Left channel is not worthing
Left channel is not working (sansui 881)
alex
    Sergeant:
  • 226 Answers
Hi, it could be the output relay, or fuses, have you checked the output fuses or any fuse that has blown, Check for anything that shows signs of overheating.May be the output transistors could be blown. If you are not qualified then i would suggest you get an engineer to look at it otherwise you may end up in hospital or even worse DEAD.
We don't want that to happen, do we.
If yo need more help , please ask.
Regards - Anthony
Posted on Feb 08, 2010
Where to find the owners manual for the Sansui QRX 7500A?
Sansui QRX-7500 Manual - Four Channel Receiver - HiFi ...
www.hifiengine.com/manual_library/sansui/qrx-7500.shtml
May 21, 2014 - sansui qrx-7500 four channel receiver. Sansui QRX-7500 ... service manual English - honestsoul99. Related Catalogues. HiFi Buyers Guide.
Sansui ' Hifi Manuals Free: Service Manuals, Owners ...
Dec 19, 2015 | Audio Players & Recorders
Sansui AU-D33 Lh speaker channel not working.
As the channels are identical you can use the good channel has a guide to the bad one. First thing is to look around see if anything does not look the same as the right channel.
If nothing obvious stands out, with the power on, using an insulated screwdriver touch the two channels one at a time. Keep away from the power supply and anything that is common to both channels. The channel will buzz once touched. Depending which points you touch them. The right channel will tell you if it should buzz at that point. Work backwards from the speaker outputs if you can. If you hear a buzz on the left channel then it is working at that point, if it produces the same sound on the right.
Using this method you should track down the part that has gone.
Dec 11, 2015 | Audio Players & Recorders
I have a 1975 Sansui Integrated Stereo Amplifier and Left Channel on System A & B are faint and Tinny as if Left Channel in System went out. I swapped speakers from right to left channel and same...
It's likely there is a fault on the power amp. This is located on the heatsink. A visual check inside the unit might be what you need. Look out for blown parts, bulging capacitors or burnt components. Remember the two channels are generally separate and identical. So identify the two channels. Work back from the speaker sockets if you can't tell. Then compare the left channel parts with the right side components. If it looks odd on the left compared to the right you have found the problem.
Feb 14, 2018 | Sansui RZ-5300AV Receiver
I have a Sansui receiver Model RZ-1000. The left channel is out. Cheaper to repair? or just buy another similar on ebay?
I have this unit. It is built with disable links for each of the channels, which are easy to replace. The replacement part is only a few dollars.
Oct 11, 2010 | Sansui RZ-5200AV Receiver
I have an old Sansui 400 receiver. I get no sound from the left channel--both A and B speaker options. The speaker and wires are OK, because they work when hooked to the right channel contacts.
The problem seems to be the left transistor part of the unit. Try this:change A versus B speakers, asuming speaker A was working properly. If still speaker A, now connected to left output does not work, you will probably have transistor malfunction on the left channel of the receiver. Any electronic store will substitute the left transistors.
Good Luck.
Flavio/BRAZIL
Jul 23, 2010 | Sansui Audio Players & Recorders
Trying to hook up a teac eqa-20 equalizer to a sansui 881 receiver
record out---------equalizer in ----------equalizer out----------tape in.
Dec 06, 2009 | Teac Audio Players & Recorders
Sansui SV 2102 GOT SOME PROBLEM PLEASE HELP TO FIND OUT A SOLUTION OR KINDLY INFORM ABOUT THE SANSUI HELP NO.
on some tv's you can get to the menu by pushing both the channel up and down buttons at the same time.
May 04, 2008 | Sansui COM311AD 13 in. Combo
Sansui 5000x
I am guessing this is a freeview channel that you are having issues with ?
Perhaps a re-scan for channels may solve the problem or the channel may not be free, it may be topup tv channel. UKTV Gold is an example of this. What is the channel in question ??
Jan 27, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Nov 10, 2007 | SansuiM1315 TV
94 people viewed this question
 Grubhead
Grubhead
