Hitachi TV I have a 36" Hitachi Dual-Tuner TV (36fx48b). In the back, it has three coax connections. A - for cable, B - for cable (so I can get PIP) and one for converter that I never used. My problem is that the B coax connection came out and was lost. I don't know where to go from here. I have been to Hitachi's website (useless) and I do not want to call an expensive repairperson, I just need help finding out, well, what is the technical term for this part and then locate the part number at the best price. Can you help?
4 Suggested Answers
MikeNJ1964
  • 398 Answers
SOURCE: Need help with PIP
When you go into the menu to choose the PIP source the PIP comes on to confirm that a valid source has been selected. It is normal for the PIP to close when the menu is exited. To display the PIP normally you will need a remote with a PIP button. Most universal remotes today have PIP functions but if you get a Zenith original replacement then you are guaranteed to enjoy the other PIP features such as size, position, freeze and swap.
Posted on Jul 27, 2007
pgh_pa_guy
  • 2992 Answers
SOURCE: how to connect tv set to digial tv tuner converter box
There are two ways to connect a converter box.
The simplest is to use the RF antenna cable supplied with the converter. Connect it from the box (the round threaded connector) to the TV's antenna/cable input connector and put the TV on channel 3 or 4 (whichever the converter box is set to). If your set has screw terminals for the antenna connection, you'll need an adapter to switch from the round cable connection to the screws. This may also have been supplied, but you'll probably need to pick one up at Radio Shack or another retailer.
The other way, if your TV has the inputs, is to use the audio/video output jacks on the converter. Again, the cable is usually supplied with the box. This direct connection gives better picture and sound quality than the RF method. The jacks are color coded: red and white for the audio right and left channels, yellow for video. Just connect them to the matching jacks on the TV and select the video input to watch the box. (If your TV is mono and has only a single white audio input jack, you'll need a Y-adapter to join the two audio signals from the box into one. This is also available at Radio Shack. If you don't do this, you'll only get one channel of the sound when watching a stereo channel.)
Please take a moment to rate this solution if you found it satisfactory. Thanks for asking!
Posted on Feb 11, 2009
  • 5 Answers
SOURCE: RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
Posted on Dec 26, 2009
Cannot recieve pitcure from dvr
can be inside the systemcable
Jan 06, 2014 | Hitachi 36FX48B 36" TV
I have sound no picture
No sound - no picture ? that's mean no power at all ? check fuse and power supply - mostly transistor faulty in primary section or the BU Transitor in the high voltage section
Oct 28, 2013 | Hitachi 36FX48B 36" TV
I have a model 36fx48b 1998 hitachi that simply stopped turning on. we watched it last night and turned it off to go to bed then the next day when we wanted to watch it it wouldnt turn on...instead it...
Only serviceman can repaired that problem, It depend on the damage spare parts but usually the labor cost is uniform or fix. The spare parts makes it high in price. lets hope that this part will not be hard to find nowadays. But technician can substitute the part if he is competence. Probably your problem would be power supply or H-out
Aug 15, 2011 | Hitachi 36FX48B 36" TV
No sound...We moved the TV from one place to another and lost our sound... I have a multiviewer 4 dual tuner PIP
Try to check the cables specially the input, output of your digital receiver specially the audio cable. Good day and best regards.
Aug 07, 2011 | Hitachi Televison & Video
Can't get PIP to work on my Samsung LCD 46"
its talking about the analog tuner in your tv. split the cable before it hits the box plug the cable strait into your tv if there is more than one coax connector on your tv you will need a second two way splitter run one into ant a and one into ant b yo will not be able to use pip and hd at same time you can only do pip with the analog tuners built into you tv
Mar 17, 2009 | Zenith Z36X31D TV
Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
Jan 29, 2009 | Hitachi 42HDF52 Television
Cable adaptor stripped
F/U guys... You advertise free solutions and then try and hose me on "premium Service" I'll find the adaptor on my own and would never consider sharing it with you you lazy bastards
Jan 03, 2009 | Hitachi 36UDX10S 36" TV
Picture in picture problem
When you use the Time Warner Digital box, you're using the tuner inside that box rather than the tuner inside your TV to select a channel. Picture in picture TV's have two tuner's inside so you can view two channels, but they can only tune the analog channels from your cable company, and only if it's hooked up in a manner that will permit this to happen.
So you only have one digital tuner (the Time Warner Box) so you can only view one channel at a time even though your TV supports Picture in Picture.
It MAY be possible to have limited use of the PIP if you connect your TV in a different way. Your Time Warner box is most likely connected to your TV set with composite cables, those are the Yellow, Red, White cables. If you buy a coaxial cable splitter and split the cable before it goes into the Time Warner box you can then run a coax cable into both the Time Warner box and the coax input on your TV. This would allow you to tune the analog Time Warner channels with both of your TV's tuners. In my area I think the first 60 channels or so are still available in analog, but there is no way to watch any of the higher premium channels without the Time Warner box.
If you go through these steps and you select the coax input on your TV your PIP will work on the lower channels. It MAY be possible to tell your TV to display the input from the composite cables on one of the PIP screens and the input from the coax on the other, but I kind of doubt it.
I know this sounds complicated and if you're not familiar with the way all this works it is complicated. The reason lots of people won't respond to this kind of question on this site is because there is no easy fix and by trying to help I run the risk of getting a bad rating. I don't get paid for this, I just like trying to help, so if I have not explained this in a way that's helpful to you please ask some additional questions before you give me a bad rating. Thanks.
Jan 01, 2008 | Panasonic CT-32D31 32" TV
PIP
Split incoming signal = half to each tuner ( RF coax in ) or
half to RF in and half to DVR, cable box or VCR tuner then to
Video input..........................
Download manual at www.HitachiServiceUSA.com.........T.
Nov 09, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
