Question about Pentax Optio M40 Digital Camera
Screen flickers and distorts picture also goes
Screen flickers (Horizontal lines) and distorts picture also goes purple and pink
Screen flickers and pictures have lines across them on my lumix DMC-TZ3
The camera is probably damaged, this also happend to my DMC-TZ5 as well after a few (5-6) years of heavy use but without any visible damage, a repair is most likely more expensive than just buying one of the new lumix cameras which have also improved A LOT, so you wont be disappointed!
Apr 08, 2016 | Panasonic Lumix DMC-TZ3 Digital Camera
Friend's Laptop Screen has become too dark to work with
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 24, 2009 | Toshiba Satellite U205-S5002 Notebook
When i take picture it looks good on lcd when i click picture there are horizontal lines in the image, why?
if thats the case on the final output when u see on pc then my friend
ur CCD is getting weak and these lines will increase in the coming days and will turn pink or purple and distorted , there is no cure for that unless u change ur CCD i will recommend a new one
Feb 23, 2009 | Samsung Digimax i5 Digital Camera
My pictures and the lcd screen come out blurry and pink, with horizontal lines across I have a Sony CyberShot DSC-T1 Digital Camera with 5 megapixels and 3x optical zoom I got in 2004. When I take...
Camera symptoms shows bad CCD Imager in camera and this part needs to be replaced.
Sony has announced free of cost repair scheme for such problem in DSC-T1 models. Please click Sony Support for details.
Thank you.
Sep 20, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
May 14, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Laptop screen flickers and color is distorted
Sounds like the CCFL is failing.. (Backlight)... Pink hue is common when these start to go out..
Dec 14, 2007 | Computers & Internet
Camera showing/taking distorted images
According to many respected sources with far more expertise than myself, the symptoms you are describing also fall within the realm of Canon CCD failure. In Canon's Service Notice: CCD Image Sensor Advisory, they outline the most common symptoms (distorted images, LCD showing only a black screen, etc.). They have conveniently limited the description to the bare minimum. More symptoms of the failing CCD include: pictures appearing on LCD show up with severe color variations (pink-purplish or green tint), colored "streaks" or "lines" throughout pictures, and wavy distortions in image. Most of these symptoms include the color variations, but not always. The lines or waves can appear in any direction and with varying degrees of severity. Some LCDs do not go black, but turn totally purple. Here is a link to a very informative article that should clear up any questions you might have.
Digital Camera Repair Blog
If nothing else, call the Canon Customer Support Center at 1-800-828-4040. They will ask questions to identify whether or not you are having the same symptoms as described in the Product Advisory. I have been through this twice, and both times they were very nice and very helpful. Even if you don't qualify for the free repair, it didn't cost a thing to find out.
I hope this has been helpful.
Nov 20, 2007 | Canon PowerShot S1 IS Digital Camera
Pinkish screen and green blurred picture
Sounds like the image sensor is malfunctioning (common symptoms: distorted images with purple or green cast, completely dark images, flickering lines across the screen.)
Oct 26, 2007 | Kodak EasyShare C643 Digital Camera
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Pentax Optio M40 Digital Camera Logo
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
