Question about Sony Playstation 3 (PS3) Console
Internet connection i plugged the ethernet cable from the modem to the back of the ps3 and i cant get on line, internet, i cant even sign into my psn account
  • 123 Answers
Modem? Are you using dialup?
Posted on Feb 20, 2008
I keep having the same PSN connection problem I keep disconnecting. The thing is I live in dorms so I can't mess with anything like the modem. I am plugged in via Ethernet. Still have problems and it
try to configure your system to the dorms internet protocols first, then try at different parts of the day, too many people using the internet will kill bandwidth, leaving you disconnected a lot.
Feb 24, 2014 | Sony Dc Universe Online
My playstation 3 has been having bad connection problems ever since feburary. haven't been able to log on to my psn account nor can my browsers direct me to the search page. I did the network settings...
This seems to be a wireless issue that you are having. In this case, ensure that your router/modem is working as it should be. Check the modem/router's login page and ensure its status is functioning with its intended speeds.
Place the PS3 close to the router and check that it is connecting with the router. If not, then plug a Ethernet cable and connect to the internet with that. If the PS3 connects, then the wireless module inside the PS3 is having a connection issue. If this is the case, contact a authorized PS3 dealer to replace the module.
I would recommend always using an Ethernet connection as it is always more secure and speeds are the fastest using this method.
Hope this helps.
Please rate my assistance. Thank you.
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
Lately from yesterday when i sign in it shows me message an error has accured u have been signed out of psn (80710092) why?? and i should do? thx
This means you've been signed out of the playstation network. A problem with your broadband, not your PS3. Check the connection of the ethernet cable from your router to the ps3. Then switch off at the mains both your ps3 and your router. Leave for 30 seconds then turn both back on. Wait till the blue lights on your router are all steady blue not flashing red or orange. Then turn on your PS3, go to network settings, then internet connection test. This will check your internet connection, and whether or not you're signed in to PSN, and also your internet download/upload speed.
Hope this helps.
LJ
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
I have ps3 internet but ps network! dns error 80 something and have been signed out of psnetwork! what do i do ?
Hope this helps.
LJ
Apr 17, 2011 | Video Game Consoles & Games
I have a PS3 slim console and it is having some internet problems that I cannot figure out. I have a CAT-5 ethernet cable plugged directly into my modem which is directly connected to my PS3. Many times...
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Make sure that UPnP is Enabled
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Nov 07, 2010 | Sony PlayStation 3 Slim Black Console
Ps3 was fine on line this morning but tonight in will not go on line and says error 80130182 i am using a ethernet cable to try and connect can you help ?
Hello, this error means you basically can't get connected to Internet. It's due probably to an IP conflict on your local LAN. Try to do the following: - switch your PS3 off - switch any device connected to your local LAN (laptops, desktops, iphones, etc..) - unplug power cable from your modem/router - unplug ethernet cable from both PS3 and modem/router - wait 1 minute, plug everything right back - switch your PS3 on and see if this error has gone.
Good luck, Peter_Rei
Aug 02, 2010 | Sony Playstation 3 (PS3) Console
A need help
you can set your playstation 3 online by two ways, 1- by a wired connection, and 2- Wireless,
1-Wired Connection: Plug an ethernet cable from your highspeed modem to the back ethernet input on your ps3 system, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wired Connection. and follow steps
2- Wireless Connection: You must have a Router connecting ethernet cable from your intenet modem to the router, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wireless Connection and follow steps,
hope this helped you on setting up your ps3 connection :)
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
Had my ps3 for year and half now, never played online (80710102)
Ok first off create a psn account online via computer, this is free of charge. Then after that connect your ps3 via cable to your modem. turn it on and access network settings. Then select internet connection settings, select easy. After it is finished select test connection. Should this time out it means you have a faulty connector somewhere, try checking your cables and the ports on the ps3 and modem. But if it states connected, back out and go to network via your ps3 dashboard then select sign in and enter your account info from your psn account.
Dec 08, 2009 | Sony Video Game Consoles & Games
How do i connect my ps3 to the internet if i dont have wifi?
Your PS3 supports both wired and wireless. Heres how I have mine set up, Ive been running wired since day 1. 1st- hook your ps3 up to your modem or router with an ethernet cable. {im assuming ps3 is plugged into the tv, if not hook it up}
2- go in to your network setting on ps3.. If you start at the far left go over click and all the way down. You will see network settings. click on it and go down to the 3rd option there.. Internet connection settings. You will get a pop up that says your ps3 will be disconnected from the internet if you proceed, just hit ok. It usually automatically detects if you have the ethernet cable plugged in but just in case it doesnt go ahead and select wired. after that, just select auto for everything else. You will go through about 5 questions and it will be ready to do an internet connection test. All should be well.
If that doesnt work, make sure all the cables are plugged in and try again.If you are able to connect to the internet after that but get booted off, go back into network settings again and disable the media server. Hope that helps.. Happy Gaming
Oct 24, 2009 | Sony Playstation 3 (PS3) Console
I have no computer or cable and need to set up internet on my PS3
??? A router will NOT replace your modem; the router won't work without the modem. If you're going to give advice, please make sure it is somewhat correct.
Okay. So first you need the telephone cord to go from the phone jack into the DSL port on your modem. Then you need the Ethernet cable that came with your modem (looks like a phone cord but much bigger) to go from the ethernet port in the back of the modem into the wan or internet port on the router. Verify that the DSL and internet lights are on on the modem.
For the rest of the setup, watch this . It will walk you step by step in connecting your PS3 to the wireless internet. Thanks and please take a moment to rate as fixya.
Feb 04, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
53 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
