Question about Texas Instruments TI-84 Plus Calculator
When i try to graph anything it says err: invalid dim
  • Texas Instru... Master
  • 7,993 Answers
The solution for this problem is simple. When you use the calculator to create statistical graphs, it is configured to accommodate the specificities of the problem. However that configuration remains set after you terminate the problem. So when you try to use the calculator to do other problems it uses the stored configuration parameters, which may be incompatible with the new problem.
In particular, list of paired-variables must have the same dimensions: There must be the same number of elements in each list.
To make a long story short, you should make it a habit to reset the Ram every time you want to do a new problem. If for reasons of you own you do not want to reset the Ram, you can prevent this type of errors from occurring. This is how you do it.
  1. Press [2nd][Y=] (STATPLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
  3. Press [2nd][0] (CATALOG)
  4. Press [PGRM] (C) to jump to first command that starts with c.
  5. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  6. Calculator displays Done
  7. Start the new problem
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
Posted on Feb 04, 2010
When I try to graph it says-ERR:INVALID DIM 1:QUIT
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Nov 01, 2013 | Texas Instruments TI-83 Plus Calculator
When I press graph, it says "ERR: INVALID DIM" how
Jan 14, 2011 | Texas Instruments TI-84 Plus Calculator
Why do I get an ERR: Invalid Dim 1:Quit Whenever I hit the graph key?
If this doesn't do it, could you post the exact function you're trying to graph?
Nov 16, 2010 | Texas Instruments TI-83 Plus Calculator
Every time I try to graph on TI 84 it says ERR: INVALID DIM 1:QUIT I have enterered something simple y= x+2 and window is set for -10<x<10 and -10<y<10 the curser in y=...
Go to http://education.ti.com/downloads/guidebooks/graphing/84p/TI84Plus_guidebook_EN.pdf to download the manual. On page 401, you will find the following:
INVALID DIM • The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff. • You specified a list dimension as something other than an integer between 1 and 999. • You specified a matrix dimension as something other than an integer between 1 and 99. • You attempted to invert a matrix that is not square.
Nov 11, 2010 | Texas Instruments TI-84 Plus Calculator
When I graph, it shows "ERR: INVALID DIM 1:QUIT"
Oct 28, 2010 | Texas Instruments TI-84 Plus Silver...
Getting ERR: INVALID DIM when pressing the Graph button
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.If the message appears in another context, it sure would help knowing the context of the error.
May 12, 2010 | Texas Instruments TI-84 Plus Calculator
When trying to graph anything, ERR: INVALID DIM appears..
The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-84 Plus Silver...
My graphing calculator won't graph anything
Go to your stat plot screen, and select option 4 (PlotsOff), Press Enter, and try to plot a normal graph again
Jul 07, 2009 | Texas Instruments TI-84 Plus Calculator
ERR:INVALID DIM
Apr 20, 2009 | Texas Instruments TI-83 Plus Calculator
I need help with graphing everytime i try to draw a graph it comes up with this ERR:INVALID DIM what does that mean
It means that your Xmin or Xmax is messed up. it often shows up when you are plotting somethings (histogram for exanple) and you don't have enough X or Y range to fit all the points in it. it also happens when you are multiplying matricies without using the right dimensions. ERR:INVALID DIM just means your dimension is invalid.
Mar 06, 2009 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
166 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
