Optics Logo
Posted on Feb 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Level a Meade telescope.
I have an old Meade telescope that I cannot keep both the east-west level with the north-south axis as it pans around the center axis. What should I do?
Joe Lalumia aka TelescopeMan
Level 3:
  • Master 3,186 Answers
  • Posted on Feb 04, 2010
Master
Level 3:
Answers
3186
Questions
Helped
952629
Points
7111
You did not say what model, or if it was on a wedge or not???
Model name and number would also help.
LX200 Classic, LX50, LX10, LX90, ??????? Post more information.
  • Joe Lalumia aka TelescopeMan
    Is the scope on a wedge or just in alt az mode?
    These links may help you:
    http://jan.eaglecreekobservatory.org/bal...
    http://www.weasner.com/etx/ref_guides/po...
1helpful
Is it grammatically correct to say up north or down south?
no
north, south , east west are compass points and have no dimensions such as up and down. The same as there is no dimensions for east or west
you go north or south, west or east
the word s up and down probably started from the time trains were developed as a direction to traveling trains was need so it was up to the capital station and down away from the station
92 regal trouble removing the rear rotor
Spray some penetrating lubricant around all the edges of the rotor (front and back), give it about 25-30 minutes to soak in, and then go to town on it with a hammer banging on one side and then the other (North south, East west, South east north west etc)
Just got my husband a casio pro trek sgw100-1 - we calibrated the compass but east and west are switched - north and south are fine - any ideas? thx
As a pure shot in the dark, are you sure that you calibrated it so that it was pointing to the north when it should be and not to south?
If it was pointing south instead of north, then East and West would be reversed.
Sounds a bit daft but better than the directions of east and west changing?
Check your calibration perhaps?
Hello, i just rec'd my used meade 125etx ec scope.
Contact Meade directly. You may need to send it back for repairs. Here is the contact web site:
http://www.meade.com/support/index.html
VERY NOISY WHEN SPINNING WITH EVEN AND LIGHT LOADS
It is more than likely not level... put a level on the top north to south and east to west... adjust the legs by turning them to lower or higher the legs
2helpful
2answers
HOW DO I USE THE TELESCOPE
he first thing you will need to know is does your telescope have a polar axis or not, that is, is it intended to track, or is it merely a point and look, or what we call Alt-Az. Alt means altitude and Az means azimuth, where Alt is the distance above the horizon, and Az is the direction in a circle around the horizon. If you have an Alt-Az mount, just skip the polar alignment step. If you have a polar axis, that is, your telescope is intended to track the stars, then find north, and make sure the polar axis is approximately lined up in that direction. It does not have to be too accurate, but make sure it is pointing pretty close to north. If you are not sure where north is, either use a magnetic compass, or try to find Polaris, the North Star.
Thanks.
1helpful
2answers
Meade DS-2114 ATS LNT
Also had the problem. I found that the LNT did not find north unless the bottom of the Smartfinder is close to parallel with the ground.
Top Meade Optics Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Meade Optic Expert? Answer questions, earn points and help others
