Question about Estate Dryers
I have an Estate model TGDS680EQ0 gas dryer that stopped drying; it tumbles but there's no heat
  • cbulajic Feb 04, 2010
    I need step by step insturctions on troubleshooting my dryer problem
    President:
  • 1,218 Answers
Good day,
There are many reasons for no heat. You will need an ohm meter for most testing. I'll assume, the gas is turned on.
First remove, the back cover. There are usually 4 thermostats mounted on the rear housing.
One in particular to test first, is a skinny white Bakelite device near the center bottom. It is held in with one screw. Remove one wire, and check for continuity. It should read zero ohms resistance. If not, replace. This component accounts for about 80% of all no heat call problems, on your model.
As well, there are other thermostats, round or rectangular in this area, they should all read zero ohms. if no issues here then....
You will have to access the front of the dryer by removing the front panel.
A tutorial is included at the bottom.
You will see a gas valve, mounted on the bottom left. There is an igniter mounted forward of the valve itself extending into the burning tube. It has 2 wires attached. Unplug, and check the resistance of the igniter. It should read around 20 to 30 ohms. If it reads infinity (no resistance) then it is burned out and needs replaced.
On the gas valve itself, are 2 black coils, held on with a 2 screw bracket. They can short out. The meter cannot properly test them, but if they are bad, you will hear the ignition click on every few minutes, with the igniter coming on but no ignition.
It is a common item to fail, as the igniter, and the white device in the back are.
These are the common items, and account for 99% of all no heat complaints. There are others, such as the heat selector switch, timer, Thermal sensor mounted on the side of the heat tube, and the centrifugal switch in the main motor, but are very rare.
This tutorial does not apply to heating problems. It's to show how to access the front.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Posted on Feb 04, 2010
  • Estate Master
  • 8,220 Answers
The fuse is mounted next to the control thermostat on the blower housing. Looks like this: I have an Estate model - 51d8ebf.jpgIf it is open no power will be sent to the gas assembly. Be sure to clear all lint and air restrictions or this fuse will continue to blow. I have repair photos HERE
  • 6 more comments
  • Dan Webster
    Dan Webster Feb 04, 2010
    The way it works is simple, drum air temp continually passes over the control thermostat mounted on the blower housing. The cold thermostat sends power to the gas assembly, the flame sensor allows power to fire up the ignitor and open the gas coils. The ignitor hogs the power so the coils cannot open the valve. When the heat from the ignitor causes the bimetal inside the flame sensor to buckle it opens contacts and kills power to the ignitor. The rush of power yanks up the coils,the raw gas comes out and hits the screaming hot ignitor and you have heat!. When the temp reaches 160f the control opens contacts and power is cut to the gas assembly. If an air restriction stagnates air in the drum and the temp rapidly rises to 350f then the fuse next to the control melts and kills power to the gas assembly. But the dryer stays running to bring back down the temps in the dryer so the clothes won't be harmed.
  • Dan Webster
    I first check the fuse on the blower housing for continuity. If that is good then the next thing I check is the ignitor. If that is good I check the flame switch.
  • Dan Webster
    I have an old school repair manual HERE
  • Dan Webster
    Newer Manual
  • Dan Webster
    GAs and Electric models with moisture sensing HERE
  • Dan Webster
    Check for 240VAC. (electric dryer)
    Check heater continuity, (8-12 ohms).
    Check for voltage (120VAC) to burner
    assembly.
    Check ignitor continuity.
    Check for gas supply.
    Check flame switch continuity, (0 ohms
    when cold).
    Check gas valves for continuity.
    Check thermostat for continuity.
    Check for continuity.
    Manually close centrifugal switch contacts,
    check for continuity, (1M-2M ohms).
  • Dan Webster
    Thermostat
    Thermal cut-off, Hi-limit
    thermostat
    Motor centrifugal switch
  • Dan Webster
    Check lint filter, blower housing, internal
    and external ducting and exhaust hood.
How to assemble belt
Hello Denise, I have seen this problem many times. The sneakers by themselves in the dryer cause a shock effect , when the weight of the sneakers tumbling onto the drum overloads the skinny belt and the belt breaks every time. Usually. if you dry the sneakers along with other clothes or towels this will not happen.
Feb 27, 2014 | Estate TEDS840JQ Electric Dryer
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Dryer tumbles the clothes not drying it leaving it wet
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 30, 2011 | Estate TEDX640JQ Electric Dryer
Estate TGDS680EQ3 gas dryer blows cold
The timer is stripped inside and needs to be replaced. The cogged teeth are made of plastic and a tooth or two has broken off keeping the timer from moving while running
Jul 16, 2010 | Estate TGDS680EQ Dryer
Kenmore dryer thats not drying
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | Dryers
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
Does not dry completely
how well did you clean that duct, the duct is problem 90% of the time when the dryer does everything else, pretty much if the dryer heats and tumbles its doing its job
May 04, 2009 | Dryers
Dry runs, but does not heat up
dude I just came here to find the same answer with my Maytag dryer! Just 10 seconds ago!
Apr 04, 2009 | Frigidaire GLGR331A Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
No heat
mcwilliams if you pull the over off the front of the dryer at the bottom you can see the gas burner assy. Put the dryer on time dry and start the dryer, you should see a glow from the ignitor, then hear a click, then the heat come on. In the auto dry mode, the timer advances along with the dryness level. No heat, No timer advancing. If you don't see a glow, there should be a thermosat on the heater can, see if it is tripped. If so if it is resetable, reset then try again. You may have a bad ignitor.
Feb 03, 2008 | Estate TGDX640JQ Gas Dryer
Dryers Logo
133 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
