Question about Microsoft Windows XP Home Edition
I need to removed a vuris - Microsoft Windows XP Home Edition
Click on the link below and download the free Ad-aware program. After you download it, install it and do a complete system scan to remove the virus from your computer
http://download.cnet.com/Ad-Aware-Free-Anti-Malware/3000-8022_4-10045910.html
Next, download this free program called "AVG antivirus" and then do a complete scan of your computers hard drive
http://download.cnet.com/AVG-Anti-Virus-Free-Edition/3000-2239_4-10320142.html
Posted on Feb 04, 2010
How do u replace lower control arm bushes nissan navara d22 duel cab 4wd 1997 , do u need to drop torsion bar and if so what's the best way to do this
to remove lower control arm bushings you need to remove control arm from vechicle have control arm bushings pressed out.you need to remove disconnect torsion bar,remove shock absorber,disconnect stabilizer bar link, remove axle half shaft, remove the lower ball joint, remove control arm mounting bolts, then remove lower control arm.
Nov 24, 2012 | Cars & Trucks
My computer is freezing or not responding. Also downloads are being blocked completely
Sounds like you have a virus. boot into safemode with networking and download malwarebytes run that in safe mode. then restart into normal windows and run malware again. then i suggest downloading AVG its free and antivirus great program. also if you are using mcaffee dont use it. It slows your PC down way to much
May 05, 2011 | Computers & Internet
How to remove window crank?
first you need to remove all screws in thje door panel then remove the crank handle with a pick or special tool to remove the clip that holds the crank arm on. then remove the panel and you will find a plastic cover that cover needs to be removed to access the window regulator. once there you will see screws which hold the window those need to be removed so that you can remove the window crank.
Jan 15, 2011 | 2000 Jeep Wrangler
Hi i have a laptop advent 8109 i need to open it
Remove panel at the back, remove keyboard from prongs at the top, remove HDD, remove screws holding down the laptop, remove heatsink, remove fan, remove ODD connector, lift out motherboard at an angle. Its really something that needs to be shown, but thats the order in which you need to do it. If you can figure out the "in-betweens", you will be on your way to a cheap repair!
Jun 18, 2010 | Advent Netbook
I need to remove the dash in 2005 chevy silverado
to remove the dash in your truck you will need to dedicate about 8-10 hours. first start with removing your kicker panels, then the plastic covers on your a-pillars. remove the bezels around your instrument panels. you should be able to see some black screws by now, they should be a 7mm some may be a 5.5mm start removing all the screws you can. next you will need to un plug all of your switches, airbags(yellow plugs), 12v accessory plugs, be sure to remove your battery cables before unplugging all of this. your dash cover is a pain to remove so be patient with it or you will break it easily. to remove your dash cover remove the screws in the front and you will have to pop the back of dash up then remove. next you will need to remove your steering wheel/column this is easily done however you will need alot of extensions for your ratchet to do this. after pulling your steering wheel/column remove the four screws by your windshield to remove your sub-dash i believe they will be a 10mm. remove your sub-dash. next you will need to remove the dash support frame, you will need a 15mm and a 10mm socket to do this, i believe there is 5 bolts holding this on. if needed you can remove the black box that holds your fan heater core blender door cab filters and etc... to do this you have to remove the ac hoses coming out of your dryer can going into the firewall, this will bleed out all of your freeon, next remove the heater hoses, now there are 7 bolts or nuts to remove on your firewall, when you remove those you can pull out the black box.
Oct 09, 2009 | 2005 Chevrolet Silverado 1500 2WD
How to remove bearings on 1998 gmc jimmy axle shaft bearings and pinion bearing?
if diying and axle bad replace the whole unit from salvage or rebuild shop.if changing the bearings its a lot of work and you will need some special tools to put back together .first you need to use a lift or again have to remove unit from truck, disconnect battery remove drive shaft,remove pinion nut need large breaker bar loosen bolts to rear cover drain fluid remove cover have someone push axles toward center remove c locks slide out axles best way to remove bearings is slide hammer bearing removal unit remove rear [gears] dont loose shims will see pinion bearing bearing remove and replace now 2 put it back.need shim package, red lead, 4 ring and gear mesh adjustments ,,
Jul 07, 2009 | 1997 GMC Jimmy
Driver side mirror installation (and removal of old)
Inside the pull cavity on the window switch bezel there is a cap in the bottom of the cavity.Remove this cap and there are 2 screws there you need to remove,then remove the window switch bezel.
There will be a screw there in the door panel where the bezel was covering up,remove this.
Under the door handle you will see a small square cover,remove this and you will see another screw you need to remove.
You will see 2 more screws at the bottom of the panel you need to remove.
Then lift up on panel and remove.
You will then see 3 nuts holding mirror on,remove these and remove mirror.
Apr 03, 2009 | 2003 Lincoln Aviator
Window Explorer is unable to get connected
FIRE FOX IS PREVENTING YOU FROM COMMUNICATION ON THE INTERNET, TRY ANOTHER INTERNET PROVIDER LIKE WINDOWS INTERNET EXPLORER, ALSO YOU MY NEED TO TURN OFF ALL ANTI VURIS PROBROM AND FIREWALL UNTIL YOU GET THE INTERNET UP AND RUNING THEN START TURNING ON ONE FIREWALL AT A TIME UNTIL YOU FIGURE OUT WHICH ONE IS CAUSING THE ERROR
OR
GOTO WINDOWS START
TYPE IN SERVICE
GO IN DOUBLE CLICK ON ANTI VIRUS PROGRAMS, FIREWALLS, WINDOWS ANTI DEFENEDER SOFTWARE AND DISABLE THEM ALL OKAY OR YES TO EACH ONE
THANK REBOOT SO THEY TAKE EFFECT
TRY NOT TO USE FIREFOX UNTIL YOU HAVE INTERNET ADD FIREFOX AND IF YOU START HAVE INTERNET ISSSUES THE GO TO UNDO LAST ITEM OR REDO, DELETE FIRE FOX FROM THE SYSEM RESTORE WINDOWS ORIGINAL MICCROSOFTWARE APPICATION THAT ILL BE IN THE RESTORE SECTION OF THE RECOVER OR ON BOOT UT F 10-12
ON BOOT UP
FOLLOW IN STRUCTION GO INTO ADVANCE BUTTON, SELECT MICROFOST SOFTWARE
ONLY AND REBOOT SYSTEM
CANDYMANGANDY/ROD
Jan 29, 2009 | Dell Dimension 4550 PC Desktop
Need help on get n a key switch out of a 93 buick regal gran spor
remove steer wheel with puller. u will see black cover remove 3 tork screws.remove. next u will need a special tool push dowd on plate . remove clip in center. remove plate.. remove bolt for lock cly. turn key lock will slide out
Nov 15, 2008 | 1994 Buick LeSabre
Error transfering mp3 files
j'ai un ipod de 1G elle a des vuris elle m'ècriè erreure format dans le 19eme chançon puis elle redemare merçi bcp de votres aides
Feb 24, 2008 | Audio Players & Recorders
Microsoft Windows XP Home Edition Logo
12 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
