Question about Kenmore Elite 45986 Front Load Washer
Build up at the bottom of the area where the water goes out. How can i get the cover off to clean this area? Is this a pump problem or simple cleaning issue?
  • 5,911 Answers
I'm not exactly sure what you are asking, but if this is in reference to checking the drain puimp, because you are having drainage issues, the following link explains how to access and clean the pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. An error code of "F02" or "F21" can be generated if the drain cycle exceeds 8 minutes. If the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. The washer will not complete the wash cycle, either. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
If you have any questions about this repair, or need additional advice, please post back and elaborate on your symptoms a bit more so I can provide you better assistance. Please include your COMPLETE model number (located on a nameplate around the door opening). I hope this helps you.
Posted on Feb 04, 2010
Good day, can you please help, I want to know what can be the problem. Our speed queen heavy duty washing machine leaks water when spining. The water leak is at the top of the outer tub where the clips...
The basics would be make sure it's clean, the outer and inter ring of this area holds and builds up dirt and debris over time, causing a bad seal, also has to spin and be balanced properly or it will leak a little. ...
Feb 26, 2015 | Speed Queen Washing Machines
Tip
GE Bottom-Freezer Icing Problem?
Most-likely the problem stems from a design flaw in GE fridges. Access the evaporator fan through the bottom of the fridge by removing the bottom drawers, the floor and insulation of the fridge and de-ice the area around the fan by using a hair drier and hot water. After completing this you will then want to move to the back of the fridge where you will remove the metal insulated cover covering the upper drain section of the water drainage system. This will expose a snake-like section of tubing, this is where the underlying problem stems from. Remove this section and clean it out with warm water, a turkey baster can make this a little easier. If you notice that the blockage was caused by a build up of dirt and mould then re-install the section of line and replace the insulated metal cover. If the blockage seems to be caused by a ice build up, then re-install the section of line and do not re-install the insulated cover, this will prevent this section from getting too cold and causing a blockage.
on May 22, 2011 | Refrigerators
Closing inground pool
Question:
How do I close my pool for the season?
by Osko Pool n Spa Information
By following the provided instructions, you will be able to professionally close your pool for the winter season. Additionally, you will protect it from winters abuse and make opening it next season...simple.
Required Tools
a) Standard Screw Driver
b) Phillips Screw Driver
c) Ratchet Set
e) Plumber Pliers
f) Sump Pump
g) Extension Cord
h) Garden Hose
i) Five Gallon Bucket
j) Air Pump or Shop Vac
k) Pool Vac & Accessories
Required Chemicals
a) Pool Shock
b) Algecide
c) Chlorinating Tablets
Required Accessories
a) Winter Cover
b) Pool Pillows or Inner-tubes
c) Chlorine Float Dispenser
d) Water Bags (for ingrounds only)
Step One - Debris & Chemicals
Remove any debris from pool water by use of a leaf rake attachment.
Add the appropriate amount of shock treatment to the pool water, as prescribed on the packaging.
Add the appropriate amount of algecide to the pool water, as prescribed on the packaging.
Run your filter for the appropriate time to circulate all water once.
(see your filter documentation for your size pool)
Install your floating Dispenser and winterizing tablets.
Step Two - Vacuum & Water Level
Vacuum your pool while setting your filter to the "back wash" or "waste" setting.
(this will help lower your water level)
After vacuuming, install the sump pump and drain pool to about 6 inches below your thru-the-wall skimmer.
Step Three - Parts Dissassembly & Cleaning
Disconnect all ladders, filter systems, hoses, solar reels and/or other accessories.
Using standard household cleansers, thoroughly clean all ladders, solar reels and/or other accessories.
Dissassemble filtration system.
Remove sand, cartridge or DE powder from your filtration tank.
Thoroughly clean all filter system parts.
Allow all items to dry.
Store all items in an area that will not be subject to freezing temperatures.
Step Four - Pillow & Cover Installation
Inflate all pool pillows or inner-tubes.
Install one pillow for every 15' of linear water surface.
(example: a 15' x 30' would require at least two pillows)
Tie pillows to pool area via nylon rope and place equally with respects to pool walls and each other.
(this is extremely important! This prevents freeze damage)
Install winter cover as prescribed by the covers manufacturer.
Step Five - Winter Tips
During the winter months, remove any excess snow from the winter cover.
(If you have a solid cover, this will prevent excessive weight form tearing you cover)
(If you have a mesh cover, this will prevent excessive water build up)
Hey, Your Finished! Congratulations, you just saved money while doing a professional job
Nov 11, 2013 | Hayward SAND FILTER, PRO SERIES
My portable windchaser airconditioner pacr9 sounds like theres some water in the top area and is blowing out some water from the front vent ? any reason why ?
This usually happens when the unit is dirty. The filter provided is pretty worthless and dirt and dust build up inside the unit badly. This causes the unit to operate inefficiently. Condensate builds up on the evaporator and freezes. When it defrosts water drains through the unit to the bottom, whats left is a muddy sludge and a clogged evaporator. The condinsate will then overflow into the fan area. Normally the condensate will be exhausted through the warm air vent in the back of the unit.
To fix this, you need to unplug the unit, then remove the entire back cover. Not just the small cover on the upper portion. Once removed you can then have access to the entire evaporater and condenser. Clean these thoroughly with a vacuum and toothbrush if necessary, Let the unit defrost if the evap was clogged with ice. Drain the unit thoroughly with the tube at the bottom of unit. I lay a thick towel on the floor and let it drain into the towel. Clean the fresh air intake area on the upper rear thoroughly, I used windex, then flushed with water, which ten drained to the bottom of the unit, and out onto my towel. Reassemble and run in fan mode for an hour, allowing the condensate that overflowed into the fan area to evaporate. You should be all set.
This maintenance procedure should be performed yearly or as necessary on these units.
Aug 14, 2013 | Windchaser PAC9 Air Conditioner
Coolant leak
Hose ? The drain valve on the lower radiator ? The water pump has what's called a weep hole built into it. When the water pump fails water weeps out of that little hole to let you know it's bad. I think the ion probably has the water pump onth the front of the engine under the plastic cover ? ( not sure on that ) if it is the water will leak from behind that plastic cover making it look like its coming from the area where the oil pan and that plastic meet. It could get blown around by the cooling fan making it look a lot worse that it is. Check the lower hose and all the other coolant hoses for cracks or leaks as well as the entire radiator area ( sides, top, bottom ) check your rad cap when its cool and be sure the rubber seal on the inside of the cap is good and not cracked or dry rotted. If it is then when the water gets hot and pressure builds in the rad it will leak. When its cold it may not.
Aug 09, 2013 | 2004 Saturn ION
Will I still get coffee if the pump is broken. The machine is leaking staem and water underneath and I beleive it is the staem valve but a 'dodgy' coffee machine repairman is telling me it is the...
I am an expert espresso certified man. First of all your repair man is wrong. Let me explain. If you are getting steam at all, then your pump is not broken. This is the way it works, you have water in your machine, it goes into a area where it heats the water by heating elements, then as it heats it builds pressure by air and heat. The machine has a water pump in it, that operates by of course electricity, it pumps the water that is heated by the elements through the machine to of course make shots of espresso. The steam part is simular as it goes in a area, the gets hot and produces steam from the water, like a iron would of press kind of method. THE MACHINE will not make coffee or steam if pump is not working. If you turn machine on, and hear it humming or running, when trying to make a cup, then motor is running, if you turn it on and try to make a cup of coffee or steam and hear nothing at all, then pump is not working. If your machine is leaking under machine from from the steam valve, means it would not do that if pump is not working. Sense it is leaking, this tells me it is clogged. Most likely your need your machine cleaned good, that means descaled. Clean hoses, use small needle to poke in end of steam wand to clean out good jet air holes and basket screen. Find your manual, and it should tell you how to properly clean your machine, and even can use can of compressed air, that you can spray in hoses. It appears to be it is clogged, and when the pump or lines are clogged , it will back up like a clogged toilet and flood area around base and underneath. This whole problem is a cleaning problem, do to a clog or build up. I hope this. PS no if you pump is out or clogged, you would not get coffee as it need to the pump to work (unclogged) to push the water through the heads. Thanks Mike
Sep 15, 2011 | Gaggia Titanium Espresso Machine
Broken plate in dish washer. Pump is now making noise. How to take pump out and clean?
at the bottom rear of the dishwasher there is a cover over the sump. remove this cover and below there should be water in the sump. feel down in this area and clean out the trash. there is also a metal cutter in this area that chops up small particles of food. you could have something in this area caught. be careful not to cut yourself.
Jul 18, 2010 | GE Nautilus 24" Built-in Dishwasher
Our Kemore dishwasher is leaking water onto floor, and the water valve continues to pour water when machine was turned off, but is not leaking water now. There is also standing water at bottom of tub from...
you just need to clean the pump area in the bottom of your unit :)
try to take spray arm out if you can and then open pump cover clean it good but watch for broken glass in it ...and thats it :)
Aug 12, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Maytag Dishwasher won't drain
on all dishwasher think of them as a simple gutter system. the water only has one drain. At the bottom, if the pump can't pump out the water, its simply a bad pump or a clogged drain hose. Food particle can clog the "drain screen", use a good quality shop vac, clean 'drain screen', remove drain hose and clean thoroughly. If the hose goes into your drain pipe, remove that and clean that really good with snake it its metal or a strong 1/2 zip tie if its plastic.
Nov 30, 2008 | Maytag 24 in. MDB5600A Jetclean II...
No Spray
Wow, you've done a lot of work. I wouldn't break the seal around the bottom. If water gets in the motor then your in big trouble. You can try to clean the spray arms out. I was just in my kitchen trying to get the dishwasher to work with the door open to see the arms spray water, but I couldn't do it. Just a little experiment I wanted to try. I told my wife I was trying to help solve a problem and you can image what happened from there .... Let me see if I can find a manual.
Jul 14, 2007 | KitchenAid 24 in. KUDI02IR Built-in...
Kenmore Elite 45986 Front Load Washer Logo
35 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
