Question about Sony SDM HS93 19" LCD Monitor
My Sony SDM-HS93 has a VERY intermittent display. It only displays for about a half a second and then blanks for a random time. Any ideas?
  • Louis Ebert May 11, 2010
    kwinncsi, Hi there. See if something on my FIXYA profile page (screen) 4 catches your eye. Do lots of reading first, visit some links you find and then you will be able to make decision on just what to do about your unit. HS93 may have repairable power supply. 12fixlouie
  • 11,361 Answers
Common failure in the SDM-HS73/93 is the bad lamps assembly due to poor soldering works.
Service manual: http://elektrotanya.com/?q=showresult&megnev=SONY&megnev2=SDM-HS93&kategoria=monitor&kat2=all
Pictures: http://s807.photobucket.com/home/budm/allalbums
Posted on Apr 12, 2010
My monitor flickered occasionally and one day went blank and turned off. It eventually came back on and then went back off another time. This happened more frequent and then went completely off and will...
Check the caps in the power supply first, hopefully it will not be bad lamp assembly as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
the HS-17 also has bad lamps problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 24, 2010 | Sony SDM HS93 19" LCD Monitor
I have a SONY SDM-HS93 LCD monitor, Maybe Monitor receiverd an electric overstress, so the screen displayed but screen disappeared after few seconds. And if I turn it off & turn it on again, it turns...
Siny LCD Monitor is so expensive. <a href="http//www.wholesaleeshop.com.au/LCD-Monitor/index.php?keywords=philips">Philips LCD Monitor</a> is good!
Nov 02, 2010 | Sony SDM-HS93 19" LCD Monitor
Hi..my sony model sdm-hs93 lcd monitor flutters for a couple of seconds right before the screen blanks out. But, if I leave the monitor on for a day in sleep mode, the next day i can hook it up to the...
I think the problem with your monitor is that, the picture board on the monitor is malfunctioning that is why it keeps going blank after a minute.
What you need to do is to replace the picture board on your LCD monitor, replacing the picture board will solve the problem, because the picture board on the monitor at the moment is bad and will need to be replace.
Replace the picture board and you will see that the problem will not repeat itself again.
Take care.
Jul 16, 2010 | Sony SDM-HS93 19" LCD Monitor
Sony SDM HS73 ''turns off''
One thing I know for sure on this model HS73/HS93 is that the backlight assemblies failed due to poor soldering works. This may the problem with your monitor.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
It is very time consuming repair works that I doubt very much if repair shop will do the work.
Apr 19, 2010 | Computers & Internet
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
Sony hs93 screen doesn't come on unless I hit the power button a couple times, then, sometimes display is wrong dimensions , so I hit power button again, straightens up. also, sometimes it comes on with...
First, check for properly connected cables. Disconnect and then re-connect to ensure quality signal path. Use a known-good cable to test. If no joy, turn off computer and remove video card, then re-install it. Sometimes, after long periods, the contacts on the card can become oxidized and have intermittent contact. This will also give you the chance to check for large amounts of dust settling on the components--dust, combined with humidity in the air, can play havoc on computer cards. If still no joy, then the processor board in the monitor might well be defective. Power, signal/resolution decoding is all handled by IC chips. I like to start simple and move to more complicated(i.e. expensive) problems.How old is the monitor? If under warranty, replace it. If not, a repair facility or replacement is your next move.---Rick
Sep 10, 2009 | Sony SDM-HS93 19" LCD Monitor
Screen turns on for a second then turns off
Your power supply is blown. If you have some repair knowledge then pull it apart and look for caps that have raised or bubbled tops. They need replacing I do this repair all the time. If you don't want the monitor please let me know I will pay for shipping. I repair them for the school.
God luck.
Mar 15, 2009 | Sony SDM-HS93 19" LCD Monitor
Sony SDM-HS53 Monitor Goes Blank
I used to have the same problem until I discovered that the cables in the back of the monitor weren't securely connected. I have a very similar model monitor to the one being displayed here
Apr 03, 2007 | Sony SDM-HS53 (Black) (Gray) 15" LCD...
Sony SDM HS93 19" LCD Monitor Logo
450 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
