Question about Lexmark X2500 All-In-One Printer
When I copy, how do I adjust the light/dark, I need to get a darker copy!
  • Official Brand Answer
  • 3,344 Answers
The only way to adjust and print, copy or scan quality is by using the Lexmark software. Just go to your printers folder and then right click on the printer and go to properties there you will find the quality options.
Posted on Feb 09, 2010
Hp 7250 scans are not clear
In the menu area of the printer you can adjust the light and dark of the scan. That should help you out. If you can get a darker copy of what you are scanning that will help as well.
Sep 20, 2012 | HP Photosmart C7250 All-In-One Thermal...
Paper darker
clean optics, adjust exposure, and/or replace drum. You need a tech
May 13, 2012 | Canon NP 6035 Copier
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Dark, horizontal lines after text and dark images.
This implies that your monitor had gone bad. you need to take it to a computer repair shop.
Apr 10, 2010 | HP w1907 LCD Monitor
Some where text get more dark and change the shape of letter while doing photo copy in thosiba e studio 166/206''
U need to confirm that u copy through feeder or big glass...
If feeder, u need to check the feeder alignment
Need to adjust the doctor gap of developer unit if some text is darker, some text is lighter... ( can proof by printing negative post )
Mar 31, 2009 | Office Equipment & Supplies
Toshiba 2060 Photocopier prints copies that are a bit too dark.
restart the copier while holding down the "0" and "5" keys. you will now be in service mode. enter "5" and press "start" key a number should show up in the display. this is the exposure value - how dark or light the copies will be. 5 is the automatic exposure setting. around 128 is the normal value. the larger this value the lighter the copies are - the smaller the value the darker the copies.
Enter a new number (exposure value) and press the "interupt" key to save the value. Restart the copier and check what the copies look like. Keep adjusting until it looks good/better.
Mar 26, 2009 | Toshiba 6560 Copier
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
Need to make everything darker
Hello sir; The easiest way to make more darker is hold down the exposure key for 5 second until auto light blinking then adjust desitive key to darker side, it will make more darker, after finish just turn power off and on, good luck.
Jan 07, 2009 | Xerox WorkCentre XD125F All-In-One Laser...
Ink tone
Hi Pam -
This is a common problem with the CX 5000 - there is no contrast control (i.e., light/dark) like you would have on a photocopier. But if you use the scanning mode (EpsonScan) instead of the copying mode, there are a couple of alternative options that might help:
1) Brightness - in the EpsonScan program, in Home Mode, under Image Adjustments, there is a button labelled "Brightness." Depending on the colors and contrast of what you're copying, adjusting the brightness may help.
2) Color Restoration - In both Home Mode and Professional Mode, this feature is meant to restore the color to a faded photo - depending on the colors of your document, it may make the copy lighter or darker, but it's an option.
Hope this helps!
Dec 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Canon PC981 Copier Print issue
When using generic toners, the automatic setting doesn't adjust to factory specs. So you have to adjust it manually. If you are using OEM toners the there is an issue with the density settings, and the unit needs to be adjusted by a tech.
Jun 04, 2008 | Office Equipment & Supplies
Lexmark X2500 All-In-One Printer Logo
134 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
