Question about BenQ FP71E 17" LCD Monitor
Hi, Monitor will not turn off when computer shuts down and continually goes through a circle of solid blue, yellow, red, white, black screen which is in a loop and continues until monitor is manually switched off. How do I get it to switch of when computer shuts down? Thanks Cheryl Cockman
  • 96 Answers
Yes its only a raster check of your monitor. YOu may press the power button off .
Posted on Feb 04, 2010
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
How can i play ps2 on lcd without having a black and white screen ? how can i connect the cables ?.....when i look at the back of my lcd i find three ports (red white yellow) when i use them the screen is...
1) The set of input (Yellow= Composite video, Red= Right channel audio, White= Left channel audio). This set of input is for composite video.
2) The set of input (Red= Red video signal, Green= Green video signal + sync, Blue= Blue signal, Red= Right channel audio, White = Left channel audio (the Red and White will be grouped close together). This set of input is used for Component video for HD signal.
You should try using composite video source (Yellow RCA jack) from DVD player and feed to the monitor and see if it works OK with all color showing that way we acn find out if it is the video source problem or the monitor video signal processing problem. Try the PS2 on the TV if it works OK also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 20, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
Hi guys. i hav an acer ac713 crt monitor. the cable that connects the monitor to the tower/hardrive has been cut by burglars. where can i find a wiring diagram to fix it? thanx.
in 15pin connector of the monitor,
red wire goes to pin No:1
green wire goes to pin no:2
blue wire goes to pin no:3
yellow wire goes to pin no:13
white wire goes to pin no:14
and black wire goes to 5&15. Now display will come!
Sep 08, 2010 | Acer AC713 17" CRT Monitor
Ive got the red power wire hook up and the yellow 12v hot all the time but dont now what color the ground wire is or the speekers are
Your ground wire is going to be black. Your normal wire colors are violet and violet/black, green and green/black, white and white/black, last but not least you have grey and grey/black. Those are your speaker wires. Solid blue is usually to power your antenna, and blue/white is for your amp turn on lead. Those two wires are approximately .5mV of power, and you can actually use either one to turn an amp on. Speakers: normally your solid color is positive, while the black stripe is your negative. As for which one goes to which speaker, left front is white, right front is gray, left rear is green, and right rear is violet. Hope this helps.
May 17, 2010 | Car Audio & Video
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
Splicing a monitor output wire from my laptop to
This cant be done.. You need a video card that has the yellow jack [video out]
the red and white jacks are your sound,
get a headphones to RCA adapter for the sound card[computer] going to projector or radio...[just need the RCA adapter to get sound]
But to get the video[yellow jack] to work you NEED a video card with a yellow jack inslled in your computer...or a video card that has a adapter for RCA video
I have a
Sep 30, 2009 | Toshiba Satellite A135-S4527 Notebook
Dell monitor goes white when computer shuts down
does the monitor stay white after shut down or does it go back to a black screen?
Jun 26, 2009 | Acer Aspire One PC Notebook
Digital Power Saving Mode
Go to your monitor power settings and turn off Hibernation and other monitor power schemes.
If this problem persist, request for more technical assistance from the manufacturers website
Nov 30, 2008 | LG W2252TQ Monitor
Monitor goes blank less than a second after turning on.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
BenQ FP71E 17" LCD Monitor Logo
148 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
