Question about GE Profile Spectra JGBP90 Gas Kitchen Range
The oven and broiler work but the broiler flames up like its not getting enough air. the flame burns yellow
  • 73 Answers
You may be correct with the air? is it LP or NG? air adjustment correspond with type of gas also the brass orifice you see going into the burner may be in need of ajustment, if its LP its needs to be screwed all way back even if it seems tight, screw it out away from burner ( clockwise) if NG then it's oppisite. hope this helps
Posted on Feb 05, 2010
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
How do I fix broiler that does not burn hot enough to broil. Oven works o.k. Broiler worked last week but now flame is not strong enough.
Make & model? You are talking about flames so I assume it is a gas unit. I would examine the broiler burner, sounds like a problem there.
Nov 29, 2014 | Kitchen Ranges
My ovens flame is completely a dark yellow is this normal? my cooker is a cannon thankyou
no,this flame is like this because either the flame orfice is dirty or the burner is dirty or the unit isnt getting enough air mixture to completely burn the gas and this will lead to a yellow flame instead of the normal blue flame
Aug 01, 2010 | Ovens
GE PGB975SEMSS Broiler and Oven flames too large and yellow
It sounds like your not getting enough air mixed in with the gas.if you can't adjust for more air make sure you were not supposed to change the spuds that feed the gas on the lower units.
Mar 16, 2009 | Ovens
Oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Funny Smell
ALL YOUR FLAMES SHOULD BE CLEAN BLUE FLAMES WITH NO WHITE OR YELLOW TIPS OR FLAMES !!!! YELLOW FLAME = DIRT OR PAINT? WHITE = LACK OF AIR SOUNDS LIKE YOUR STOVE IS NOT GETTING ENOUGH COMBUSTION AIR. INPROPER AIR ADJUSTMENTS OR LACK OF AIR WILL CAUSE A WHITE TIP ON THE FLAME ... THAT IS CARBON-MONIXIDE !!! A CLEAN BLUE FLAME EMITTS CARBON-DIOXIDE AND IS NORMAL. IF YOU USED AN AIR-GUN TO PAINT, CHANCES ARE YOUR BURNERS HAVE A SLIGHT COATING ON THEM AND HOPEFULLY WILL BURN OFF IN TIME. TRY OPENING ALL YOUR DOORS AND WINDOWS IN YOUR HOUSE ... AND TURN ALL BURNERS ON AND LET THEM BURN FOR AN HOUR. DO NOT LKEAVE SIGHT OF THE STOVE, BUT KEEP NEAR A OPEN WINDOW. NOTICE !!! MOST GAS COMPANIES WILL COME OUT AT NO CHARGE TO CHECK GAS, AND FOR CARBON-MONOXIDE.(C0) NOT (CO2).
Apr 28, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
111 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
