Question about Amana Refrigerators
Refrigerator compartment doesn't chill - Amana Refrigerators
  • 4,070 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Feb 04, 2010
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Water on floor - french door refrigerator with freezer below
Yes the bottom compartment does have a drain opening but to see it you will need to remove the rear panel covering the evaporator inside the back wall of the freezer compartment. See item location number 11 on page 3 of the parts list. That will need to be removed so you can reach the drain inside the freezer compartment. The fresh food section also has a drain. Here is a=> AFF2534FEB4 Parts List and AFF2534FEB4 User Manual I am here to answer any questions you may have, Thanks Sea Breeze
Leaking Refrigerators
Jul 23, 2013 | Whirlpool Amana Refrigerator Water Filter...
GE refrigerator chilled water has mildew taste
change the water filter usually located in the upper right hand corner of the refrigerator compartment on side x sides,if top mount freezer it can be about anywhere inside the unit except freezer compartment
May 11, 2012 | GE Refrigerators
My fridge freeze is excessively freezing in the freezer compartment and not chilling in the fridge compartment Any help would be greatly apprieciated Brian
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Microwave Ovens
Top is not cooling, sn no cold air is coming into top. Freezer seems to be working
SOUNDS LIKE THE CIRCULATING FAN IS WEARING OUT. THIS PROBLEM IS VERY HARD TO DIAGNOSE BECAUSE THE FAN SPINS BUT NOT FAST ENOUGH TO CIRCULATE CHILLED AIR THRU THE FREEZER AND REFRIGERATOR. THE MINIMUM COST FOR PARTS AND LABOR IS AROUND $300.00. THE FAN IS LOCATED BEHIND THE BACK PANEL OF THE FREEZER COMPARTMENT.
Aug 04, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
My Jenn Air bottom freezer refrigerator is too warm in the fresh food (upper) compartment. This just occurred today. The freezer works fine. Any ideas?
sounds like the FF(Freezer Fan) is starting to wear out. This fan problem is very hard to diagnose because the fan will still spin but not fast enough to circulate chilled air thru the freezer as well as the refrigerator.
Jul 30, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Refrigerator Compressor does not start
Is your freezer below your frig, like a drawer. If so does it still freeze the food. if this fact is true, then listen with the freezer drawer open to hear if the freezer fan is running. If it is running and your freezer is working then it could possibly be that fan that is the problem. This fan circulates the chilled air from the evaporator coil thru the freezer and the refrigerator. This problem is very hard to diagnose as the fan still spins but not fast enough to circulate the chilled air thru the freezer and frig. The minimum cost is around $300.00 if a service company does it. But if you can do it then you can possibly get the fan motor for around $80.00. This repair is very labor intensive as the access to the electrical connection is at the extreme rear of the freezer compartment.
Jul 23, 2009 | Refrigerators
The food side not geting cold I set up the control nothing
the small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
Mar 06, 2009 | Amana AFD2535DES French Door Refrigerator
Freezing food in upper chill drawer and freezes water in tank
Does you appliance have the custom cool controls ? If it does then there is another air damper in the custom cool unit at the bottom of the fridge compartment
Aug 28, 2008 | GE PSS25NGM Side by Side Refrigerator
Refrigerators Logo
61 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
