Question about Samsung BL103 Digital Camera
Whats the best way to take pictures in dim lighting without using a flash? my pictures take a long time to take and come out blurry
    Brigadier General:
  • 11,967 Answers
Use a tripod.
Posted on Feb 04, 2010
When trying to take pictures of my motorcycle with all the led lights on at night the pictures keep coming out al blurry or very bright I have tried the settings on night time/ museum/ without the flash/...
Most likely the problem is "Camera shake". This just means that being in the dark, the camera shutter speed is long enough that the natural shake of your hands make the picture blurry.
You've got a couple options. The easiest is to find a nearby object and use it to steady your hand as you take the picture. You can also get a tripod and use the time delay release on the camera. This will let you push the button (which shakes the camera) and then step back before it actually takes the picture.
If you're shooting fairly bright LED's on the bike, you also might go into manual mode on the camera and experiment with shorter shutter speeds. Most people can use a speed of 1/60 without too much blur, so start with that and move to shorter speeds (maybe 1/100 or less). With the manual speed, you may get enough light from the LED's to make a good picture.
If this doesn't work for you, post a comment and I'll check back every few days and give some more ideas. Your camera may have some other ways to work through this. Rear curtain flash would be the best, but I don't think it has it....
Sep 11, 2009 | Nikon Coolpix 4800 Digital Camera
Nikon D40x flash will not go off
I have the D40x. Only thing i can think of is the little sensor thing on the front down and to the left of the release button. If you have your finger over it, the flash don't work and the focus won't work right. "Infrared assist" in the manual. Myself, I use the sb400 strobe flash cause the popup flash uses too much power from the camera battery.
Jun 28, 2009 | Nikon COOLPIX L3 Digital Camera
WD-52525 screen is jumping all around with wavy horizontal lines etc.
Good Day;
Keep talking to the factory, it is their product. Best Buy won't replace unless it is deemed not repairable and/or terms of the contract. You purchased the extra warranty because you most have felt that the TV might break down. Well, it did, now use the contract to repair your TV.
Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Close-up picture
I'm not one to know EVERYTHING about cameras, but I do own a Canon Powershot S5IS & the best advice I can give you is.. to put it on 'auto' and since you'd like to show as much detail as possible.. try using the super macro. ( It's on the bottom left side of the camera) it really makes a BIG difference, you see EVERYTHING, point & shoot!
but you have to be close to it, because if not, it won't focus much
& the picture will be blurry.
hope I helped!
Aug 09, 2008 | Canon PowerShot S5 IS Digital Camera
Canon powershot s3 is digtal
This is a menu setting, in capture mode it is the slow synchro option I think. What it does is try to get the subject to have a lit background. Turn this off and you get a subject lit with flash and no background but no blurriness either.
Jul 11, 2008 | Canon PowerShot S3 IS Digital Camera
Canon sd900
Try a higher ISO speed (suggest 400). Look in your camera's instruction book to find out how to do this.
May 27, 2008 | Cameras
Blurry pictures
Most probably you have incorrectly set your camera to a Camera Record mode other than Auto.
If there is not enough light and you are trying to photograph the scene without flash, (eg. by setting your camera mode to a mode that is programmed not to use flash) then the camera has to compensate for the missing light by keeping its shutter open for a longer period of time so as enough light comes into its sensor.
If your hand shakes during that time, you get blurry images.
Check your camera settings. The Twilight scene mode gives you slower shutter speeds to capture dark, night scenes, but you need to stabilize the camera on a tripod or something, depending on the level of light of the scene you want to photograph. The Twilight Portrait, on the other hand, is the same as Twilight with the addition of flash is used to illuminate a person or foreground subject as well as capturing a night background. This mode also keeps a long shutter time for capturing the night background.
For taking pictures of people, I would suggest you use Auto or Portrait mode where the camera will automatically use fast shutter speeds and flash (if dark).
Hope this helps.
May 22, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Why can't I take photos in darker places without flash?
Not a big flash fan, that'll cost ya. Read on...
I'm just going to answer the last two questions. You have to have what are called fast lenses. These are lenses like the Nikkor 70-200 f2.8 ($1200) that make this possible. See my site gallery for examples. I will either do manual or sports setting, it depends on the amount of ambient light. I can't use flash, it's not permitted in my work. Thus, the fast lens f2.8 all the way through the mm range, is the only lens I can use to achieve this. Some lenses (less expensive of course) are rated and medium lenses, that is, at 70mm, they have a low f range of 2.8 and at 200 mm have a lower range at 5.2. Ouch.
That's simliar to squinting to see the results in a dimly lit room. Whereas the f2.8 lens through the whole range is like having your eyes wide open in a dimly lit room, no matter how much extra light was around.
In short, in order to not get a blurry picture, because of movement, you have to have your shutter go off above 1/250 or 1/500. But to get that you have to have enough light or the image will come out black. Thus, to compensate for both of those, you have to have a lens that is "fast" enough to read the light and yet stay high on the shutter speed.
Again, it'll cost ya.
Nov 04, 2007 | Nikon D40x Digital Camera
Blurry Pics and not able to set date/time
You can only set the date stamp in the “Post Card” resolution mode. Hit the “function” button, go down to the resolution selection (L, M, S, W, Postcard, etc.). Pick the “Post Card” setting. Hit the “menu” button and the “date stamp” menu will be active
May 07, 2007 | Canon PowerShot SD600 Digital Camera
Picture blurry or out of focus.
Make sure your subject is within the camera's range. You should be at least 31 inches away to take a picture without the flash, and 31 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close- ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. For more information, see Chapter 6. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 750Z Digital Camera
Samsung BL103 Digital Camera Logo
91 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
