Question about Tyan Thunder K8W S2885 Motherboard
Tyan S2885 mb and graphics card Asus AH 4650
Tyan S2885 motherboard and graphics card Asus AH4650 AGP. After loading supplied drivers and current drivers for card, system freezes in both Windows 7 & Vista both Ultimate versions (freezes at different points) although in XP there is NO problem
  • ronrobins Feb 04, 2010
    You say install agp drivers & ide drivers these are handled by operating system
  • 617 Answers
Install agp drivers, ide drivers then video drivers
Posted on Feb 04, 2010
GRAPHICS CARD
http://uk.asus.com/Motherboards/Intel_Socket_775/P5S800VM/
I see it is the VM/S version, and not the Asus O.E.M. version above.
My thinking is the motherboard was made for a proprietary computer manufacturer.
Perhaps NEC or Packard Bell.
Using this line of reasoning, it is my contention that the graphics expansion slot is the same, and motherboard chipset; for the VM/S version, as well as the Asus OEM VM version.
Going further...............
Specifications:
Graphics Expansion slot -
AGP and 8X........AGP 8X
Motherboard Chipset:
SiS 661FX - Northbridge chip
SiS 964 - Southbridge chip
http://www.motherboards.org/mobot/chipsets_d/SiS/661FX+964/
So we know the motherboard will support an AGP 8X graphics card.
Another item you need to have knowledge of, is what is the Minimum power requirement; for the particular AGP 8X graphics card you are looking at......
Let's look at some examples,
(They are getting fewer, and fewer; as the graphics card technology has gone to PCI Express.
PCI Express has evolved to the PCI Express 3.0 technology now)
A) http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=853908&CatId=2234
Scroll down to - Features
-> Minimum PSU Wattage requirement
(Ignore of you are aware;
PSU = Power Supply Unit
The Power Supply's used in personal computers are SMPS.
Switched-Mode Power Supply)
MINIMUM power wattage requirement for the above AGP 8X graphics card, is 250 Watts.
Something I would like to impart;
Back in the day Power Supply manufacturers 'fudged' the True, Actual maximum wattage rating.
Actual maximum wattage rating, was more like 60 to 70 percent of what was stated.
If we use a 250 Watt PSU from back in the day, as an example; actual maximum rated wattage would be 150 Watts, to 175 Watts.
[Simple equation(?);
250 divided by 10 = 25
25 times 6 = 150
25 times 7 = 175 ]
Point?
DO NOT under power a graphics card!
A) It will not work right, or at all.
B) It will burn;
The gold plated contact pins on the bottom of the graphics card.
The contact pins in the graphics expansion slot.
Takes a while usually, but when done you can use the motherboard for a Frisbee.
Here is a Power Supply Wattage Calculator,
http://extreme.outervision.com/psucalculatorlite.jsp
Takes about 2 seconds for the page to fully load.
Need guidance in using it post back in a Comment.
It is the 'Rule of Thumb', to have at least 10 percent more power, than what is required.
Easier on the Power Supply, as it doesn't have to strain to keep up.
I myself would recommend a 350 Watt power supply, at least.
One more thing if I may;
LOAD THE SOFTWARE FIRST!
Load all the software that comes with the graphics card.
It will be on the Installation disk that comes with it.
You will be loading the Drivers, and user interface.
For a graphics card utilizing the ATI (AMD) technology, you will be loading Drivers, and the Catalyst Control Center.
For a graphics card utilizing the Nvidia technology, you will be loading Drivers, and the Nvidia Control Panel.
AFTER doing so, THEN turn the computer off, FOLLOW Anti-Static Procedures, and Physically install the graphics card.
Why?
Because when a device is installed on a computer that has Windows on it, Windows will 'break it's neck', to find suitable, matching drivers.
If THE drivers are not already there, Windows will match up one of it's THOUSANDS of generic, one-size-fits-all drivers.
This = No
A Driver conflict can result........
Windows: "Which drivers do I use?
These or THESE?"
For additional questions please post in a Comment.
Or Reply, at the end of this solution.
Regards,
joecoolvette
1) SMPS;
http://en.wikipedia.org/wiki/Switched-mode_power_supply
2) AGP technology;
http://en.wikipedia.org/wiki/AGP
3) PCI Express technology;
http://en.wikipedia.org/wiki/PCI_Express
May 10, 2013 | ASUS P5S800-VM Motherboard
Can foxconn 661m03 handle ati radeon 4650 agp?
Hello here is the foxconn homepage:
http://www.foxconnsupport.com/Default.aspx?Language=en-us
The graphic card will fit the mainboard, all graphic card with the AGP socket will fit, there is no limit here.
When adding a bigger graphic card, the power supply can be too small for the system.
I would suggest a 400 watt psu or bigger, for a smooth running system.
A more expensive graphic card is always better, depending what you have to use it fore.
More system memory (ram) can also help, if you intend to playing games.
The newest AMD driver can be downloaded here:
http://support.amd.com/us/gpudownload/Pages/index.aspx
By selecting the graphic card model, and your windows system.
Hope this will help you
Mar 19, 2013 | Computers & Internet
I have problem with configutation , or the drive are not good, because the monitor works my mouse a way.
its not a problem with youe mouse ...its a problem with your operating system ...get an antivirus and scan your computer thoroughlt for viruses ....there are some viruses which cause this problem with mouse pointers...
Jul 26, 2012 | ASUS AH4650 Radeon HD 4650 1GB DDR2 AGP...
I am a gamer and p5vdc-mx has only agp slot and i want 1gb vga card but it is harder to find in agp slot i find only pci express x16 cards can i use riser card to convert agp to pci e x16
Hello
I dont think there are any agp to pci ex riser cards.As pci e x16 is part of the motherboard circutry.
There are pci to agp riser cards.If your going to be playing some of the latest games.Most games in the past 3 yrs require a pci x16 vid card.
I suggest geting another motherboard,chipset,and memory.Along with a Pci e x 16 card min 512mb.
Sep 07, 2011 | ASUS P5VDC-MX Motherboard
I need to download drivers for ASUS V3800 (32 MB) AGP Graphic Card thanks
open this Link
Select your required operating system.
Download all the drivers and install.
Jul 12, 2011 | ASUS V3800 (32 MB) AGP Graphic Card
Nvidia graphics card won't fit in asus ncch-dl motherboard
The NCCH-DL has the following slots:
1 - AGP-Pro 8x
(you can use regular AGP cards in here as well as long as you have the little plastic thing that comes with the mobo... you may even be able to without it)
2 - PCI-X
This is NOT PCI-E.
You CAN use regular PCI cards in a PCI-X slot IF the company that manufactured the card left the space between the little metal contacts... unfortunately, many PCI cards are made with the space filled in with useless plastic... I've heard you can cut the little space yourself and it'll work fine... I don't know why it wouldn't but be careful, and of course do at your own risk.
I currently use a regular PCI network card in this slot because the onboard LAN port only has Win64 bit drivers on the web site and it works just fine.
A PCI-E card will NOT work in this slot.
Generally speaking the PCI-X cards you are going to find are riser cards, network cards, firewire cards, and controler cards.
2 - Regular PCI Slots.
I think you know what PCI is.
May 03, 2009 | ASUS NCCH-DL Dual...
Cmos Chechsum bad
your CMOS battery needs to be changed..u can find it on motherboard...
Dec 12, 2008 | ASUS GREEN MODEL N6200/TD/128M - GRAPHICS...
Asus P4S800-MX
I would swap the power supply or test the power supply in a known working system. Than do the same for memory & lastly for the CPU. Resetting the bios should cause the onboard graphics card to load instead of an AGP card loading. If you did have an AGP card on the board, remove it. Though you did remove the battery it is still recommended to move the bios jumper to clear for 15 seconds, page 1-15 in you're manual. Than reset the jumper to normal. Again, if you were using the onboard graphics card, you can try adding an AGP 8x/4x, 1.5v card. It may allow display. If nothing helped than replacing the board is the next step.
There is one listed on this link. Scroll to the bottom of the page.
You might want to hurry. Other than EBay I did not find another board for sale.
http://www.crayeon3.com/c3/pc-60-6-.aspx
I did not try to buy this item.
You might have to register to buy the board. Be careful with EBay over seas. Buy a faulty board & it can cost you triple to return it. Return policy not normally specified.
This link will add to cart but it's double the price.
http://microsource-store.stores.yahoo.net/mb-asus-pp4p800vm.html
You should be able to use Asus P4V8X-MX MB to run you're current devices.
http://www.pcplanetsystems.com/abc/product_details.php?category_id=115&item_id=2801
Good Luck!
Still need something? Just post.
Mike
Mike
Jun 19, 2008 | ASUS P4S800-MX Motherboard
Swap 9800 Pro for 9700 Pro
You must uninstall the current driver and reinstall the driver for the 9800 Pro first:
http://ati.amd.com/support/driver.html
Power supply recommended is 300watt for each, so that is not a factor. It would have to be a driver conflict.
Oct 30, 2007 | ATI RADEON 9800 PRO (256 MB) Graphic Card
Tyan Thunder K8W S2885 Motherboard Logo
518 people viewed this question
Top Tyan Computers & Internet Experts
Jerry Umali
Larry Chandler
Robert Graf
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
