Question about Epson STYLUS R230 InkJet Photo Printer
The printer does not print only dragging a paper without printing I have tried the best how to set it but failed completely. If such is the case how can I get a help so that my printer should work?
Same problem here ni think the main board i9s defective
Posted on Feb 11, 2010
Mx 2830 - fails to print - asks to add extra plain paper
Check the paper type and paper size in the Printer Properties. Set them according the actual paper used in the printer. Check the paper size in your document you want to print. Correct, if differs from the printer's paper size.
Jan 09, 2014 | Sharp Office Equipment & Supplies
When I try to print paper will come out without printing
1. Try to align printhead
2. Head cleaning with epson software
3. Reinstall driver and try to print
4. Check printer component, and ensure that's no broken part
Oct 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
My printer Epson Stylus PHOTO R230 does not print
The printer does not print only dragging a paper without printing.
3 option to solve
make sure your
1. heads are working
2. flex cable connecting the heads
3. main board
Most common that i found is to replaced the main board. or replace parts of other main board if you have some extra. hope it can help.
Jun 29, 2009 | Epson STYLUS R230 InkJet Photo Printer
Printing paper with to much toner ink on the paper. Words are unreadable.
If this is a cartridge refiling case,
I think its an over refill
try with refill again (complete empty (also waste) is necessary for best result)
May 21, 2009 | Brother Office Equipment & Supplies
My printer is printing blank pages What is wrong?
You may clean the cartridge by following the steps given below:
1. Remove the cartridge or cartridges from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridges back into the printer.
Next, I'd like you to attempt this printer self-test by following the steps given below:
1. Disconnect the power cord from the back of the printer.
2. Press and hold the button on the printer panel.
3. Reconnect the power cord and keep holding the button on the printer panel until the printer starts to pull paper.
4. The printer should now print a test page. Please note that the test is continuous. To stop the test, disconnect the power cord.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
Apr 16, 2009 | Lexmark Z617 InkJet Photo Printer
Photosmart C6300 pictures are printing very wet and grainy. printer is also very loud - almost as though the parts were scraping and banging.
Sounds like you have the wrong paper setting in your print properties. I would use photo or high bright 24lb paper and set the paper type in your printer properties prior to executing the print job.
Regards,
Worldvet
Nov 12, 2008 | HP Office Equipment & Supplies
Blank printout
If you are able to drag out your users manual, most lazer printers have a self cleaning process for the head, which takes around 3-5 minutes to complete, after that try to run a test page to ensure the colors are working fine.
Failing that, unless the printer is brand new, and or unless it has been sitting ( unused - regardless of age ) the print heads can dry out leaving a blockage ... hence, no ink, hence blank page.
The only other suggestion after running a Print head clean, would be to replace or refill the ink cartridges.
Jan 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
Epson 2400 printer prints dark and with slight colour cast
try these :
1. nozzle check
2. image set to RGB color (Photoshop)
3. check driver settings
4. try another file
5. try another application
6. ¨supported / recommended¨ epson paper & inks
7. another computer (to pin down where issue is happening)
8. all else fails - the printer needs service (better check your warranty status)
Jan 03, 2008 | Epson Stylus Photo R2400 InkJet Printer
MFC-3240C
The printer may not be scratching your printout but you may have a clogged printhead. A clogged printhead will constantly miss a spot creating an effect of a scratch printout. Please run an all inks printhead cleaning routine (2 or 3 times) and create a test page. Best Regards
Aug 20, 2007 | Brother MFC-3240C All-In-One InkJet...
Epson STYLUS R230 InkJet Photo Printer Logo
90 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
