Question about Electrolux Vacuums
Removing motor from electrolux vacuum D725 - Electrolux Vacuums
  • 1 more comment
  • e_swift Feb 04, 2010
    Further, the vacuum is stripped down, but I am having trouble releasing the motor suspension bracket from the rear of the barrel casing - it feels like it is held in by internal lugs, but even moderately severe barrel distortion/levering is not releasing them - suggestions?
  • e_swift May 25, 2010
    Perfect - worked a treat - thanks!
    Excellent - worked a treat - thanks beales
When viewing from the rear there are small protrusions at 2 & 4 o'clock on one side and 8 & 10 o'clock on the other side of the motor suspension bracket. These are hooked behind an internal ridge in the barrel. On one side the barrel must be expanded at these points and the motor suspension bracket will pop out on that side under the action of the support spring on the end of the motor. There is a special tool for this but it can be achieved as below.
You will need two screwdrivers smallish but still strong/stiff enough.
At the 3 o'clock position insert one screwdriver from the rear between the barrel & the plastic motor bracket. Lever against the plastic bracket using the tip to expand the barrel outwards. Make sure the screwdriver is inserted far enough until the tip is against the ridge in the barrel. The stiffness of the ridge will keep distortion of the barrel to a minimum. Insert a second screwdriver at the same point. Keep levering the barrel outwards far enough so that the second can be pushed past the ridge holding the barrel outwards. Remove the first screwdriver and lever the barrel outwards working towards the 2 & 4 o’clock positions until the bracket pops out on that side. The other side then will also be free.
Posted on May 25, 2010
Testimonial: "Excellent solution - your precise level of detail worked a treat. Very much appreciated beales - thanks heaps"
Where do I get Electrolux motor in south Africa?
A local rewind or motor repair might prove more convenient and perhaps cheaper but Electrolux service is available in South Africa
Electrolux South Africa ' Home Appliances and Household Appliances
www.electrolux.co.za/
Welcome to Electrolux South Africa. Discover our range of ... Enter your postcode, town or city to find your nearest authorised dealer. Translation missing for ...
May 03, 2016 | Electrolux Vacuums
New bag indicator will not reset causing bare floor mode not to work at all and mode 2 not to vacuum dirt properly
Your top motor (suction motor) isn't running. Your vacuum has two motors in it. The top motor is the suction motor that runs on the first switch position and the bottom motor (brush motor) turns on with the second possition.
It could be the switch.If it isn't the switch, the only other thing it could be is the motor itself.
To check the switch, unplug the vacuum and then take the three screws out of the back of the handle. If you are comfortable with electricity, jump the black wire and the blue wire togeather and plug the vacuum into a electrical outlet. If the motor dosen't run, the problem is with the motor. If the motor runs, the switch is bad and needs to be replaced. You can get one at most any vacuum shop.
The motor could be bad or the carbon brushes can be stuck with dust. This is more involved and I recomend taking the vacuum to a vac shop that works on the "old" Electrolux vacuums. The new name for the "old" Electrolux is now Aerus Lux but you would probably get it repaired less expensively at another vacuum shop.
If you want to go into the motor housing you'll have to take the big screw out of the back of the handle and pull up on the handle to remove it. Next, remove the four screws holding the top half (motor housing) of the vacuum. Two screws on the back and two screws to the front inside of the bag housing. You'll need a long #2 phillips screw driver. Then pull up on the bag housing with a side to side motion.
With the housing removed, you will see the motor and can lift it out.
Check for any bad winding. You can smell them to check if you can't tell by looking at them. If they are burned, you will need to replace the motor.
To check the brushes, you will need a 5/16th" socket to remove the two bolts on the top of the motor and lift the top bracket with the carbon brushes off and see if the brushes move freely. If not moving or not long enough to touch the top part of the motor with the copper bars (the comutator) it would be best to replace the motor.
To reassemble the vac just reverse.
This is a long and difficult prosedure and I reccomend that you take the vacuum to a repair shop that works on the Electrolux.
Feb 09, 2014 | Electrolux Vacuums
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
How do I gain access to the motor of an Electrolux 2000 canister vacuum. The air intake on the motor must be partially blocked as there is a loss of suction and the motor makes that high pitched whine like...
Dismantling the vacuum probably won't help much, and reassembling can be a bear.
To check the intake, remove bag and look into bottom of bag well. It there's a filter there, remove it and check intake at bottom of bag well. Clear if there is.
The afterfilter on a canister is located beneath the air diffuser grid on the top of the machine where the tools can be attached. Remove this cover and there should be a white filter. Yours is probably black, or at least real dirty, if it's never been changed. This also blocks the airflow, reducing suction, and potentially damaging the motor. Extremely dirty filters are an indicator of how much dust is getting into and through the motor. This is usually caused by using generic bags rather than the genuine Electrolux, now Aerus, bags.
It is also an indicator of another internal problem on some other Aerus and pre-Aerus Electrolux vacuums.
Sep 10, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Disassemble electrolux olympia one vacuum.
Four nuts in rear housing, deep inside. Motor slides out after they are removed.
Jan 17, 2010 | Electrolux Vacuums
How is the motor cover removed?
Two screws at the front, accessed by opening the dust bag lid. Two screws at the rear accessed by prising off the on/off switch and rewind button covers.
Jan 05, 2010 | Electrolux Vacuums
How to remove the motor cover?
There are 2 screw under the removable outlet cover and 2 more under the shiny label under the booster slider. Pick off the label to find them.
Dec 05, 2009 | Electrolux Vacuums
Sparks in the el. motor of Electrolux Canister.
check the wiring it might have gone bad
Jul 07, 2009 | Vacuums
Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Vacuums
Vacuums Logo
285 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
