Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
My printer KodakESP3 will not print black properly I have made many atempts to clean the head but it still streaks on the test page, Do I need a new print head? If so wher can I get one? Thank you .Norb
I may get a new printer and it will not be a Kodak. They haven't shown me much in coustermer service,
Posted on Feb 04, 2010
My printer is not working properly. On the test page, not every line prints clearly.....faint and grey compared to other lines. Lines 1, 4, 8, ll, 14, etc. prints very light compared to the other lines. ...
sounds like your heads are all gummed up with dried ink.Is this a older printer or previously used if so run the cleaner that should have come with your printer software. keep running it until clean or bring it to get cleaned.
Feb 22, 2011 | Computers & Internet
When I try to print, a large black vertical streak runs on the right side of the page, in the same place every time Sometimes the streak is a small line, other times it is very black and is 2 inches...
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Dec 31, 2010 | Brother MFC-8840D All-In-One Laser Printer
I replace my Black ink with new and it will print only a few times then the black streaks and then stops working. I clean the heads and it don,t help. Change to another new black ...same thing print a few...
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 04, 2010 | Kodak 5300 All-in-One InkJet Printer
Ink is printing streaky, but this is my second brand new ink cartridge. Any suggestions?
this symptom signals blocked printhead, you need to do bit of cleaning, not necessarily cahnge the cartridge.
follow this procedure:
1. download test page with alternative from this site black:
http://www.inkjetcartridges.com/_black-print-test.html
and colour:
http://www.inkjetcartridges.com/_color-print-test.html
2. print page each and assess the colour and streaks. if on the beginnig of the page you do have errors and on the bottom all is corrected, this meant that you just cleaned your printhead nozzles and problem is solved.
3, if problem persist, from stationery store purchase few pages of absorbent paper, weight of about 120 to 160, do not use thicker than 160 and print these colour pages again,
4. print control page again and see if any improvement was made, if there were no changes, follow this procedure:
a. remove cartridges from craddle
b. determine what is ink solvent, water, isopropyl alcohol or methylated alcohol - correct solvent will be that which do not precipitate or curdle the ink
c. touch with absorbent tissuebottom of the cartridge and check if it is leaving even print, if not, whipe once with solvent
d. put a drop of solvent on gold/silver buttons inside of the craddle, allow to sink for about a minute, whipe off with absorbent tissue
e. put again a drop of solvent on the button in the craddle and insert ink cartridge
f. print test page, page will be very weak on the top (solvent print first!) and improve as it prints down, if necessary, print again colour or black test page from 1.
this should solve your streaking head problems, if they still persist, this meant that print heads are really well blocked by caked ink and usually is cheaper to change printer than change the head in it...
if you find this advice useful, please do not hesitate to leafe your feedback and vote for me, thanx!
Jul 31, 2010 | Canon PIXMA MP470 All-in-One Printer
I have a HP Photosmart C5200 - pages are printing pink and red streaks in pictures
the print head for magenta and cyan (might be also Yellow) is dirty. you can try to clean it with warm water, or replace a new print head.
Jul 31, 2009 | HP PhotoSmart InkJet Printer
There is a white vertical streak on pages I print.
You can pull out each cartridge and shake it gently to redistribute the toner. Try a half page test to eliminate the various stages of the image formation. The timing on this is not easy but through trial and error it can be helpful.
Jun 25, 2009 | Cannon MULTIPASS C530 Printer
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Streaks on photo sensitive drum HP laserjet 5MP
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 28, 2009 | HP LaserJet 5p Printer
Streaks / Bands of broken print area
First with a clean soft cloth and a very small amt of alcohol clean off the underside of the printer carridge (the holder for the print heads) also where the print heads cleaning station is clean out any large masses of congealed link. Then remove the ink cartridge in question and with a pencil eraser gently rub the contacts and both the cartridge and the carridge replace the cartridge. Using the software tools for the printer clean and align the printheads ( if there is an option to do so). If this dosn't fix the problem try a different ink cartridge.
Sep 04, 2007 | HP OfficeJet Pro k550 Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
312 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
