Question about Maytag Neptune MCE8000AY Electric Dryer
Can the drying cabinet on the Maytag Neptune DC be removed and replaced with a simple top?
    Novelist:
  • 127 Answers
Sorry to say it cannot be removed and a simple top placed in its space.. I am sure if you wanted to tinker and mess around with it you might be able to come up with something, but there is no 'factory' conversion such as you speak.
have fun, and best of luck,
ttfn
Posted on Feb 04, 2010
Tip
Maytag Neptune Front-Load Washers Front Panel and Top Cover Removal
Most of the internal components of Maytag Neptune Front-Load Washers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the machine.
The top cover is held on each side of the cabinet by hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Open the door then lift the front of the top cover and tilt it toward the rear of the machine.
The internal components of the machine can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Square-Front (1998) and Sloped-Front (1999) Dryers (Maytag Neptune Dryers). The only difference is the dispenser bezel removal.
on Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
I need to take off the lower front of the dryer unit to gain access to the igniter
Just remove the control panel. The screws are accessible from the drying cabinet. There will be 5 screws holding the bottom panel in place from the top. It tilts out then up off the clips.
Sep 08, 2010 | Maytag Neptune MCG8000AW Gas Dryer
How to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Apr 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Blown bulb in Maytag Neptune Drying center in tumbler section
1-800-688-9900 OR WWW.MAYTAG.COM, THIS SHOULD HELP YOU OUT.
Jan 16, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dc
I have a Maytag Neptune drying center. The top unit is making a very loud banging noise. How can it be repaired, is this a common problem?
Apr 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune DC Model# MCE8000AYW leaks water from the right side of drying center unit while using the "Wrinkle Release Hanging Dry Only" feature. The leak happens during the steam portion of the cycle....
Stop using the water bottle because the water is overflowing the heater steamer pan and will short the heating element and the part is no longer avaliable and the top will stop drying.
Mar 27, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
153 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
