Question about Cyberhome CH-DVD 300 DVD Player
Cyberhome dvd ch-300 dvd player
Comment by 4z4jt, posted on Feb 13, 2008 Just exactly same problem !!
Constant orange light that turns red or green depending on which button you press. Won't turn on. Pressing "stop" button does not reset unit as suggestions on other fix-it sites.
I took it apart and checked the power supply.11.5 volts and 2.75 volts are supplied to the circuit.
Any idea what the problem is ??
    Scholar:
  • 104 Answers
Not sure, but I believe the 2.75 volts you have should be 5.0 volts.
May want to check capacitors on power supply.
The output connector on the supply may also be labeled with
the correct volatges for reference. COnstant orange light may be
indicating the +5v is low.
Posted on Mar 05, 2008
Need wiring diagram for 1996 Ford Explorer Sport radio,connecting wire colors, the one I have is different than what's on vehicle
Check this diagram for 1996 Ford Explorer Car Stereo Radio Wiring Diagram...
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Hope this helps; remember to rating this free answer and leave some testimonial comment.
Oct 13, 2011 | 1996 Ford Explorer
No function
As most current designs of such devices, you can force a full hard reset on the unit/system by unplugging it from the mains for a couple of hours (or overnight).
Thereafter, pls post back if problem persist and will work form thereon.
Mar 13, 2008 | Cyberhome CH-DVD 300 DVD Player
What is the wiring diagram for the stock radio
Check this...
1998 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Yellow
Radio Switched 12V+ Wire: Yellow/Black
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: N/A
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 5" x 7" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Hope helps (remember to rate and comment this answer).
Feb 16, 2011 | 1998 Ford Taurus
Car stereo wiring color code for f-150 1999
Constant 12V+ Light Green/Pink Switched 12V+ Black/Purple Ground Black/Green Illumination Light Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Gray/Light Blue Left Front (-) Tan/Yellow Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 6" x 8" Rear Corners Left Rear (+) Orange/Light Green Left Rear (-) Light Blue/White Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 21, 2010 | 1999 Ford F150 Regular Cab
What wires go together for the constant on a 94 ford ranger
1995 Ford Ranger Pickup Truck Car Stereo Wiring Diagram Car Radio Battery Constant 12v+ Wire: Green/Purple Car Radio Accessory Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black/Light Green Car Radio Illumination Wire: Light Blue/Red Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: Blue Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 6 1/2′ Car Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Orange/Light Green Right Front Speaker Positive Wire (+): White/Light Green Right Front Speaker Negative Wire (-): Dark Green/Orange Car Audio Rear Speakers Size: 5′ x 7′ Car Audio Rear Speakers Location: Rear Corners Left Rear Speaker Positive Wire (+): Gray/Light Blue Left Rear Speaker Negative Wire (-): Tan/Yellow Right Rear Speaker Positive Wire (+): Orange/Red Right Rear Speaker Negative Wire (-): Brown/Pink
Oct 14, 2009 | Kenwood Audio Players & Recorders
Digital clock
Here is a wiring diagram of the radio by wire color:
Radio Ground Wire: Black/Green
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Blue
Radio Amp Trigger Wire: Blue (Same as Antenna Trigger)
Front Speakers Size and Location: 5′ x 7′ Doors
Rear Speakers SIze and Location: 5′ x 7′ Rear Deck
Aug 14, 2008 | 1988 Ford Mustang
Need wiring diagram for 1997 ranger stereo
1997 Ford Ranger Pickup Truck Car Stereo Wiring Diagram
This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Jul 31, 2008 | 1986 Ford Ranger 2WD
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Car stereo wiring (1993 Ford Taurus GL)
My guess is that ford did not change that much in a year.
1994 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Blue
Radio Amplifier Trigger Wire: N/A
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Pink/Light Green
Left Rear Speaker Wire (-): Dark Blue/Orange
Right Rear Speaker Wire (+): Pink/Light Blue
Right Rear Speaker Wire (-): Tan/White
Jan 13, 2008 | Car Audio & Video
Cyberhome CH-DVD 300 DVD Player Logo
198 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
