Question about Frigidaire Washing Machines
Gentle Annie wont pump out water
My Gentle Annie washing machine by F & P wont pump out the water. Can you please help. Erin
  • Kerry Sinclair Apr 27, 2013
    Fisher and Paykel gentle Annie washing machine waste water hose has split where it passes through rear of washing machine, how do you replace the hose, purchase spare parts
I had the same issue with mine and the coil windings for the pump out motor had rubbed though. I unwound it a little and re crimped a new spade terminal to the end. Works perfect for the last year or so !
Posted on Dec 04, 2012
  • 129 Answers
Could have a sock in pump vac and towel needed unplug empty water remove drain hose shop vac pump and both hoses turn on to see if pump motor runs
Posted on Feb 04, 2010
Ecs gentle annie
Is it just the cold valve slow do you have a hot valve to swap it with to check the flow rate.
I think there 12volt valves,
The solenoids would be OK just the valve wont open all the way.
The solenoids do come off with a flat blade screwdriver under the solenoid.
Dec 17, 2013 | Fisher and Paykel GWL11 Top Load Washer
Gentle annie
The fill switch may have failed or the tube to it broke. Anyway, the machine probably is too full of water for it to start to spin out, so it slips on the belt and that makes noise.
The machine is going to be very heavy if it is overfull, but try to let some water out. Maybe you can just lower the drain hose way down into a bucket and get some water out of it. Once it's low enough, it may be able to pump out the rest. Then you can find out about the fill switch.
If it's not overfull, then some hose came loose or broke.
Nov 25, 2013 | Washing Machines
Remove agitator gentle annie ECS
the is actuallt a special spanner for it which is now unavailable
Dec 19, 2012 | Fisher and Paykel Washing Machines
Hi Experts, I have a 1988? Fisher & Paykel GW51F top loading washing machine, and last week during the spin cycle, instead of draining & spinning, it just hummed for a few secs (draining, I...
Hi just read your posting.Is this machine a Gentle Annie model?Does the machine drain at all?The web address to watch the video of your machine does not work.Please reply with correct address and the name of your machine and I am sure I can help you.Looking forward to your reply.
Sep 20, 2010 | Washing Machines
Fisher & Paykel Gentle Annie washing screeching sound
remove drive belt.check 2 see if main drive pulley turns freely.check to see if motor turns freely. could b belt. what country r u in . parts hard 2 get in australia. please reply 4 more help. please turn off power b4 u work on it. do not want any accidents.good luck
Apr 04, 2010 | Washing Machines
I have a Fisher and Paykel ECS Gentle Annie GW52-k
Make sure there is voltage going to the valve solenoids. That is what opens up and lets water into the washer. You will have to open up the top of the washer control. The valve assembly is where the hoses screw in the back. I don't have the technical on it but most likely should be 120V. Sometimes the valve goes bad and won't open up.
Feb 17, 2010 | Washing Machines
Hi.I have a Gentle Annie that starts and stops filling with water
It is most likely the lid switch. The switch sits in a plastic bracket which has a lever coming down behind the tank.
If the tank sways and hits that lever, it cuts off the cycle as a safety measure. When the switch is faulty or more often when the plastic bracket breaks, you get this symptom.
Let me know if you need more assistance.
Ash
Oct 22, 2009 | Fisher Washing Machines
F&P ECS Gentle Annie, Frigidaire & Kelvinator model compatibility
Almost all parts are interchangeable- Gentle Annie and Frigidaire are all the same machines- only parts different are main power board in base of machine, and display board- everything else the same. Motors are interchangeable, as long as the plug connection is the same- there are two different types of plug connection (ie male and female plugs are opposite ways around).
Aug 26, 2009 | Frigidaire Washing Machines
Gentle annie motor wiring
This according to googled results, and somewhat verified by me:
For the Gentle Annie connect the white/orange/green wires together to from a
star point and the three other ends (red, yellow & blue) go to your 3 phase
rectifier.
You can leave the others hanging. Don't form the star point with the wire
that's green with a yellow stripe, that's the chassis earth. The brown,
purple, and brown with black stripe I think are sensing coils, with a star
point connected to the black wire. 1.4ohm each, whereas the main coils are
4.8ohm and apparently rated for 5A.
Dec 20, 2008 | Fisher and Paykel Washing Machines
Washing Machines Logo
375 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
