Question about GE (PSS26MSRSS) Side by Side Refrigerator
Our freezer leaks water on the floor. Looks like
Our freezer leaks water on the floor. Looks like the water is actually coming out of the freezer. not from below. It leaks a small puddle at a time. Maybe once per day.
    New Friend:
I had the same problem, and the solution is that the drain valve was plugged. On my unit, I removed the lower back panel and started cleaning. It was filthy, and I don't think it had been cleaned for 8 years or so. Anyway, there is a drain hose that releases into a flat pan. The pan is really long and weaves its way through the all the other components under the fridge. It is designed to increase surface area and allow the defrosted water to evaporate. Anyway, the drain hose into that pan was plugged. I just removed it from the point of connection to the drain and blew into it (from upstream) and that dislodged the dirt plugging it up. My system allowed relatively easy access, but I would guess some designs might be pretty tricky. Also, make sure you have some towels standing by because when you remove the drain hose, all the backed up water will come streaming out. This was a surprisingly easy job, and only took about 30 minutes total. The main work was vacuuming all the dirt. The lesson learned is that this should be done every few months. Also, a lot of the insulation around the components had pretty much disintegrated, so that was more clean up, and I imagine there might be some issues now with efficiency and maybe hot or uneven spots in the fridge itself.
Posted on Nov 11, 2012
  • 52 Answers
I'd check the seal around the freezer to see if there are any leaks first. You can check if the fridge has a energy saver switch that helps with condensation.
Posted on Feb 06, 2010
We have got water coming out at the bottom of the freezer of our fridgidair FRC170FF how do i fix it?
1. Your freezer may be not cold enough so water does not freeze.
2. Your freezer may leak so warm air goes into the freezer and keep the temperature higher than freezing temperature.
Jul 03, 2014 | Miele KFN8762SDED Bottom Freezer...
Water leaking onto the kicthen floor from my frost free fridge freezer
The drain inside the cabinet may be clogged. Sometimes the flimsy plastic evaporation pan inside the bottom under the cabinet cracks or overflows.
Feb 15, 2018 | Beko Refrigerators
Water is leaking on the floor, looks like it is coming from the freezer side underneath. What could be the problem?
This is a common problem that happens when the defrost drain becomes clogged with ice or gunk. Click Here=> Leaking Refrigerator's Just What May Be HappeningOnce you look over that page Please Click Here=> Leaking Refrigerators Should you have problems or would like to ask me questions I will be here or here=> appl...@yahoo.com Thank You, Sea Breeze
Feb 16, 2012 | Refrigerators
My Maytag wide by side is leaking water from the
Yes. Your defrost drain hole in the lower rear of the freezer is frozen over with ice. Turn off the fridge. Remove the shelves and bins from the freezer side. Break up any ice on the floor of the freezer and dispose of it. Use a hair dryer to melt the ice over the drain hole in the rear portion of the freezer. Once it is clear pour a 1/4 cup of bleach into the drain hole.
Dec 20, 2009 | Refrigerators
Freezer leaking around drain plug
hello!
the drain plug is loosening if equiped with a housing nut try to rotatate nut to tighten the drain plug,if has no lock nut have it weld by glue gun to hold tight fit your drain plug.have a nice day
May 05, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water runs out of freezer door overnight ,at times
Have a look at this link:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/7670-leaks-water-floor-front-freezer.html
or this one:
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Apr 17, 2009 | Westinghouse Refrigerators
Accumulation of water in bottom of fridge
You probably need a new door deal for the freezer. When you cet too much condensation in the freezer, it drains down the back of the refrigerator section during the defrost cycle. Check under the produce bins for a drain. If you don't have one, you're not alone. I used to have have to wipe mine out every other day until I finally replaced the seal.
Feb 02, 2009 | Frigidaire FRT21G4B Top Freezer...
Frigidaire Side-By-Side Refrigerator Leaks Water on Floor
I don't have the same refrigerator, but had a similar issue with a GE. Melt the ice at the bottom of the freezer. I think the water comes from the auto defrost feature. There should be a hole at the back bottom of the freezer that water would go into, and run to an evaporator pan under the refrigerator. The tube may be blocked that allows this water to drain, so it is backing up in the bottom of the freezer, and overflowing through the front bottom of the freezer to your floor.
Sep 28, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
329 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
