Question about Wurlitzer Jukebox CD Player
Hi,carrige has stopped.cannot get lights in record choice numbersdoes not seem to be getting power.Because you cannot select there is no movement.this is a NSM Prestige ES 160. There is power to all other parts,I have replaced all fuses.
  • roywilson6 Feb 05, 2010
    The solution offered sounds as though it is the right one.I have not had the time to check but this i will do over the weekend.It is the way we intended to go but not as fast as this ,I am very greatfull forthe speed I was answered,I will let you know the good results. Thank you very much,I will shout you a beer if we meet. Roy.
  • 10,319 Answers
A selection programmer in your unit is at fault. A capacitor may be bad is no power is going through it to blow a fuse. A capacitor will not let power continue through if bad so you will receive no continuity to the rest of the circuits gaining a working mode
Posted on Feb 04, 2010
My Toshiba DR430KU dvd recorder is not recording. I hit the record button, and the light comes on, saying that it is recording, but nothing gets recorded.
Hello
Secure the audio/video connection cables that attach the source device you are trying to record from. Try this step if you do not see a picture when trying to record from a source device onto the Device. After unplugging the cable and checking for any damage, plug the cables back and attempt to record the content to see if this resolved the problem.
Secure the power cable that attaches the device to an electrical source if the unit will not power on or if it intermittently loses power. If you think a malfunctioning surge protector may be at fault, you can 'bypass' the surge protector by plugging the device into an electrical outlet. Replace any surge protectors that appear to be malfunctioning and have an electrician examine any outlets that appear to be "dead."
Insert the disc that you would like to record
Press the "Edit Menu" button on the remote control while playing the disc or while playback is stopped.
Use the up and down arrows to select "DVD-Video Finalizing" in the on-screen menu, then press "Enter."
Under "Menu Create" select "None," then under "After play final title" select "Stop." Select "Next" to move to the next screen.
Select "Writing" in the lower right of the screen.
Select "Yes" or "No" to tell the machine if you want it to power down when finalizing is complete. Finalizing will then begin and a progress bar will appear.
Contact your electronics dealer or the Toshiba service department if the disc still does not finalize.
Apr 19, 2011 | Toshiba DR-430 DVD Recorder
It keeps reading 'carriage jam, close door then press ok ... ' it will not stop.
If you open the printer cover you should be able to see a guide bar where the print carrige runs, if you can touch it feel if it is dry, if it is very dry (it may have black residue) then you will need to wipe the bar with a tissue or rag to clean it and then with a toothpick carefully add some singer oil (Machine Oil) maby 4 -5 drops along the bar, and slowly move the print carrige over the newly oiled section this should lubricate the bar again and stop your carrige jam issues
Feb 09, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How do you change the print heads on HP DesignJet 500ps InkJet Printer
first select the ink menu on front pannelthen enter select the print head replacement then enter carrige moves towards left then stop & message appears open the door then open the door & remove the head lock & remove the printheads during this process no power off
????????????/pls reply thanks mishrajk21@rediffmail.com
Apr 27, 2010 | HP DesignJet 500ps (42 in.) InkJet Printer
I have an OS 10.5 Mac and a Logitech desktop microphone. I want to record and play back voice. What software do I need?
Mac come with builtin Sound Recording Service. You need to follow these steps to record sound through your microphone.
  1. Click the Apple menu and select Control Panels; select Monitors & Sound
  2. Click the Sound icon.
  3. Under Sound Monitoring Source, select one of the seven input sources (where the sound will come from): Built-in Mic, External Mic, Sound In, Expansion Bay, CD, Zoomed Video, Internal Modem, RCA In, DAV Analog In, or PC Card. Some systems may not have all choices.
  4. Choose Sound Output Quality: 11.025, 22.050 or 44.100 KHz. Some systems may not have all choices.
  5. Click the Apple menu and select Simple Sound.
  6. Click the File menu and select New. You're presented with a window set up like the controls on a tape recorder.
  7. Click the Record button and start your sound (either speaking or singing into a microphone, or playing your CD, or whatever).
  8. Click the Stop button when you're finished. You can click Play to check what you recorded.
  9. Click Save. You're presented with a Save dialog box in which you can name the sound file and place it in whatever folder you like.
You are done. If SimpleSound isn't in the Apple menu, search for it with Sherlock (press Command-F). To play the new sound file later, just double-click its icon to open SimpleSound.
For further help please visit http://www.ehow.com/how_6538_record-sound-mac.html
Please do rate my solution.
Regards, Rashid.
Oct 28, 2009 | Logitech USB Desktop Microphone
Want to stop VCR from using Spanish language on programs it records
Use SAP (or SAP/HI-FI) button on remote to cycle through the choices until you get to English or OFF.  Or use Setup Menu to select English language.
May 30, 2009 | Panasonic PV-V4525 VHS VCR
LG LCD TV remote power button turns off LG DVD Recorder as well
Hi VMUZZI,
IT Seems that teh SIMPLINK Featire of your TV/DVR is ON. Try to OFF the feature.
Mar 09, 2009 | LG DR787T DVD Recorder
Recording from TV issues: Channel selection...Line 1, 2 or 3???
get it fixed in a shop.
when things break do that.
this dc4000 is an old device.
get the service manual on it ? yet?
or why not upgrade ,
what way to you watch TV, (sources)
antenna
Cable
SAT
what?
Nov 06, 2017 | HP dc4000
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Pace Sky plus box
You have 2 choices, software reset or hardware reset. It's up to you what you try, but please read the advice in full before starting - if you break your box, please don't blame me!
SOFTWARE RESET
The following is copied from http://www.ecademy.com/node.php?id=73309
This is useful if your disk usage percentage doesn't go down even after clearing programmesfilms off.
The following is offered on an ADVICE only basis, take care when making changes:
WARNING following this advice is totally at your discretion and anything which happens to your digibox as a result is your responsibility, not mine. You will lose all recorded programmes from your Sky+ Planner.
Sky tech support can talk you through performing a system restore over the phone. To do this yourself, press 'services' on your Sky plus remote, then select option 4. Next press 0, 1, select - you should now see the engineer's menu. Choose option 8, 'Full System Reset'. The box will now take a few minutes to reset itself
Try pausing or recording again, and if the problem persists disconnect the digibox from the mains power. Press and hold the 'left' and 'right' navigation buttons on the front of the digibox whilst you reconnect the mains power. Continue holding the buttons in for about 20 seconds, and when the ring of light on the front comes on, press the 'select' button on the front of the digibox (between the left and right buttons you were holding). The Sky+ recording logo lights will spin backwards and, according to the Sky engineer, this will "clear the hard drive".
Once this is done, disconnect the digibox from the mains power again and this time press and hold the 'back up' button whilst you reconnect the mains power. Continue holding it for about 15 seconds until 3 lights on the front of the box come on and you get a full-screen message saying "Updating system software. Do not disconnect mains supply or satellite dish."
Leave the digibox doing its thing for about 10 minutes and it should be fixed! Try pausing and recording things again... hopefully you've just saved yourself £65
If you've not been so lucky, you'll have to get Sky to fix it for you. Some people report that if you ask to cancel your subscription Sky sometimes offer a free callout to fix the problem - you're more valuable to them as a paying customer than the cost of an engineer callout
Sky customer service's (seemingly unpublished) freephone number. You need to dial 0800 731 6965, then option 2, option 4 March 9, Sky have closed this Freephone number
HARDWARE RESET
Copied from http://www.digitalspy.co.uk/forums/showthread.php?t=484098
Full System Reset via front panel:
  1. Remove power at mains.
  2. Hold LEFT+RIGHT.
  3. Apply power, wait for ring to light.
  4. Release LEFT+RIGHT, press SELECT.
  5. Ring cycles backwards while disk is quick formatted.
  6. If format sucessful PLAY lights up, if not RECORD lights up.
  7. Box goes into standby - wait 30 seconds are wake it up.
Warning: Full System Reset deletes all your recordings and planner entries.
Aug 07, 2008 | Pace Type 30-0060 1121-0369 D1 .060 D2...
Does not record
Have you selected the correct input? These recorders are desinged to stop after 20 seconds of silence. Do you get any level showing on the record level meters? Press the source button until it shows 'analogue' if recording to the 2 phono inputs.
Dec 29, 2007 | Philips CDR770 CD Recorder
Open Questions:
See all Wurlitzer Jukebox CD Player Questions
Wurlitzer Jukebox CD Player Logo
104 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
