Question about Dishwashers
Water not getting hot
Hi i have a dishlex dx302 i have power on the active side of the heater however on the nuetral side which is switched by a relay on the control panel the relay is not pulling in to supply nuetral to the heater the relay tests fine but it is not getting current to the low voltage side to make it work i prosume there is a thermerstat input some where. Can you help if not do you know where i can get a circuit diagram.
Kind reg Kevin
  • 1 more comment
  • leicester Feb 29, 2008
    Hi i thought was the card however it appears not tried new card.
    Can you please send me a diagram to Kevin@adam .com.au
    This will be much appreiated.
    Kind reg Kevin
    It just appears what ever tells the relay it is ok to pull in, isnt doing that.
    Sorry, My email is Kevinr@adam.com.au.
    Thanks
    Kevin
  • leicester Mar 03, 2008
    problem was broken wire on tacho now fixed all good thanks
Hi there I have a dx302 with a heating problem and experiencing similar readings decried above. Is it possible to get a hold of the wiring diagram? It would be a great help. Thank you, Dave
Posted on Sep 28, 2011
  • 49 Answers
There is no thermostat but there is a temp sensor (ntc probe). if you check the Resistance between terminal g5 and g6 you should get 6.03 k ohm at 20 degrese Celsius.
it sounds to me like the control board needs replacing.
i can send you a wiring diagram and full diagnostics in pdf format if you give me an email address
Posted on Feb 20, 2008
  • Matt Close Aug 12, 2013
    I would love to get the diagnostics pdf .... matthewclose@bigpond.com
I have a dx302. its not heating the water or drying.
download this manual...
http://epubl.luth.se/1402-1617/2006/118/LTU-EX-06118-SE.pdf
Aug 22, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Hello - I have an Electrolux Dishlex DX302 dishwasher. The washer works okay - but it doesn't always empty the contents of the dishwashing powder in to the dishwasher. It is often wet and stuck in the
If you have hard water, you should reduce the amount of detergent you use. Here's a map showing water hardness in the USA. http://www.citriclean.net/why-citriclean/
Nov 23, 2013 | Dishwashers
I have a Electrolux Dishlex DX302 and the last few washes I have notice that on the ususal cycle it is not heating (steaming) at the end. The dishes are still coming out half clean. I am not sure why the...
Doubble check the settings on your machine.
It is a long way from my heater to the washer. Hot water is essential to the operation of any model machine. I always get hot water to the sink (by running the hot water, of course) before I start the washer. I can tell when I fail to do this.
Just a thought, I hope this aids your situation.
Of course your washer heater may have failed ... You can check it using a volt/ohm meter.
Thanks for your question this morning @ FixYa.com
Jul 12, 2011 | Electrolux Dishwashers
Dishlex dx302 not drying dishes. Doesn't seem to be as hot as usual when opened immediately after finished. Steam not present.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Mar 04, 2011 | Dishwashers
User manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
Nov 12, 2009 | Electrolux Dishwashers
I have a electrolux dishlex dx302 that will not heat the water and dry ,how dose it work?
Yes I had the same problem. One of the solder joints on the relay was cracked but hardly visable. Resoldered it and no problems.
How to do it:
Make sure you turn off the power at the wall and pull out the plug. To get to the circuit board remove the screws on the inside top of the door and pull out the front panel (where the buttons are). Press the little clips and the white box containing the circuit board comes free. Remove all the plugs and lever open the small clips holding the box shut. After you open the box pull the circuit board up and have a look at the contacts under the black little box (relay). Use a soldering iron and some flux cored solder and redo the joints. Put it all back together and turn on to see how it goes.
Worked for me.
All the best......
Jun 29, 2009 | Electrolux Dishwashers
The dishlex 302SB is not producing hot water for the washing
I have a Dishlex 302 which had this fault. Initially I thought it was the inline heater element and replaced it. It seemed to work but later no hot water again. Someone here put me on to the problem. There is a dry joint in the control board in the top of the door. This controls the relay which powers up the heater. Unplug it from the mains (very important) and undo the screws around the top of the door (don't take the door right off!) you will be able to wiggle off the front panel containing the electronics. The control board is ealiy disconnected an removed from the machine in its protective plastic cover. Have a look around the PCB and you will see the dry joint. Resolder with rosin core (electronic) solder, reassemble and you should have hot water.
May 23, 2009 | Electrolux 504199 Dishwasher
Dishlex dx 302 heat drying
Found I had no hot water in my Dishlex DX302 and did a google search and found this page.
My problem was found to be the same as the others; one of the solder joints on the relay on the control board had arced off.
You could see the burn mark on the board and cover where it had been arcing.
Soldered it back together, and now it seems to be going good again.
Now my only problem is a damaged door seal, which means a small water leak; I have used part of a rubber glove to bridge the gap, and it reduces the water leak.
Sep 22, 2007 | Dishwashers
Dishwashers Logo
590 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
