Question about LG enV3 VX9200 Cell Phone
If i want to cancel a message i press pwr end it said canceled but it still sends. also my front screen might be falling off...one side is higher than the other and i cannot see the siding on one side. will my front screen fall off or is the screen siding just not perfect because i bought it like this im so scared??? and the screen isand really loose but kinda?????
  • 30 Answers
I have this phone and I suggest you go to your verizon store because you probably have a warranty even though verizon are cheap cause they sold me the display phone for full price
Posted on Feb 06, 2010
What is the calibrating code of toshiba e studio 2303a
(1)While pressing [0] and [5] simultaneously, turn the power ON. ? Adjustment Mode
(2) [SETTINGS] ? [USER FUNCTIONS] ? Select [DRAWER] ? Select [DRAWER1] ? Set the paper size to A4/LT. ? [OK] ? Set A4/LT for the paper in upper drawer.
(3) [CANCEL] ? [CANCEL] ? [SETTINGS] (Return to code entry screen.)
? [10]? [SETTINGS]? [START] (A gamma adjustment patch chart is printed out.)
(4)Place the patch chart for adjustment printed in step (3) face down on the original glass. Place the chart aligning its black side of the gradation pattern against the original scale.
(5)Key in a code "7165" and press the [START] button.
(6)If process finishes successfully, select "Yes" and press the [OK] button to apply the adjustments. (To cancel the reflection of adjustment results, press the [CANCEL] button.) In the case of an abnormal ending, "Error" is shown.
Press the [CANCEL] button to clear the error display. Next, confirm that the patch chart is oriented correctly on the platen and not at an angle, then do the process from step (4) again.
(7)Press [20] ? Press [SETTINGS] ? Press [START].
Notes:
•Compare with chart output in step (3), there should be no differences in patterns and no faint colors.
(8)Place the patch chart for adjustment printed in step (7) face down on the original glass. Place the chart aligning its black side of the gradation pattern against the original scale.
(9)Key in a code "7167" and press the [START] button.
(10)If process finishes successfully, select "Yes" and press the [OK] button to apply the adjustments. (To cancel the reflection of adjustment results, press the [CANCEL] button.)
In the case of an abnormal ending, "Error" is shown. Press the [CANCEL] button to clear the error display. Next, confirm that the patch chart is oriented correctly on the platen and not at an angle, then do the process from step (9) again.
(11)Turn the power OFF.
Sep 04, 2016 | Toshiba Office Equipment & Supplies
Display screen shows "Will return soon" Would like
You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
KX-TA624 Phone System
Press intercom button, dial 750#, lift handset then return handset to cradle to end.
KX-TA1232 Phone System
Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
KX-TDA100 or KX-TDA200 Phone Systems
Press intercom button, dial *7500, lift handset then return handset to cradle to end.
Jan 27, 2011 | Panasonic KX-T7633 Corded Phone
How can i formate htc touch viva
do these steps:
Remove the back cover and then pull out the stylus.
2. With the device turned on, press and hold the TALK/SEND and END buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the TALK/SEND and END buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to manufacturer default. Press Send to restore manufacturer default, or press other keys to cancel.
4. Release the TALK/SEND and END buttons, then press the TALK/SEND button to perform the hard reset, or press any other button to cancel the reset.
Jan 18, 2011 | HTC Touch Viva Cell Phone
I want to reset my samsung phone b7610
Follow the guideline here:
Press reset pin button ONCE (do not hold)
Once you see the Samsung logo appears on the screen, immediately press the SEND and END key simultaneously
Then the screen appears asking you whether you are sure to format
Press SEND to format or END to cancel
Jun 01, 2010 | Cell Phones
Hotpoint washer will not start when you press
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
May 23, 2010 | Hotpoint Ultima WF860 Front Load Washer
For format htc viva
To perform a hard reset (format)
1. Remove the back cover and then pull out the stylus.
Feb 27, 2010 | HTC Touch Pro Smartphone
When starting my new tomtom accidentally installed
hello. i recommend that you do a factory reset as follows: With the device turned off, press and hold the TALK/SEND, END and POWER buttons until you see a message on the screen. Release the TALK/SEND, END and POWER buttons. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset. Once the restore screen appears press Volume Up to restore the device to its factory settings or any other button to cancel. Once complete press Volume Up to reboot.
Nov 12, 2009 | GPS
I have a message in my outbox
Try this but you have to use the LG PC Suite.
Reset the Handset reserved memory by:
1. Go to "Setting" then "Memory Manager" then choose "Handset Reserved Memory "
2. Choose "Clear All" then choose "Yes"
3. After this an envelope will appear on top of your screen
4. Use the PC Suite on your computer choose "Message" then "SMS" then "Task" then"Reload" then choose "Outbox" from there delete the message.
Jul 08, 2009 | LG KF310 Cellular Phone
HOW DO I CANCEL A SENDING MESSAGE
go to outbox and press option and then select cancel thats it but do it fast before it sent it
Jun 13, 2009 | LG Vu CU920 Cellular Phone
HARD RESET MY 02 XDA SMARTPHONE
1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the
same time, use the stylus to press the RESET button at the lower left
2. Release the stylus, but continue pressing the two soft key buttons.
Release them only when you see the following message on your
device screen:
“Press Send to restore manufacturer default, or press other keys to
cancel.“
3. Press send on your device.
Jun 01, 2008 | O2 Xda Orbit Smartphone
LG enV3 VX9200 Cell Phone Logo
53 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
