Question about Sos Snow Devils Down Hill Ski/Snowboard Metallic Googles/Eyewear w/PC 2.0mm
IF the length of a ski hill is 1500 feet and the angle is 45 degrees at what average speed would a skier ski down the hill
    Problem Solver:
  • 10 Answers
45 degree slope feels practically vertical when skiing, there are very few slopes this vertical on any in-bounds ski hill in the world. So this sounds like an academic question probably for a high school physics class? Just do the math and calculate top speed at 1/2G over 1500 feet. Just off the top of my head though, What in physics they call the guesstimate to check your work from being way off, i think I could easily exceed 50 or 60 mph skiing a 45 degree chute with no turns over 1500 feet.
Posted on Aug 31, 2014
  • jgcfamily Aug 31, 2014
    45 degree slope feels practically vertical when skiing, there are very few slopes this vertical on any in-bounds ski hill in the world. So this sounds like an academic question probably for a high school physics class? Just do the math and calculate top speed at 1/2 G over 1500 feet. Just off the top of my head though (what in physics they call the guesstimate to check your work from being way off, and you would have to include friction in air resistance) I could easily exceed 50 or 60 mph skiing a 45 degree chute with no turns over 1500 feet.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 69 Answers
Depends on the skis,skier,temp,wax,and skill.
Posted on Feb 04, 2010
How do I miter with my radial arm saw (RA-2500). I can't tell from the manual.
the slide can be angled by the degree plate where the timber sits
the blade can be angled by the degree plate on the arm that mounts the saw
so you can get a 45 degree to the timber length and a 45 degree angle cut to that angle to give you a corner mitre cut
Jul 03, 2017 | Saws
Question. a triangle with two sides 1700mm each with a 45 degree angle. what will the length be of the third side?
If 2 angles are 45 degrees, the other must be 90, so Pythagorus' Theorem applies, so it is sqrt ( 1700^2 + 1700^2 ) = 2404.16
or
for triangles, a / sinA = c / sinC so c = ( 1700 / sin (45) ) * sin (90) = 2404.16.
Oct 31, 2016 | The Computers & Internet
For a 10ft radius octagon, how long should each side be?
There is probably a formula for this or other ways of doing this, but I will give it a shot.
An octagon has 8 sides (octopus has 8 legs). To make an octagon, we effectively have 8 triangles joined at the centre. In the centre, we have 8 equal angles. Since a full circle is 360 degrees, each of these angles must be 360 / 8 or 45 degrees.
Now we can just focus on one of these triangles. We have an angle of 45 degrees at the centre and two arms extending out 10 feet.
At this point, we can use the cosine law to calculate the length of the side or we can recognize that it is an isosceles triangle and work out the other angles and determine the length of the side.
Using Cosine Law, a^2= b^2 + c^2 - 2xbxc Cos A
In this case, A = 45 degrees, b = 10 feet, c=10 feet.
Good luck.
Let me know if you have any questions.
Paul
Aug 25, 2015 | Miscellaneous
My Dept56 animated ski mountain. The skiers seem to heavy for the magnets in the ski run
Cut the friction on the skis or ski slope, use wax or soap to cut down on friction
Dec 16, 2014 | Sport & Outdoor - Others
What is more difficult, sit-down hydrofoil or water-skiing?
Clearly, water-skiing is a more difficult sport for the reason that the water-skier rides on the water itself, while a sit-down hydrofoil rider rides underneath the water, which decreases the friction level substantially.
Feb 06, 2013 | Water Sport
A rectangle is 87 feet by 136 feet. find the length of the diagonal and the angles that it makes with the sides.
Length of diagonal =SQRT(136^2+87^2)=161.4465856 ft
One angle = arctan(87/136)=32.60... degrees
Other angle= 90-32.60=57.39 degrees
Sep 10, 2011 | Super Tutor Trigonometry (ESDTRIG) for PC
I just bought a new Panasonic TX-P46S2 46"plasma
Try some adjustments. Brite changes the level of bright and Picture changes contrast. Less contrast and less brightness to even things out may help, and you won't be driving the panel so hard, so It's life will be longer too.
Nov 25, 2010 | Panasonic Televison & Video
I am going to put pea-stone all over a sloping hill .. How do I stop the pebbles from all landing on the bottom in a pile?
That depends entirely on the pea gravel and the slope of the hill. Read the Wikipedia entry on "angle of repose". Pea gravel typically has an angle of repose of 45 degrees or less. If you hill is less steep than 40 degrees you will probably be OK. Otherwise, you would need some retaining walls to reduce this angle. (Probably not what you had in mind.) Best thing to do is go to the source of your pea gravel and measure the slope of the pile it's in. This will be the maximum angle of repose for that material. Compare this to your hillside. If the hillside is at least 5 degrees less steep, you should be OK, unless you will expect foot or vehicle traffic on the pea gravel - in which case you would need at least a 15 degree margin.
Jun 15, 2010 | Garden
I need an urgent help..pleassssssssseeeee....
cafdef1.jpg Given AC = 2675 feet
ð XAC= 14 degree
Therefore ð ACB = 14
Now Sin C= AB/AC
AB = AC . Sin C
AB = 2675 * Sin 14 feet
AB = 2675 * 0.241922 feet
AB = 647.1411 feet
Jan 02, 2009 | Super Tutor Trigonometry (ESDTRIG) for PC
Finding the length of a triangle
might try
(54tan)/45
I don't have a calc that will do it or I would try it and see.
Jul 31, 2008 | Office Equipment & Supplies
Sos Snow Devils Down Hill Ski/Snowboard Metallic Googles/Eyewear w/PC 2.0mm Logo
391 people viewed this question
Top Sos Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Sos Winter Sport Expert? Answer questions, earn points and help others
