Question about SMC WIRELESS-G SMCWPICG 802.11G EZCONNECT PCI WIRELESS ADAPTER
How to hook up smc router to at&t modem. where do i put the cords.
  • 2,260 Answers
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Feb 04, 2010
Working on a SMC router. There was a power failure and the ADSL modem can talk to the internet and the router doles out IP addresses but no internet access from the computers?
Check the computer's network interface card by opening the command prompt and typing ping 127.0.0.1 If you get back 4 replies 100% then ping router's and modem's IP addresses. If all are working. Try resetting your devices unplug your modem, router, and turn off your PC. Wait about 2 minutes. In this order, turn on your modem, wait 15 secs, turn on your router wait 15 secs, now turn on your PC.
Sep 07, 2011 | SMC Barricade g SMCWBR14-G (662698582192)...
Can I use a USB Modem (cricket) on the USB Port on SMC Barricade SMCBR14UP Router ? Thanks
No, this SMC router is designed for Broadband connection via RJ-45 connection thru WAN port.
The USB is there for USB printer as Printserver.
Jul 27, 2010 | SMC Barricade SMCBR14UP Router
Cannot set up security on wireless router "wireless card nt found
Are you trying to configure the router wirelessly. Connect your computer to the router with a lan cable and then access the router and change its wireless settings. since you cannot change the wireless settings wirelessly as you will get disconnected.
Sep 03, 2009 | SMC Barricade g SMC2804WBR Wireless Router
Default login & password
Default password for most of the modem is "admin"
If it doesn't help, then it will be mentioned in your modem user manual. For resetting your modem, you can use the hardware reset switch also. You can reset using that by inserting a small pin/needle into the hole located somewhere behind the modem.
Aug 03, 2009 | SMC Barricade g SMCWBR14T-G Wireless...
Two router home network problem
Can you still connect to the Internet with the Linksys router? I suggest that you go ahead and reset the SMC router to clear up your previously configured settings. Then before reconnecting it to the linksys router, make sure that you can access its web interface via 192.168.1.1. Don't disable DHCP as your computer won't be able to obtain an IP address from it automatically. Do not change other settings. Next, disconnect the ethernet cable and check if you can access the router interface wirelessly. Once done, connect SMC's WAN port to Linksys' numbered port. Make sure SMC's WAN light is on, as well as the light for the port you used on the Linksys router. Check if you can get online.
With this configuration, the linksys router is now acting like a modem, and the SMC as your router. As long as you're online when wired to the linksys, you should also be able to access the net on the SMC once you physically connect them.
Dec 22, 2008 | SMC2804WBR Wireless Cable/DSL Broadband...
Hooking ethernet to broadband router and cable modem
Hi Sherry - The etherport port on your modem should be connected to the WAN port on your router. You then connect your pc to one of the 4 ethernet ports on the router. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Jul 10, 2008 | SMC Universal Wireless Broadband Router...
Broad band hub
donn't connect the cable driect you use the 5port or 8port swicth then take a cble to modem to that swicth then how many computer you have to connect you can
Trouble do download drive or software
1st you want the phone cord to go from the wall to your modem, from the modem to the router connect using the cat5 cable, from router to pc using cat5 cable. then connect the power cord and turn it on....once connected open the browser and type 192.168.1.1 hit enter. This will prompt for a user name and password...should be either admin/admin or admin/password.
then you have to contact your ISP for proper settings. then your good to go.
Nov 11, 2007 | SMC Barricade 7004VWBR Wireless Router
For SMC7904WBRA :: How to use Cable Modem on ADSL router/modem
Looks like your device does not support playing router for cable internet. Would recommend you get an actual router, or alternately if you have a computer with two network adaptors you could plug one into cable modem, plug other in to LAN side of router, then configure turn Windows Internet Connection service, will need to disable the DHCP service on the router. I highly recommend you get a real cable/dsl router to do this tho. Linksys 54g series has been one of my favorites. Router homepage on SMC site. http://www.smc.com/index.cfm?event=viewProduct&localeCode=EN%5FUSA&cid=1&scid=4&pid=1588
Jul 29, 2007 | SMC Barricade SMC7404WBRA (SMC7404WBRA EU)...
Computers & Internet Logo
79 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
