dial tone here, you've confirmed an inside wiring issue. One thing to check while you are at the box: since you have multiple jacks, check that all of the wires connect to the box. We had our service upgraded and they forgot to wire one jack to the new service box. (It was obvious when we went to the box; the wire was just floating behind the house's vinyl siding.)
Next consider your service type, if you have DSL with your phone service, check the filter. Some phone companies have these inside the home and you are responsible for it. Lightning strikes nearby can damage them and interrupt the phone line. Otherwise, since you didn't see any breaks in the wires when you inspected them, you may want a professional to check the wiring. It's possible to have one broken conductor within the shielding. (One way to test this is to swap the wires at the service box and the jack. Most RJ-11 lines are 4 or 6 wires. Two wires are needed for each line. Use the diagram I linked to above and physically connect the R2 and T2 lines to the R1 pins.) Some telephone companies will do indoor repairs for a fee.
If the service box doesn't have an RJ-11 connection or you have an outside DSL filter, ask them to send someone out to physically check the service. (Just because their computer says it is up, doesn't mean it is. I've seen it happen.)
I hope this helps.
(My preferred test phone is an old rotary unit. It never fails unlike some newer phones.)
Aug 01, 2014 | Panasonic KXTGA470B KX-TGA470B KX TGA470B...
I need the wiring diagram for Pioneer Music System MS-Z64
You would need to contact Pioneer directly, in Long Beach, CA, to obtain a service manual. I would suggest you hurry, as Pioneer has recently sold off the home audio side of the company.
Feb 06, 2014 | Pioneer Audio Players & Recorders
Lost phone manual, uniden d2997
I have a standard trouble-shooting routine for cordless phones. 1) Remove the battery from the handset (from all handsets for a multi-handset version). Then unplug the power cord from the base and wall outlet and also remove the telephone cord. Wait a few minutes and then reconnect the power and phone line cords. Reconnect the battery (ies) for the handsets. Make sure this connection is tight. Then make sure that the battery is fully charged (15 hours before first use) and register the handsets if needed. This is done by putting each handset onto the base in order for the D2997. Wait about 30 seconds for each one until you see the Handset Registered message. Make sure that you are within range of the base.
Next try a different telephone (RJ-11) phone cord between the base and the wall jack. Also check if the power adapter for the base is warm. For the next set of tests, I like to use an old corded telephone. Using a different phone, check if you get dial tone at the jack. If there is a dial tone, then the problem is with the Uniden phone. If the above trouble-shooting didn't help, then contact Uniden. These phones aren't meant to be user serviced.
If you do not have a normal dial tone, try another jack on the same telephone line. If there is dial tone at another jack, then you have a problem with the first jack. Otherwise find where your telephone service comes in. If you have a fairly new service, you'll find an RJ-11 jack. Plug your test phone into the jack and test for dial tone. If you have no dial tone or can't test your line, call your phone company. They will fix any outside problem for free. If it is an inside wiring problem, look at the visible wiring and determine if the wires are damaged. Open the jack (if only one is bad) and check for loose wires. There are two types of jacks. One secures the terminal wires with screws and the other uses a punch-down jack. For the screw type, strip additional insulation from the conductors, if needed, and then reconnect them. For the punch-down type, you will need the punch-down tool. It is available at many hardware stores in the wiring section. Use this diagram to check your jack wiring: http://www.lanshack.com/wire_phone_jack.aspx . If you can't see an obvious problem with the wiring, you may want a professional to deal with the wiring in the wall. Your telephone company will do this for a fee.
Uniden has the manuals for their DECT phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manual for the D2997 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D2997om.pdf .
I hope this helps.
Nov 26, 2011 | Uniden Lands Phones
Every thing works except can,t get incoming calls and out going calls
First check if the phone jack and cable are good. (I like to plug in an old corded phone for this.) If you have a dial tone with the other phone and can make calls, try the new cable on the base of the cordless phone. If the problem persists, then the phone needs service. (Cordless phones are not meant to be user serviced.)
If neither phone has a dial tone at that jack, try another jack. If only the one jack is bad, open it up and check for loose or broken wires. (Most jacks terminate either at screw terminals with stripped wires or keystone jacks that require a special tool to push the wire down. A cheap version of the tool is sold with many keystone jacks and others are available separately at many home improvement stores. Check the aisle for wiring a house.) A RJ-11 wiring diagram is available here: http://www.lanshack.com/wire_phone_jack.aspx .
Find where your phone connection comes in, open that box and check what type of connection is there. If it is a RJ-11 connection, try your phone at that point. (If it isn't RJ-11, you will need the phone company to check the line.) If there is no dial tone at the service connection, the phone company will repair it at their expense. If the problem is inside, check all exposed wires for damage. If the problem is inside a wall, you may need a professional. Your phone company will fix it for a fee.
I hope this helps.
(I've lost telephone service due to mice chewing on underground wiring, lightning damage to a DSL filter and digging crews failing to avoid the wires.)
Feb 21, 2011 | Uniden EXAI 918 Cordless Phone
What do you check when the phone lists a message of "Check TEL Line"? The phone cord in plugged in so I'm not sure where to go from here. I have a model DECT1480
Usually this means that the phone isn't detecting a dial tone. For diagnostic purposes, I like an old corded phone.
First try a new telephone cable between the jack and the phone. Then try the old phone and see if you have a dial tone. If you have a dial tone with the old phone but not the cordless, then the Uniden needs service. These phones are not designed to be fixed by the user. If the phone is under warranty, send it in. (see page 28 of the manual www.uniden.com/pdf/DECT1480-3om.pdf )
If neither phone gets a dial tone, check at another jack if you have several to see if the jack is the problem or if it is a more global problem. If the problem is at one jack, you may want to open the jack and check for a loose wire. Some wall plates hold the wires with screws; others use a keystone jack with the wires pressed into slots using a "punch down tool". Keystone jacks do not need the insulator removed from the individual wires. For the screw connectors, you do need strip the individual wires. The punch down tool is available at many hardware stores in the electrical section (for wiring homes for ethernet and other services).
If you do not have a dial tone at another jack, find where your telephone service comes into your home. Open the panel and identify how the connection is set up. Some use RJ-11 jacks. In that case, plug in your test phone and see if there is a dial tone at that point. If there is no dial tone, contact your phone company for service. There is a break in the wires coming into your home. The phone company will fix this for free. (If the service doesn't use an RJ-11 jack, you need a special adapter to test at this point. Your phone company technicians will have this.)
If there is a dial tone at the incoming service, you have a inside wiring problem. Check any visible phone wiring for damage to the insulation. If the problem is with wiring inside a wall past the jack, you will need a professional to track the break. Your phone company will fix this for a fee.
I hope this helps.
Dec 29, 2010 | Uniden Cordless Phone
We have a no line message, and are not recieving phone calls. How do we fix that?
You need to find out where the fault is. I like an old corded phone for this. Check if a different phone gets a dial tone at the jack and other jacks inside the building. If no dial tone inside, find where the phone service comes in. Open that box and if it has a RJ-11 connection, check if you get dial tone at the junction. (If you have an older service, you will need a special line tester to check the service.) If you have no dial tone at the service box, contact your phone company - there is a problem with the service. (It could be some idiot damaged a wire digging or something else.) If there is a dial tone at the service connection, you need to find the break in your inside wiring. Open up the jacks and check any visible wiring for loose wires or damaged wires. If there is no obvious damage, you will need to look at the hidden wiring (a professional to do the work might be best).
Good luck.
(I've had dead phone lines outside the home from lightning (affected the DSL), an idiot road crew and one unknown malfunction. All of these were promptly fixed by the phone company technician.)
Jun 18, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
I want to install a phone jack where the old phone is direct wired but I don't know how to get the phone apart to disconnect the wires. It is an old black rotary phone that hangs on the wall.
Look for screws on the bottom of the phone. Unscrew them. The top shell cover (excluding the dial) should be pulled up. Loosen the screws that hold the wires attached. To reconnect match wire colors.
Hoe it helps.
Sep 15, 2009 | Bell Lands Phones
Lands Phones Logo
47 people viewed this question
Top Bell Lands Phones Experts
RobertFonner
RobertFonner
 Bob Buchholz
Bob Buchholz
ray gallant
Are you a Bell Lands Phone Expert? Answer questions, earn points and help others
