Question about Konica Minolta magicolor 2300DL Laser Printer
C0500 error code minolta di 2550
How to reset c0500 error code on minolta di 2520
Soulvisitor
  • 1113 Answers
SOURCE: Minolta Error code C0500
1. Test Mode Operations
• The Test Mode is performed from the copier’s Tech. Rep. Mode.
1-1. Entering the Tech. Rep. Mode
1. Press the Utility key.
2. Touch [Total Check].
3. Press the following keys in order: Stop → 0 → 0
→ Stop → 0 → 1.
NOTE
Be sure to keep the display procedure for the Tech.
Rep. Mode from any unauthorized persons not
involved with service operations.
4344S504CA
link to a service manual that explains tech mode
Posted on Dec 02, 2007
  • 214 Answers
SOURCE: Konica Minolta bizhub 350 Error c0500
did you do a trouble reset ?
Posted on May 11, 2008
SOURCE: minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Posted on Sep 02, 2008
jqsababa967
  • 145 Answers
SOURCE: Minolta Di 351 code C0500 & need reset code for this
look for a small hole...on right side of the disply panel...THE HOLE IS SMALL THE SIZE OF PAPER CLIP IN DIMETER..IN FACT THE ONLY WAY TO ACCESS IS BY PAPER CLIP.PRESS IT ONCE VERY GENTLY..AND WAIT FOR A SMALL DOT TO APEAR ON THE LEFT SIDE OF THE SCREEN IN THE CENTER.ONCE YOU SEE IT>>PRESS # 3 than you will be promted by a screen to reset troublr code press it to conform MACHINE WILL RECYCLE
HOPE THAT HELP S
GOOD LUCK
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: Konica Minolta Di 3010 - cannot clear trouble message
one thing you can try since you have already removed the fuser you can probably do this but i would not recommend it unless you are familiar and comfortable with the components of the machine turn the copier off remove the back cover you will see in the middle of the machine a metal cover with 4 or 5 screws, behind this cover is the main board it has many wires going to it through out the machine...remove the cover so u can see the board and all its connectors on the board there should be a little black button... turn the machine on press this button and the code should reset. If the code does not reset then the thermistor or thermostats are bad and the fuser needs to be rebuilt. as for the password 8 zeros or 1-8 are the defult passwords for the machine. you can also try 1247....
Posted on Apr 08, 2009
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
How can I reset eror code CO 500 on konica minolta copier DI 2510
Aug 08, 2016 | Konica Minolta Di2510 Di251 Di250 Di2010...
How I Can Solve the Code C-0540
May 18, 2014 | Minolta DI-2010F Copier
Di minolta 251 diplays the code c0500 if when the wires are connected properly and sufficient current is supplied. What do I do to correct it? Thanks.
Check Your Fusing unit. if there is any possible changes on it maybe wires wer cut off, or some pieces of paper left inside of it (fusing unit) blocking the thermostat or just simply buy an AVR.
Dec 08, 2012 | Konica Minolta Office Equipment & Supplies
The machine di251f is saying contact your technician with code error c0500 please help
C0500: Warming-up Failure
error code c0500, checked lamp and thermo fuses, checked thermistor ok. reset machine
Jun 17, 2011 | Minolta Di251 All-In-One Printer
Konica Minolta Di2510 error code C0500,can not reset error code
check the fusing unit parts heaterlamp,thermistor & thermoswitch i'm sure one of them is the cause of error c0500
Nov 22, 2010 | Konica Minolta DiALTA Di183F Copier
Porque sale error c0500 en la dialta 470
plz chek the thermostate heater unit fuse and heater lamp and clear truble button and relase this code c500
May 28, 2010 | Konica Minolta DiALTA Di200 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta di 2510 code c0500
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Minolta Di 151
How to clear a C-0500 error code.SolutionHold down the [Clear/Stop] key while turning on the power.
For the Di151f, hold down the [0] key while turning on the power.
if the code comes back replace the fuser unit. DO not continue to reset the fuser can catch on fire and that will ruin a perfectly good day.
Oct 21, 2006 | Minolta Di151F All-In-One Laser Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
246 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
