Question about Whirlpool GB2SHKXL Bottom Freezer Refrigerator
Ice builds up and closes off the vents in the freezer section. I have "dfrosted" this 3 times in the past 3 months, and it is building up again. Is there a drain tube or something I can check
  • 52 Answers
Try changing the tempt on the freezer, and not have it at the lowest setting. Also, if you do not keep too much items in the freezer, that can contribute to the excessive build-up of ice. Try recommended settings first.
Posted on Feb 06, 2010
Why samsung Refrigerator Freezer is cold but Refrigerator is warm -Model srs622dss
check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Feb 23, 2015 | Samsung Refrigerators
Water in refridgerator
Have a look inside fridge compartment (especially the "roof", if it's a top-mount freezer) & see if you can see any ice build-up (look inside vents that allow cold air into fridge from freezer section. Also, if top-mount freezer, look inside the freezer compartment for ice build-up on "floor", inside vents, or on back wall. These symptoms, combined with water dripping from lots of the "roof" of fridge section (in a top-mount freezer model), can mean several different problems, so best to re-post with more info/symptoms included.
If there's no ice build-up (& the dividing area between fridge & freezer sections isn't particularly cold, which otherwise might indicate hidden ice build-up), it can be as simple as a plugged or obstructed drain tube, which is VERY COMMON. Easiest solution for this latter problem is to use a flexible plastic tube (think similar type as attached to aquarium air pumps), stuff it into drain hole, and blow on the other end. Sometimes you have to blow quite hard to clear an obstruction or complete blockage. If you can't clear the drain tube, it's likely a different problem. Again, a re-post with more info/symptoms will help narrow it down.
Sep 17, 2013 | Roper Refrigerators
Rsh1dbrs - freezer fine, fridge now emitting loud 'slow fan' noise after opening /closing. just under 2 yrs old - no problems til now.. cleared it out & looks like ice build up at back ? any...
Check for ice build up in the freezer section. Sounds like a defrost problem .You will need to remove the panel in the freezer and look for ice build up, from there you could have 3 or 4 different parts that one or more has failed
Jul 08, 2011 | Refrigerators
Frost is building up in bottom freezer. Amana ABB2224DEW
I have this problem as well, only nobody is leaving anything open. The defroster is defective of these things and the duct between the fridge and freezer gets frozen over and the cold air can't get in the fridge, so the freezer keeps working until it's blue in the face.
Apr 19, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Freezer vents are building up ice.
I believe it is time to change the defrost timer and check the remaining major parts of the defrost system. I will give you a page to go to where you can view theses parts and enlarge them to help you see what we need to start with. (defrost timer). Part WR9X502 Defrost Thermostat part WR50X10025 and the defrost heater WR51X10038 Now this is parts for the model listed above your post right? BRB, Sea Breeze
Jan 06, 2010 | GE Hotpoint® HTS18BCPL Top Freezer...
A couple of things can cause this problem. One is that your defrost temp sensor is ot functioning correctly and terminating the defrost cycle early allowing ice build up to occur over time. The other thing could be that you have a torrn or loose door seal on either your freezer or your food section door. The thrird possibility is that you deftost timer is intermittent and only working part of the time or is clocking forward at a very slow rate. You can unplug the unit again and place a fan blowing into the freezer section for about 2 hours but we both know this is only a temporary situation and that you should have your unit serviced. I would call for that service either before you defrost it or 2 weeks after you defrost it.
Jan 06, 2010 | Hotpoint HTS18BCPWW Refrigerator
Hi, We have a whirlpool eb22dkxfw01 bottom-freezer refrigerator. The freezer part is working OK, compressor is running, but the refrigerator part is getting rather close to room temperature, and...
need to check for ice build up in air vent. if not make sure you hear your evap fan blowing in the freezer section. this blows your cold air into the fresh food side. do you have ice build up on rear wall of freezer section?
Jun 21, 2009 | Refrigerators
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
May 07, 2009 | Refrigerators
LG LRFC22750 Bottom freezer french door refrigerator
6343ed3.jpg The problem is ice build up on the back wall. The noise you hear is the fan blades hitting the ice. On the back wall water gets trapped, it then builds up over time, and a big ball of ice forms and blocks the fan. Take off the back wall, defrost the build up and cut the insulation off as above. The water will no longer get trapped and the problem will not come back.
Sgt 48
Feb 13, 2008 | LG LRFD25850 French Door Refrigerator
Refrigerator not cold.
if the freezer section is still working ok then check for ice build up inside freezer on the back wall, its possible that the unit is not defrosting and ice is building up on the cooling coils, the most common culprit is the def thermostat. easiest way for you to get it going again fast is to manually def the coil.
remove the 2 screws about half way down the back freezer wall. then using a blow dryer def the ice from the coil.
since this refrig has an electronic def control i would recomend calling a reputable service company to check it further for you..
Dec 19, 2007 | Maytag MSD2456G Side by Side Refrigerator
Whirlpool GB2SHKXL Bottom Freezer Refrigerator Logo
405 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
