Canon EOS 40D Digital Camera
Problem for Canon EOS 40D Digital Camera
Error 99 Code on 5 month old Canon 40D
By KAPphotos on Feb 20, 2008
My 40d froze up during an all day soccer shoot last saturday. I was shoting with the 100-400 Canon IS L lens. I turned the camera on and off, removed and replaced the batteiries, tired different lenses, change memory cards and still the dreaded "Error 99 Code". Please help!
Return email:
info@KAPphotos.com
Thank you.
Comments:
Feb 20, 2008
- I tried the eraser trick already. No luck. I will try your other solution.
Thanks,
KB
Same Problem
Dec 28, 2008
-   Error 99 Code on Canon 40D occurs always at temperatures about 8 celsius or lower -   muletrain
Best Solution
posted on Feb 20, 2008
Very Helpful)
amsatnetg
Rank: Master
Rating: 92%, 16 votes
error 99 can be several things. Try the following. Check that the contacts on the lens housing are clean if not clean them with a swab of denatured alcohol available at walmart. also if there is extremely cold weather your shutter could be creating the error. Try using a blow dryer and on the warm setting warm up the camera with the lens off. Blow around the mirror area. I know it sounds silly but it has worked in the past. Good luck.
Was this helpful?
Yes
No
Popular Solutions for Canon EOS 40D Digital Camera
Questions and Unsolved Problems for Canon EOS 40D Digital Camera
Do you recommend Canon EOS 40D Digital Camera?
Answer
Answer
40d camera got damp...now lcd not working...after a few shots shutter stops working , flash strobes... (More)
Answer
I have a canon 40d. Its making screeching noises whenever I take pictures. I thought it was the lens... (More)
Answer
Canon 40D with Canon 50mm 1.8 lens ERR 99 Shooting is not possible Turn the power switch to and... (More)
Answer
when i press to take a picture the shutter only does the first part of the release. I have to take... (More)
Answer
How do I set my canon 40D to my laptop for live viewing
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital... Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
