Question about Lexmark All-in-One Printer with PictBridge
Printer wont work with windows
When i put in the installation disk there is a message saying my printer wont work with windows
  • jinky42 Feb 20, 2008
    need help
Windows 2000 wont work with all in one printer5500
Posted on Oct 29, 2008
May I suggest reading what type of operating system is written on the CD, just like "amsatnetg" suggested, the CD you've installed might not be compatible with your operating system. Wndows OS should be wriiten on the CD Label.
Posted on Mar 20, 2008
    Problem Solver:
  • 17 Answers
Need more information. What operating system? what model of printer
Posted on Feb 20, 2008
WINDOWS ERROR MESSAGE
boot from the CD copy of your windows XP. enter in console session and manually replace the file. if the file is corrupted this should fix it
Feb 26, 2012 | Gateway GT5026E PC Desktop
Have windows 7 on new computer, installed Adobe Pagemaker which is fine but want to turn files into PDF format, message say's no printer driver installed. Have tried to install but windows will not let...
the printer will need to be installed in compatibility mode....un-install the printer from control panel.
pain in the **** i know, but least you'll know from now on, how to install older programs & drivers in to windows 7....
if your installing from a disk, then put the disk in, then when the auto run box comes up, close it...
open computer instead from the start menu.
right click on the cd drive with the disk in, & select open.
drag & drop the contents of the disk on to your desktop....make a new folder to put it all in, if you need to.
then once it's copied across, right click on the install/application icon.
from the top of the menu click "check compatibility" if you dont see it,click off it & then try right clicking on it again untill you see it.
windows will scan & set itself to the right settings for that program.
then click try recommended settings.....followed by START PROGRAM.
if it all installs ok click next then click YES KEEP THESE SETTING FOR THIS PROGRAM NEXT TIME.
then go to the printers web site & update it with the latest software,thats if windows doesn't do it for you.....TIP:(white flag @ bottom right of screen)
do this with all older software.....windows 7 is **** hot when it comes to running older programs, im using a windows 98 program call photo express on mine...no problem.
GOOD LOOK MATE.
Sep 10, 2011 | Computers & Internet
Hi, I just bought INTEX Night Vision IT-305WC webcam, it says upto 16 mega pixel, then i connect it to my windows xp pro sp3 computer, it says found new hardware and i select install it (recommended), it...
with that web cam they will give intex webcam drivers cd it ill be small if the webcam is not working then change the USB port if the problem repeats then you must re install the whole win sp3 or repair it
Aug 08, 2011 | Computers & Internet
HP6210 all in one set-up won't work on Vista System Laptop
Did you get an error when installing,or did it install. What happened when you plunged in the printer
when the software told you to plug it in, did windows say found new hardware and you let it install a windows driver or did you shut down the window so it would install the hp driver.
Go to start,control panel,programs, look and see if the hp software is listed,if not it did not install,
try it again.
With the hp printer plugged into your laptop, go to devise mgr and look under portable device,it should
show your printer model#, rt click on the model # and then on driver, does it say hp or windows,if it says
windows then the hp driver did not get installed, put in the disk, then click on update driver and pick browse computer, and point it to the disk.
HP has a vista driver for your printer, so you need to check the set up info that came with it to see
if the vista driver in on the disk. You can always just download the driver software from HP,pick the vista
one and install it. But make sure that the software is removed from the program list if it was in there before you install again. Hope it works out, its very hard to cover everything so if any more Q's
just post back.
Mar 20, 2009 | HP OfficeJet 6210 All-In-One InkJet...
When i first got my printer i got it to work. then for some reason it quit working then i redownloaded and ect. now it wont work at all and i cant download the all in one part of the printer. it only says...
Disconnect the printer from the computer .  Look at the download page below and see if the link for your version of windows is the same as the one you downloaded. Dowload it , if not.  Remove the printer(software) by going through the control panel. Plug the printer back in , turn it on and let windows find and install it. When asked if you have the disk say NO. Install manually and tell it where you put the driver software you down loaded.  Need more help, just ask again,hopefully before rating the answer. Thank you. .
http://search.lexmark.com/printer/US/en/21C2000
Feb 25, 2009 | Lexmark X4270 All-In-One InkJet Printer
Windows wont boot up
try putting the windows disk in and mess around with that and see if it wroks. what i think might of happend is the windows might of gotten del. so put ur windows disk in and i think that might work
good luck
Nov 29, 2008 | Compaq Evo D310v PC Desktop
HP printer 1200 cannot access Hp director
I had to redo my whole computer because of virus. when i reinstalled windows xp my hewlett-pachard psc 1210 will print. I get a message that says it is not installed and I have tried everything to get it to work. no disk i even install a driver but still wont work help please
Oct 24, 2008 | HP Office Equipment & Supplies
New Motherboard=no printer
Hi I am back again. I wanted to see if you reformatted your computer after you installed your new motherboard. If you did not , you had better do so, because installing a new motherboard and not formatting your computer first can cause a lot of problems and cause the activation status of Windows to quickly get lost.
Did the motherboard you replace come from a brand name computer? If it did , it most likely came with its own version of Windows and it is tied to the motherboard meaning you will have to buy a new license for your new motherboard. OEM software is tied to the original BIOS it was activated on at the time and is non transferable to a new motherboard. You can plea to Microsoft all you want but they wont budge :)
Aug 16, 2008 | Dell Dimension 8300 PC Desktop
Lexmark 2500 Scanning
my lexmark 2500 scan wont work I get App4r exe problem...
Sep 04, 2007 | Lexmark All-in-One Printer with PictBridge
Lexmark All-in-One Printer with PictBridge Logo
23 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
