Question about HP Color LaserJet 2600n Printer
Network printer problem
From my laptop I can successfully print a test page to my network printer (hp Color Laserjet 2600n - linksys WRT56G router), but no documents will print from any program. The printer status says ready but when I try to print I get an error. help!
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 73 Answers
Try the usb cable if the computer can print print test that would be the network is wrong ip address that declare you on printer
Posted on Feb 04, 2010
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Apr 16, 2013 | HP Color LaserJet 2600n Printer
Hp 2600n printer, flashing yellow light near printer cable
check the IP address on the printer,if u reset ur rooter it will assign a new IP so thats y cant print to it In a future use a host name of the printer so this wont happened again
Feb 23, 2010 | HP Color LaserJet 2600n Printer
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Strange Printer Issue - HP Laserjet 2600n
The last time I checked, you cannot set up a local printer using a TCP/IP port. A local printer is physically connected to a computer via a parallel, serial (very old), or USB cable. If the printer is connected to a switch, hub, or router via an Ethernet cable, it is by definition a network printer and the driver install must reflect this. I don't understand why it is able to print out the test page after the install. If you open up Control Panel -> Printers and double-click on the HP Laserjet 2600n in there, it will bring up the local spooler for the printer. You may have a bunch of print jobs queued up in there that it cannot currently send to the printer. You may want to clear the queue first (cancel all print jobs). Let me know if you have problems clearing the queue & I can give you instructions on how to do that one too.
Apr 23, 2009 | HP Color LaserJet 2600n Printer
Is this printer wireless capable?
It doesn't have wireless built in but if you've got a wireless router you can link to it through this by plugging it into a network port. It would need setting up then...
Feb 10, 2009 | HP Color LaserJet 2600n Printer
HP 2600n will not except print jobs.
just reset the printer to factory settings , use the menu to find factory settings .
Feb 03, 2009 | HP Color LaserJet 2600n Printer
Error message on HP 2600n
Connect to it through usb/parallel from your laptop, If this works then check your settings through your wireless connections,Hope that helps
Andy
Jul 10, 2008 | HP Color LaserJet 2600n Printer
Cant print in my network
I am having a similiar network problem, I setup the 2600n on my small-office network, plugging it into an 8 port switch along with a computer and IP camera....then connected the switch to the default router...this worked for a while as my router provided the printer an internal IP, but somehow the IP reset itself to an external IP,and print jobs I send now to the 2600n from my network will not print. I can't seem to access a configuration window to set a static IP address my router will recognize.
Feb 15, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
169 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
