Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
It leaks a lot of water. I Checked the water container, the O ring seems okay. It does not leak by idle sitting but as soon as I make coffee the whole table is full of water.
  • 1,089 Answers
Hi I would suspect that you have a ruptured tube inside. When the machine starts to pump it looses water from the tube onto the counter. It can be fixed.
Posted on Feb 04, 2010
Hi the cup warming tray is very hot to the touch and steaming a lot???
The cup warming tray works by sitting directly over the main boiler. If there is something wrong with the cup tray there is probably something wrong with the boiler.
If there is lots of steam coming from the top of the machine you may have a leak. Check for puddles under the machine as well.
Leaks
Coffee leaking into the drip tray could be from the brew unit or the front door assembly. Water leaking probably means a hose connection to the boiler has failed. Don't just leave it, fix leaks immediately. Besides the electrical danger, the rust on working parts from long term leaks can be extensive.
Are you confident? Operate the machine with all covers off to see where the leak comes from. Be extremely careful, ready to pull the plug at any moment. Touch nothing inside! Burning, scalding and electrified! Check both boilers very closely while making coffee, most leaks become obvious on close examination.
Most leaks are due to failed o-rings in the connectors at the end of the teflon hoses, usually at the coffee boiler. Replacing the o-rings should stop the leak.
Source replacement o-rings. Slide the hairpin c-clip out of the side of the white connector and pull the teflon hose out. Fish the old o-ring out of the connector with a small hook or point if it didn't come out with the hose. Place the new o-ring over the end of the hose, snug against the brass collar. push the hose back into the coupling being careful to go straight and true so as not to damage the new o-ring. Some force may be required, be careful not to kink the hose. Blunt needle nose pliers to push the rear of the brass collar usually does it. Replace the c-clip and test for further leaks before reassembling.
Sep 25, 2011 | DeLonghi Magnifica 3300 Espresso Machine
My Delonghi N95 Nespresso machine is leaking water
on a N95 fill the water container and take it off the machine if it leaks its just the red seal on the botton but if thats not it put the water container back on full of water,let it sit for a bit,it wil leak out the front or side it will be the dark grey seal in the base were the outlet of the water container sits in, I found this with vmine anyway,it was hard to see it leaking but was a pain in the but!! i will talk to Delonghi or pull the seal out and match one the same
Ant
Feb 12, 2011 | DeLonghi Nespresso EN660 Espresso Machine
The water container releases too much water and it spills out the back and sides of the machine
Water container have a small valve which work with a small spring and o ring. You can remove the container over a sink unit fill with water and try to press with your finger to check if it block the water without pressing it and also check visual if their any dirt or scale blocking it from closing full or if the o ring is damages in any point.
In any case the valve work very simple the the spring force down the piston and o ring should block the water from ascape if any of thsi is dirty or damage or the loose then the water will leak.
You should also check the valve base on the machine body since their can be something that blocking the valve sit corectly on base so water can leak out of the piping arount the machine.
Good luck
Aug 15, 2010 | Saeco Trevi Automatica Cappuccino
Espresso gaggia titanium. Water Tank leaking
The o-ring on the bottom of the water tank is either missing or not seated properly.
May 10, 2009 | Gaggia Titanium Espresso Machine
Water container leaking on Saeco Magic coffee machine
Hi
There is a donut like cap under the water tank on top of the machine. Pry on the outside of this cap an pop it off. Under the cap is a black seal. If you stick your finger in it and just pull out and the seal comes with it, you need to replace the seal. The new seal will not slip in you have to run your fingernail around the outside and silp the seal in. It should not just slide in. Make sure that the receptacle is clean before putting the new seal in.
Apr 28, 2009 | Saeco Magic De Luxe Espresso Machine
Jura Z5 - no water being sucked up through the system
If you are holding the filled water tank in your hands does it leak? If no then the o-ring in the bottom of the hole on the machine where the tank sits is damaged.
If yes then check the spring and o-ring on the bottom of tank.
Apr 28, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Water leaking from underneath water tank.
I rang Saeco service centre about my leaking water tank and they posted me a new tank - no questions or need to return the faulty item. I believe there may be a bad batch of tanks which leak because of faulty valves.
Mar 24, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Water leaking out from water container
You either have a small crack on the water tank and/or the connection from the bottom of the tank reservoir to the machine is not sealing properly. ( i.e similar to putting the tank on top of a flat surface, the tank will leak as the seal connections gets pushed up and water begins to flow out)- it is that component that I am refering to. If you can inspect it to pin point the problem - if the latter is the case (valve), could try purchasing a new o-ring, piston, and valve. Suggest contact
. Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support and they will give more detail or contact SAECO via e-mail at : outlet@saeco-usa.com
Jun 20, 2008 | Saeco Magic De Luxe Espresso Machine
Leaking
i got a vienna digital when i take the water container of to clean it 1 time out of 2 im gonna have water all over the floor what i do now clean the container put it back fill the water container with big glass and no more leak it probably have to do warp water container when it empty it seat perfectly when you have it in our hand it warp a little bit were not the only one with that me when i dont remove the container to fill it up i have no problem since then thanks for using fixya pierre
Feb 25, 2008 | Solis Master 5000 Espresso Machine
Water reservoir leaks intermittently
Saeco use the same seal under the grey plastic ring on most of their coffee machines so it should be easy to find a replacement from any Saeco, Spidem or Gaggia service centre.
In most cases the seal isn't worn, it just isn't sitting right, so remove the grey cap (two flat screw drivers to lever from both sides at the same time helps) and reposition it. This is usually all that is needed if the problem is only intermittent.
Also check that there isn't anything sitting in recesses where the legs of the water container sit. It only takes a tiny bit of dirt to stop the container sitting in far enough to seal.
However, make sure the leak isn't coming from the container itself. Hold the container up with water in it and see if it drips. Check the the spring is clean.
Nov 26, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
211 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
