Question about Ariston Technologies CBC96 Wine Cooler Refrigerator With Ice Box
Ariston Fridge not cooling - Frozen Coils
I have an ariston fridge, freezer on top model about 5(?) years old. Lately the fridge has stopped cooling properly but freezer is still warm. The fan etc was working fine but was noisy so i pulled the back off and the coils were all frosted up. I have defrosted it twice now with a hairdryer which fixes the problem for a few weeks but then the coils start to freeze up again and it needs to be repeated. It seems from reading that it is the defrost time/heater... Can anyone tell me where to find these in this type of fridge and how to check them. I couldnt see anything in the back but then maybe i dont know what im looking for.
Any help would be greatly appreciated so i dont break something in my search. Thankyou!
  • Anonymous Apr 06, 2008
    the freezer is working fine but the fridge is not cooling?
No freeze
Posted on Jul 15, 2011
  • 236 Answers
Try to check the noisy fan, slow rotation of fan can cause the icing evaporator. Unplug the unit and rotate the fan manually by your finger check if the fan is not misalign or not touching the fan frame. Or check if fan motor bearing is not worn out. Under charge of gas is also one of icing cause.
Posted on Feb 20, 2008
Please can u suggest a direct suitablee replacment to fit Integrated Ariston BC312 model
for information on this , consult wit a fridge technician as they know the best replacement units for the fridge
Aug 30, 2016 | Washing Machines
Hi, My fridge ( 420 ltrs) Top Freezer making constant humming noise ( like a dieasl car engine)like the engine keeps running and try to cool the fridge. 1 year old. When I open the freezer or the...
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 14, 2010 | Samsung Refrigerators
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Water collecting in bottom of ariston fridge
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 04, 2009 | Refrigerators
PTS25 Top Freezer Model- Fridge & Freezer won't cool
If the compressor is still good your hard start relay might be bad.
Aug 05, 2009 | GE Profile Arctica Stainless Steel Top...
Ariston fridge freezer
hi smyvilla
on some fridge freezers there is a channel which is designed to take condensation from the fridge out through a small hole at the bottom of the back wall of the fridge check this hasnt got blocked or iced over, if the unit is a few years old it is possible that there has been some evaporation or leakage of the coolant mixture, that may be whats on your floor, the pump can therefore no longer pressurise the mixture sufficiently to cause it to remain cold,
Oct 25, 2008 | Refrigerators
Ariston fridge
Try to defrost the unit, if it wont work check the air vents if air is present. Check also if some of your stuff may be obstructing the air vent.
Apr 06, 2008 | Ariston Technologies CBC96 Wine Cooler...
The fridge is not cooling but the light turns on and the freezer is fine
Thank you sir even i had this problem.Its working properly now!By the way sir i have a few more questions that i need to get clarified can u help me with them?
Oct 23, 2007 | Ariston Technologies CBC96 Wine Cooler...
Ariston Technologies CBC96 Wine Cooler Refrigerator With Ice Box Logo
1,077 people viewed this question
Top Ariston Technologies Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
Are you an Ariston Technologies Refrigerator Expert? Answer questions, earn points and help others
