Question about Scotsman Ice Maker CM3 30inW Cubed Ice Machine 900LB
My scotman model sce170a1a.goes into harvest to
My scotman model sce170a1a.goes into harvest to fast befor it makes ices .it goes about every 3 minutes
  • Scotsman Master
  • 8,220 Answers
That has to be a faulty control wouldn't you think?
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
Posted on Feb 04, 2010
My hoshizaki ice machine KM-900mrf model beeps 3 times and stop making ice. After reset it starts, but stats beeping again after an hour.
Have a look at the side of the evaporator; there is a probe (thermistor) attached to it that tells the control board when to initiate the harvest cycle. make sure it's clean and attached properly and doesn't need replacing. If hitting the float switch initiates the harvest cycle it sounds like you have a blocked/ scaled water tube or switch housing. take off the bottom of the switch assembly (black rubber bit) and clean through to the water chamber. run a cycle of descaler before trying again.
Jul 04, 2015 | Hoshizaki Freezer Commercial Ice Machines...
HOW DOES A MODEL 315P ICE MACHINE GO INTO HARVEST?
The ice machine has a HARVEST TIMER. You can adjust the harvest time, it comes from the factory for 3 minutes. You should not have to adjust it 3 minutes is plenty of time if every thing is working right. If the machine is operating making ice but not falling in storage bin then check these possible cause.
1. ICE may be stuck in the evaporator and the unit is " frozen up "
POSSIBLE SOLUTION: Clean and sanitize.
Possible Cause: Harvest time set too short - timer needs adjustment.
2. Harvest timer bad: replace harvest timer.
Jun 24, 2014 | Kitchen Appliances - Others
WHY scotsman iec machine shuts down on the refridgeration light ON CM3 CONT
Is the machine producing ice thick enough to come off the evaporator plate? the machine will try to harvest 3 times before it locks out on long harvest. Harvest cycle: The compressor and hot gas valve are both powered during the harvest cycle. The fan and pump are off at this time. The machine stays in the harvest cycle until the evaporator thermistor senses 52 DEG F. If the bin is not full, the unit goes into another freeze cycle. I would check the Thermistor
May 28, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
Why my scotsman ice machine goes off on the refridgertion light
This could be several things. This means it has tried to harvest the ice 3 consecutive times before the machine has locked out.
1. Likely Cause, Ice bridge thickness too small, not enough ice to open curtain. PROBABLE SOLUTION, Check and adjust if needed.
2. LIKELY CAUSE, ice bridge too large, ice frozen to evaporator frame. PROBABLE SOLUTION, Check and adjust if needed.
3. LIKELY CAUSE, Purge valve does not open, water melts ice bridge, not enough ice to open curtain. PROBABLE SOLUTION, Check purge valve during harvest.
4. LIKELY CAUSE, incomplete ice formation. PROBABLE SOLUTION, Check water distributor for partially plugged holes. The machine needs to be cleaned and sanitized every 6 months.
5. LIKELY CAUSE, Curtain out of position. PROBABLE SOLUTION, check curtain for swing restriction.
6. LIKELY CAUSE, Curtain switch dose not open when curtain does. PROBABLE SOLUTION, Check switch with ohmmeter if bad replace.
7. LIKELY CAUSE. Machine in very cold ambient. PROBABLE SOLUTION. Move machine to a warmer location.
8. LIKELY CAUSE. Hot gas valve does not open during harvest. PROBABLE SOLUTION. Check hot gas valve with a volt meter during harvest mode to see if you are getting correct voltage to it. If not then replace control board . IF yes and valve is not opening then replace valve.
9. LIKELY CAUSE. Harvest assist probe out of position - ejector pin not retracted. PROBABLE SOLUTION. Check harvest assist mechanism - spring should retract pin.
10. LIKELY CAUSE. Damaged evaporator. PROBABLE SOLUTION. Check evaporator surface. Make sure the plates where they intercept each other is not loose this will cause ice to hang up. check to make sure the nickel is not peeling off, if so then the plate will need to be replaced.
11. LIKELY CAUSE. Fan motor stays on during harvest. PROBABLE SOLUTION. Check controller using test mode. If this dose not help you then give me the model number so i know what machine you have.
May 28, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman ice machine is not making ice goes through the motions but no ice
h=harvest 2=harvest problem 8=makes ice to fast 0=off.most common issue is your senors/ice mach needs to be descaled and clean
Feb 25, 2014 | Kitchen Appliances - Others
Model CME256AS-1D will not go back into freeze cycle and will eventually stop, requiring the unit to be reset.
So is the unit going into a harvest and not going back to a freeze cycle? dose it dump a batch of ice but wont go back into a freeze cycle? before you reset it have you pulled the front cover to see what code it is giving? any time you have to reset it that means it locked its self out on a fault. if unit freezes and go's into a harvest and dumps the ice but dose not go back into freeze cycle check the door switch when the ice dumps the deflector door opens a magnetic switch which tells the board the harvest has finished and then the freeze cycle begins. Now if there is no ice falling off the plate to open the door then the board will time out and try 3 more times to make ice before it locks it out. the same go's for the harvest.
Jan 08, 2014 | Scotsman Cooled Modular Contour Cuber Air...
It will not stay in harvest cycle long enough to make ice before it goes into defrost
First it has to go through freeze cycle then harvest cycle to drop ice then back to freeze cycle. If you have never worked on ice machines before you should call a service company.
Aug 16, 2013 | Manitowoc QY-0214A Self Contained Ice...
I have a hoshizaki ice machine and it will harvest for about 3 harvest and just before the 3 harvest it shuts off. It makes us up untill it shuts off. It beeps 3 times. DONT know what to do! NEED SOME...
How long is a freeze cycle on your unit? How big are the cubes that it's dropping? The three beep error indicates that the unit exceeded maximum freeze time.
Sep 05, 2010 | Hoshizaki KML-600M Low-Profile Crescent...
Kitchen Appliances - Others Logo
585 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
