Question about Aardvark Direct Pro Q10 (bundle) External Sound System
Installed xp hot fix, then aardvark would not work, so I uninstalled hot fix. Now when I install cd for software, I get aarkthk.dll not found. Please help
    Problem Solver:
  • 11 Answers
All aardvark interfaces will only work well with xp sp1 or earlier 2000/win98. Also, dont simply uninstall SP2, 3. You have to unistall/reinstall xp, xpsp1 and then if needed, go to the microsoft download pages and get all the updates prior to SP2. Pay attention and make sure you dont install SP2. Do all of this with the pci card pulled and all aardvark drivers uninstalled/deleted. Then install per aardvark's instructions. I dont recommend internet usage without SP2. You will be vulnerable to attacks even with the best protection.
Posted on Mar 15, 2010
    Scholar:
  • 56 Answers
Dll errors often come when there is an entry in shared dll registry section for a dll which is not present on the computer. Programs generally remove files but not registry entries upon uninstallation. Such can be fixed using good registry cleaner like Advanced PC Tweaker http://www.repair-dll.com/.If your system is missing a windows dll then you might have to repair your installation after fixing the previous registry entry of that dll using a good registry tool.
Posted on Dec 05, 2011
  • 4 Answers
I seem to be a great test case for running Aardvark cards in a modern quad-core system on Windows XP SP3. I've got an Intel Q9550 quad proc, Gigabyte GA-P43-ES3G v1.1 mobo, an Aardvark Q-10, & an Aardvark 24/96.
After reading the forums below, I have a good idea of what I need to do. I'm going to summarize those ideas below & cite sources, but first I'd like to submit my theory explaining why Aardvarks work so badly starting with XP's Service Pack 2.
XP's SP2 & Win2000's SP4 introduced a 36-bit addressing system called PAE, which was designed to support more than 4GB of RAM (never quite worked right), as well as the use of Data Execution Prevention (DEP). SP2 installs the capability & automatically turns it on, just to screw with us. This was done after the Aardvark drivers were written, & even ProTools had problems with PAE; lots of stuff did.
Fortunately, PAE can be turned off. This is what worked for me, in my c:\boot.ini file:
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="WinXP Pro Corp SP3" /NoExecute=AlwaysOff /fastdetect
To check to see whether it is really off (after rebooting), open the System Control Panel, and check on the General tab. If it says "Physical Address Extensions" anywhere under the Computer heading (usually on the 4th line, under the line that says how much RAM you have), PAE is enabled.
If it's still running PAE, try one of these in the boot.ini file instead.
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="WinXP Pro Corp SP3" /NoExecute=AlwaysOff /NOPAE /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="WinXP Pro Corp SP3" /NoExecute=AlwaysOff /NOPAE /KERNEL=ntkrnl.exe /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="WinXP Pro Corp SP3" /execute /fastdetect
(it's different in Vista so if you're crazy enough to try using the Aardvark in Vista, read this: http://thehunk.blogspot.com/2007/06/disabling-physical-address-extension.html)
sources
http://duc.digidesign.com/showthread.php?t=130383
http://www.msfn.org/board/topic/80046-help-do-not-enable-pae/
http://forums.overclockers.com.au/showthread.php?t=398765
http://msdn.microsoft.com/en-us/library/ff557134%28VS.85%29.aspx
general approach to using an Aardvark in Windows XP SP3 on a multi-core computer
1) It helps to know the *rest* of your hardware works right. With the Aardvark cards not installed in the computer, run Memtest86+ for 24 hours with no errors.
2) Install Windows XP. (Do not install any drivers, even motherboard chipset drivers or graphics card drivers. Also, keep it off the network since it's unpatched & unprotected.)
3) Disable PAE & DEP by modifying boot.ini.
4) Disable the computer's internal sound card in the BIOS if you can, and/or in Device Manager.
5) Run the Prime95 blend stress-test for 24 hours each with no errors. If you get errors in these tests you have to fix that issue first.
6) Use Acronis or Ghost to create an image of the partition exactly as it is now, before installing any drivers or system updates. This way, when it crashes, you can reset to this safe point quickly.
7) Physically install the Aardvark cards into the machine.
8) The order in which you load drivers matters. If your first attempt doesn't work, try doing things just slightly differently the next time. Write everything down to keep track of what you try and what happens. First attempt, try loading the motherboard chipset drivers first, then the display adapter, network card, etc & finally the Aardvark drivers, version 7.13.
9) Aardvark drivers 7.13 and 7.14 support hyperthreading and multi-core processors; 7.04 does not, but some people have success with 7.04 so don't assume anything. (7.04 crashes my new computer hard, but seemed to work better on my Athlon 3000+)
10) You may have to try switching which PCI slot the card is plugged into, or try to assign the IRQ in the BIOS or in Windows Device Manager.
11) If it absolutely won't run in your system using XP SP3, try XP SP1 (clean install, not a roll-back). Keep your machine off teh internets for gods sake (or you'll get wormed in 30 seconds & your computer will be a spambot).
12) Set the "timing master" in Sonar or similar programs to your last set of inputs. If you have an Aardvark Q10 in your system, this would be 9/10. (In my case, I think it will be my second card's last outputs, so it's my 24/96's 5/6 inputs.) Also, disable any read & write caching.
sources
http://www.fixya.com/support/t1516728-aardvark_q10_no_drivers_cd
http://www.fixya.com/support/t4047907-installed_xp_hot_fix
http://www.fixya.com/support/t1716701-problems_aardvark_q10
http://www.fixya.com/support/t3260184-aark24_installed_computer_windows
http://www.michaelchagnon.com/aardvark/software_sonar.html
http://www.sweetwater.com/sweetcare/ts/detail.php?Index=25505&Keyword=Aardvark&Archive=showarchive
http://www.sweetwater.com/sweetcare/ts/detail.php?Index=28034&Keyword=Aardvark&Archive=showarchive
http://www.michaelchagnon.com/aardvark/download.html
Posted on Jul 24, 2010
Where can I get a free download for windows xp 3 ksuser.dll?
The ksuser.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, ksuser.dll errors usually show up only when using these programs.
Resolution
Important Note: Do not download the ksuser.dll DLL file individually from any "DLL download site." There are a number of excellent reasons that downloading DLLs from these sites are never a good idea.
Note: If you've already downloaded ksuser.dll from one of those DLL download sites, remove it from wherever you put it and continue with these steps.
1. Restart your computer if you haven't yet.
The ksuser.dll error might be a fluke and a simple restart could clear it up completely.
2. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the ksuser.dll not found error.
Note: Microsoft often releases updates to DirectX without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX10 and DirectX9 files but they run side-by-side without problem on all of these operating systems.
3. Assuming the latest DirectX version from Microsoft doesn't fix the ksuser.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
4. Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with ksuser.dll and a reinstall could do the trick.
5. Restore the ksuser.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your ksuser.dll error, try extracting the ksuser.dll individually from the DirectX downloadable package.
6. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
Oct 30, 2012 | Microsoft Windows XP Home Edition Service...
It has DINPUT.dll error
Dinput.dll errors usually appear when a game or other software program is started. and are caused in one way or another by an issue with Microsoft DirectX.
The dinput.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, dinput.dll errors usually show up only when using these programs.
Solutions:
1. For Dinput.dll not found. Reinstalling Direct X should fix this.
2. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the dinput.dll not found error.
Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX 11, DirectX 10, and DirectX 9 files, but they run side-by-side without problem on all of these operating systems.
3. Assuming the latest DirectX version from Microsoft doesn't fix the dinput.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with dinput.dll and a reinstall could do the trick.
Restore the dinput.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your dinput.dll error, try extracting the dinput.dll individually from the DirectX downloadable package.
4. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
Here is a good link for DirectX info on how to download and install:
http://support.microsoft.com/kb/179113
Jun 04, 2012 | EA Sports Cricket 07 for Windows
Error message at start up. Running windows xp. HP Pavilion a700N PC desktop. The message is: This application has failed to start because hpzjrd01.dllwas not found. re-installing the applicationmay fix...
To fix hpzjrd01.dll errors occurring due to corrupt or incomplete installation of HP printer software, uninstall your printer driver and reinstall it again.
To ensure the HP printer software is completely uninstalled from your system, we recommend you either use the built-in Add or Remove Programs utility or use the help of a third-party uninstaller, such as Perfect Uninstaller.
for more information and help click here hope this helps you.
Thanks
Michel
Dec 18, 2010 | HP Pavilion A700N (PJ516AA) PC Desktop
Ddraw.dll not found
Note: If you've already downloaded ddraw.dll from one of those DLL download sites, remove it from wherever you put it and continue with these steps.
    The ddraw.dll error might be a fluke and a simple restart could clear it up completely.
  2. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the ddraw.dll not found error.
  3. Assuming the latest DirectX version from Microsoft doesn't fix the ddraw.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
  4. Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with ddraw.dll and a reinstall could do the trick.
  5. Restore the ddraw.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your ddraw.dll error, try extracting the ddraw.dll individually from the DirectX downloadable package.
GOOD LUCK AND PLS RATE THIS POST AS FIXYA!!!!!
Nov 16, 2010 | Yahoo Messenger
Problems for sp2
MICROSOFT STOPED SUPPORTING XP SP2 YOU SHOULD UPGRADE YOUR SYSTEM AND ALL YOUR SOFTWARES WILL WORKS
DONT FORGET TO RATE
Jun 08, 2010 | Microsoft Windows XP Professional With...
Need 64 bit Win7 drivers for my aardvark LX6
all devices which work with XP should work with 7... this is the way microsoft designed windows 7... download realtek high def audio drivers and install em.... this should solve the problem...
Apr 01, 2010 | Aardvark Direct Pro LX6 Sound Card
MSVCR71.DLL NOT FOUND
If the error started appearing soon after you have installed a new application or device driver, then it is possible that the error is occurring due to problems in the installation. To fix the error in this case, uninstall the software you installed and reinstall it.
Many times, errors related to DLL files, such as Msvcr71.dll, occur due to malware infections. Download, install and run Malwarebytes.
Hope this helps.
Jul 09, 2009 | Microsoft Windows XP Home Edition
Trying to open a power poits application I recd "application has failed to start because mso97v.Dll was not found. re-installing the application may fix this problem.Microsoft corp version:12.0.6215.1000....
  • Please first arrange Legal MS Office CD
  • uninstall MS Office completely
  • Restart your system
  • Run Setup from Office installation CD, Provide CD key when asked.
Zulfikar Ali
Mar 11, 2009 | Microsoft Windows XP Home Edition
Shell32.dll
Try running RUN and type regsvr32.exe /i shell32.dll.
This actually fixes the shell32.dll and installs it again.
RegSvr32.exe has the following command-line options:
Regsvr32 [/u] [/n] [/i[:cmdline]] dllname
/u - Unregister server
/i - Call DllInstall passing it optional [cmdline] (/i /u calls dll uninstall)
/n - do not call DllRegisterServer (must be used with /i)
/s  Silent (added with Windows XP and Windows Vista)
Aug 20, 2008 | Microsoft Windows 98 for PC
Smapls missing in kernal32
Go to C:\Program Files\Aardvark\ Aarkthk.dll and remove this file. It is an old file from win98 that didn't get removed when installing on winXP. Restart computer and you're good to go.
Dec 07, 2007 | Aardvark Direct Pro Q10 (bundle) External...
Aardvark Direct Pro Q10 (bundle) External Sound System Logo
456 people viewed this question
Top Aardvark Computers & Internet Experts
David Payne
David Payne
Are you an Aardvark Computer and Internet Expert? Answer questions, earn points and help others
